Non-Programmable Thermostat Modding
  • bluto
    • Oct 2007
    • 560
    Hey everyone. I have not been posting much lately but tonight I did a little mod that I thought I would share.
    I have two of these 1F78 non-programmable thermostats laying around since I replaced them in my house. I couldn't help but notice that the insides of these seem to indicate that they could possibly be made programmable somehow.
    Tonight I started looking at this board for clues as to what it was missing. There were a few missing resistors, a missing LED & transistor under the display as well. I starting googling for the model number and found a picture (last attached picture) of the programmable model. So I studied it closely and determined the differences.
    A short time later I un-soldered the zero ohm resistor from W1, soldered a jumper on W2, soldered a jumper across W903, and added a missing 1000 ohm resistor at R10 to connect rest of the button pads to the CPU. I put the batteries back in and my non-programmable thermostat is now programmable! Look at the last picture for programming instructions.
    The only minor caveats are the lack of button holes on the cover and the hole for the display is cropping some of the LCD. But since I am just going to use this as a thermometer, it is nice to have a clock along with it.
    It makes sense from a manufacturing standpoint to have one circuit board that can be both programmable and non-programmable with only some trivial modification. And then they slap on a different cover with some extra button holes. Lo and behold, they can now charge 50% more for the same basic unit.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Non-Programmable Thermostat Modding
    Very nice
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • 3d0
      • Jan 2014
      • 159
      • BiH
      Not much time spent from the manufacturer on making the board more harder to hack/mod.
      Like everything these days, products are shipped in a rush to the markets.
      Nicely done.
      • desert-rat
        • Mar 2014
        • 4103
        Reminds me of some of the vhf/uhf scanners , you could cut one dioed and the scanner went form 200 ch to 400 ch. , or something like that. You could add a dioed and get the cel. freq.s 800mhz and 1300 mhz .
          • 31290
          still the same, but now you just set the frequencys in software.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Wow, very neat mod.
            But why would the manufacturer cripple some of their thermostats like that? Wouldn't they make more money if they sold all of them as programmable? Sigh.
            • desert-rat
              • Mar 2014
              • 4103
              On programable/non programable therms. People will get a programable thermostat and set it to one temp , thinking it will save them money . Some people dont undersand how to set them/dont read inst./ just dont take time to set one , ect.
              • bluto
                • Oct 2007
                • 560
                My house was a spec house so I suppose they need a bargain basement unit for contractors. And then there is the crowd with the blinking 12:00 on their VCR. The simpler the better for those situations.
                • desert-rat
                  • Mar 2014
                  • 4103
                  The programable therm.s do work , if they are set . Hear in the south west where it gets warm in the summer , if you have the therm. get warmer when no one is home , you can save some money . My point was , a lot of people get them , then dont set them rite .
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Yeah, I guess you are right. Explains why we have so many "dumbed down" products today too.
                    Yeah, I myself have not actually seen anyone to "properly" program their thermostat either. Most just set them to one temperature and perma-hold it there until the season is over.
                    I do exactly what you mentioned above - when no one is home during the day, I let the house heat up (summer) or cool down (winter) a few degrees extra. It does indeed save quite a bit of energy. Another thing to keep in mind is that most people get colder as they become sleepy late at night, so that's another place where you can let the temperature drift up a few degrees (in the summer, that is).
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Originally posted by momaka
                      Wow, very neat mod.
                      Because of supply and demand. Increase the supply, and the price goes down on the nicer units. Same reason why intel and others would take good chips and make them celerons and the like...
                      sigpic
                      (Insert witty quote here)
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Actually they do that to sell some of their "lower-quality" batches. The chips from these lower-quality batches are actually the same as the "good" chips, but due to manufacturing equipment tolerances and whatnot, some of them end up with bad cache or not able to run stable at full speed. These chips are then put aside, tested, and configured accordingly to run with a part of their cache disabled or at lower speed (or both) and sold as lower-tier chips. And this is not just common for CPUs and GPUs. Same can apply for rectifiers, transistors, etc.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          ^some, but not ALL. some were legitimatly good chips that were intentionally downclocked... aka higher than expected yield.
                          sigpic
                          • Hondaman
                            • Sep 2008
                            • 1092
                            Nice work there.
                            In 1990 my family bought our first VCR. We could program it to record stuff when we weren't home, and watch it later!
                            Years later, I learned (I'm pretty sure of this) that if you had the IR remote control from a higher-end unit, you could type in the six-digit code found in TV Guide to record with the timer, instead of selecting start time, stop time, which channel, etc. I think it was a Toshiba VCR, but I don't really remember.
                            And most of us here know about the Canon CHDK firmware mod, since Canon used the same powerful chip on many of their lesser cameras, advanced functions could be "unlocked" in them. And one particular hardware revision of the D-Link DI-524 four-port router could, IIRC, be flashed to be a DI-624 (every capability of the 624).
                            Anyway, good job.
                            • SolomonMan
                              Nest Thermostat Discussion...
                              by SolomonMan
                              All,
                              I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
                              The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
                              Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
                              At my boy's place he has a York Stellar...
                              12-11-2022, 10:54 PM
                              Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
                              by sam_sam_sam
                              My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
                              06-22-2025, 10:23 AM
                            • subroto
                              Programmable and non-programmable SIO list
                              by subroto
                              ene kb9012 programmable
                              ene kb9016 programmable
                              ene kb9018 programmable
                              ene kb9022 programmable
                              ene kb9028qc programmable
                              ene kb9010 programmable
                              ene kb3930qf/b1 programmable
                              ite it8585e programmable
                              ite it8586e programmable
                              ite it8985e programmable
                              ite it8587e programmable
                              ite it8522 programmable
                              ite it8987e programmable
                              ite it8589 programmable
                              ite IT8380E programmable 192kb
                              ite IT8380VG programmable 192kb
                              ite IT8995E-128 programmable
                              ite it8886H...
                              01-13-2018, 09:15 AM
                            • ugamazing
                              820-02020 PPBUS_AON missing
                              by ugamazing
                              Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                              Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                              02-05-2025, 04:21 PM
                            • jpreza
                              Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                              by jpreza
                              I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                              Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                              It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                              Looking at the card, it appears to be missing the following:
                              1x 1.0uH inductor - orange square
                              2x...
                              11-01-2024, 10:54 PM
