Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
    • Jul 2011
    • 6070
    My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but I have to come to realization that I do not have keep it that low all the time
    The issue with thermostat that you program are great if you have a predictable schedule and you do not deviate from from it very often plus my wife is not programming inclined but wants to be able to change the thermostat setting when she wants to and not wait for me to change which here is the other issue is that these type of thermostat are not very easily changed because you have to go through all of program settings to just make changes to one set of settings which is some case a pain in the a** to do
    The temperature hold setting is a good feature but it in most cases turns itself back to normal programming settings and you are back to the program and setting that you have
    But I have a concern about doing this type of thermostat controller hooked to the WiFi how easy is it hack and gain full control of your air conditioning system and what safe guards can you do to keep it from being taken over by someone else
    I do have a garage door that is hooked up to the WiFi but what I really use if for is to make sure that the garage door was not left open by accident by someone I have no real issue now but when I first got I had issues getting it worked correctly I put a gate way adapter on my router for it to work properly I had a post about the issues I was having because the manufacturer of this device was not very forthcoming about wireless connection to your router and it you had issues and what could be done about
    • 31283
    never let your house be controlled via the net - ever.
    the company supplying the cloud services will fuck you after 1-3 years by discontinuing the product support,
    or they could lock you out for various reasons.
    finally, your stuff could be messed with by government agencies - specially heating controls.
    there are several cases of governments talking about "maximum temperatures" and messing with cloud thermostats to "save the planet" and similar green bullshit.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8351
      Check out: https://us.shelly.com/?srsltid=AfmBO...7QPtGtWJzytnRy
      You can put custom firmware on these too.
      These can run over a cloud, but don’t have to.
        • Jul 2011
        • 6070
        I really do not see a product that actually controls a air conditioner system or am I missing something about how there systems work
        Just what products would I need to interface with Alexia system software
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8351
          You can control boilers, infloor heating zones, ac, heat pumps etc… it is just done a different way. I’ve got my air exchanger on it. There are many Shelly devices for one purpose or another…
            • Jul 2011
            • 6070
            I am not familiar with there devices so I am not sure exactly what I need can you give me example of what you have so I can do some research on this topic any help would greatly be appreciated
            Can you explain how you use this system on your air conditioning and heating systems and what method you use to set parameters and so on
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8351
              You control em through powering them on or off either with power or one with an isolated relay. You can mimic button pushes and can pair a certain shelly device with a wireless button. You can set scenarios, like one Shelly device detects water, another Shelly device that is paired to the first one will turn on the pump automatically etc. You can control them via cloud or direct. They don’t need the cloud in order to work. The firmware has schedulers, etc.
              So for automatic dehumidification, either use a Shelly plug or a Shelly plus one by itself on the internal scheduler, or buy that thermostat with humidity to go with it and merry them two together. The thermostat humidistat will command the other shelly on or off when certain conditions are met.
              I use them for air exchange (set on a daily schedule), dehumidifier control and basement lights (I am too forking lazy to walk down and back up, because of something I want to turn on or someone left the lights on again, etc.
              I also used them for remote controlled reset button for devices that get hung up there is one that has an isolated relay. You can make a lot of dumb devices smart with their products. You can also use some of them as a power monitor. I have one in a metal crazy long power bar. Lets me also control the power bar and you can set it to protect. For example you set it to shut off if the current exceeds 500w. Lots of uses for these.
              I haven’t hacked in a Shelly to the power button of my heat pump head… just yet.
                • Jul 2011
                • 6070
                By the way the thing about two or three years after you buy then they start playing games like that are wanting more money and telling you that you really do not own anything so I would not give a crap about this as well I just would not buy another end of story
                Yes I aware of this government is capable of doing but other identities do far more damage just in different ways wanting money and threatening to not give you anything back in return I would not pay there ransom in the first place the government will play games with deny you services or want to investigate because they you are a threat to national security or whatever drum up charges they can find I do not give a rats a** about that I am more concerned about hackers and there motives are because they are unpredictable in what they are really after so just do it for the thrill of to see if they will get caught then you have the type that are just doing because they want your money and think that you can not do without I could give a sh*t about that as well
                  • Jul 2011
                  • 6070
                  Decided to buy one and I am about to return it back to the store because of the Google user agreement they want to know where you live making it public want to know where your phone is located 24 hours a day I do not think so
                  So very intrusive in your privacy this is not funny anymore I will program my thermostat and be done with this crap
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8351
                    One reason why I use Shelly, as I can control them without the cloud shit.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5085
                      • New Zealand
                      It amazes me the number of people who willingly install these "smart home" spying devices where they live.
                      These things report back all sorts of data to who knows where... not to mention they also often become a brick when the company inevitably discontinues support a few years later anyway, or suddenly adds a subscription fee, or doubles it if there already was one, etc.
                      Way more hassle than they're worth. No thanks!
                      -David VanHorn
                        • 31283
                        worse than you think,
                        a robot floor cleaner took stills of a woman sitting on the toilet and relayed it home somehow.
                        (mesh networking?)
                        a worker at the company who saw it - reviewing footage?, put it on social media!
                        the woman is taking legal action.
                        this is a warning to people that these devices can create their own networks to connect to whereever without your help!
                        a lot of korean smart tv's can mesh network to each other to create a path to the internet too.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5085
                          • New Zealand
                          (mesh networking?)
                          Crazy! I hope they get sued big time. Wasn't there also a similar thing with a Tesla car uploading video of a guy in his own garage that people had shared within the company?
                          Oh yeah I heard of that one before, if I am ever unfortunate enough to own a "smart" TV (unlikely) I would definitely remove any antennas, mic, and paint the camera before use!
                          -David VanHorn
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8351
                            (mesh networking?)
                            Must have been a roomba with the cam. Roborock makes circles around Roomba on any day!
                              • Jul 2011
                              • 6070
                              What interest do these companies have in invading your privacy what is the ultimate goal or purpose of this nonsense do we need to be concerned about any internet connected device that we buy now but what I do not like is that there are no other option for a device like tv every thing is a smart tv anymore on some of them you can choose not to hook to the internet but apparently this option is not on all of them one thing I noticed is that when there is an update on one it asks you repeatedly and after a while it just does the update anyway without you permission really this is not acceptable at all
                                • 31283
                                DATA is the new product,every government wants to collect it and every corporation wants to sell it.
                                all the talk of saving energy is because the fucks want gigwatts of power to run the AI farms that will try to collate all this shit into something useable!
                                  • Jul 2011
                                  • 6070
                                  I do not know if I could have said this any better
                                  Unethical at best and corruption at its worst
