XP must be activated?
  • ron350
    • Feb 2014
    • 296
    Turned this computer on today and there was a blue screen with a window that said. This copy of Windows must be activated within three days.
    Now there is a blue star in the start up bar at the bottom of the page.
    This computer is using XP service pack 3 with Firefox.
    Microsoft wants me to install-Windows genuine advantage installer- but it will not install.
    Is there any way around this without buying a new computer?
  • c_hegge
    • Sep 2009
    • 5219
    Re: XP must be activated?
    That usually happens if you make any significant changes to the hardware. You don't need to buy a new computer. Just run through the activation procedure. It takes about a whole 30 seconds. You don't need to install the genuine validation tool to activate.
    • ron350
      • Feb 2014
      • 296
      C hegge thanks for the help but I can’t find XP Home CD or product key.
      1. Locate your product key. Microsoft product keys contain 25 characters divided into groups of five, and are located on the proof of license label attached to your DVD case or on a Certificate of Authenticity attached to your PC.
      2. Click Start.
      3. Point to All Programs.
      4. Click Activate Windows.
      5. Follow the instructions to activate Windows XP.
      I had it back when I installed MS security essentials why are they after me now?
      It says buy a copy of windows 7 or else.
      The only thing that has changed on this old computer is an updating Firefox a few weeks ago.
      • R_J
        • Jun 2012
        • 9624
        You can find your install cd key by using a key finder program like magic jelly bean
        Also check your system bios date, sometimes if it gets changed back to default this can happen
        Also fyi Don't install windows updates KB2934207 or KB2949787
        • ron350
          • Feb 2014
          • 296
          Well that was scary.
          I found the XP CD and this time MS activate did not ask for the product key.
          Sorry I just noticed this is in the wrong section please delete.
          • c_hegge
            • Sep 2009
            • 5219
            Thread moved to appropriate section
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              sometimes if its not connected to the internet for a loong period of time (of has been off for that long period of time) it will do this, reconnect it to the internet, and rebooting usually fixes such things for me
              • abbylee
                Banned
                • Jan 2015
                Try finding a free key on google.
                • c_hegge
                  • Sep 2009
                  • 5219
                  You can't. Even if you do find one, it will be blacklisted and activation will fail.
                  • ron350
                    • Feb 2014
                    • 296
                    Thanks for the help I found the MS product Key and turned off the dooms day clock.
                    Microsoft is leaving me alone for now.
                    Don’t have a clue why MS came after me nothing has changed with this old computer.
                    M$ night have targeted me because I have automatic updates turned off?
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      Don't have a clue why MS came after me nothing has changed with this old computer.
                      On most non-oem installs of Windows XP if it has been more than 120 days after the original activation and the computer has not had sufficent internet time to connect to a Microsoft server, then it will think that it is a fresh install and needs to be reactivated, that all.
                      • reaper57
                        • Sep 2014
                        • 216
                        • Norway
                        That moment when you realize that pirate activators are designed to work better than the M$ activation system...
                        Keyboard not detected, press F1 to continue...
                        • GaryCole
                          • Jan 2015
                          • 5
                          Sometimes I faced it as well. I use google to solve that problem
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Not likely. Likely when vice-versa.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • davidkien68
                              • Jan 2015
                              • japan
                              follow like this, you just need to safemod and restore window is ok
                                Copy DMI info easily with Hex editing software and Macro script
                                by SMDFlea
                                Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                02-28-2023, 02:14 PM
                              • Caimano
                                Need to copy DMI info for HP ProBook 650 G2 Bios
                                by Caimano
                                UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
                                Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
                                01-03-2024, 05:19 AM
                              • Hondaman
                                Firefox is now SATANIC
                                by Hondaman
                                Now that I have your attention:
                                In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
                                I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
                                I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
                                03-05-2025, 04:41 PM
                              • sdinelli
                                latitude e5550 - no charge- all battery not recognized as genuine
                                by sdinelli
                                -latitude e5550 all batteries sense as non genuine(ive tried two working genuine and two new non genuine).
                                -battery led flashing white and amber which indicated non genuine AC adapter. tried multiple bios.
                                -ive tried multiple genuine chargers
                                -the circuitry seems to be working fine and battery and charging seems to be controlled by EU2 which is ECE5048-LZY
                                https://datasheet.octopart.com/ECE50...-147335658.pdf
                                does this chip have to be programmed? or is it replaceable? do you all think this could be the reason?
                                i have two of these same...
                                11-14-2021, 09:52 AM
                              • m0seba
                                how to block copy from network access
                                by m0seba
                                hi
                                there is a small company have 4 computers and server with windows server 2016
                                all computers are entered into the server by local users, and there is shared folders on server with limited access to every computer
                                my question is there any method to disable copping form all shared folders on this server, but jest disable copy form server not paste on it.
                                my client want his team copy from their computers and paste on any shared folders on server, on the other way can not copy anything from shared folders to their computer.
                                or any way to disable copy on windows...
                                03-16-2021, 03:35 PM
