Will an HP DV9000 Boot from SSD ?
  • diif
    • Feb 2014
    • 6978
    • England
    #41
    Re: Will an HP DV9000 Boot from SSD ?
    They are hidden away on the .eu site, i didn't check the .com
    http://www.pny.eu/s/d/Downloads/PNY/
    • mmartell
      • Oct 2013
      • 3189
      There is some voodoo here. Getting strange errors and having a real hard time installing any os. Memory tests good.
      Going to harvest a hd from my daughters lappie and see how an installation goes on a new partition.
      Does a regular Drive scan work to pick up errors on an ssd because I couldn't find any...
      • diif
        • Feb 2014
        • 6978
        • England
        #43
        The free version of SSD life should let you know.
        http://ssd-life.com/eng/SSDLife-Freeware.html
        • mmartell
          • Oct 2013
          • 3189
          Hey thanks for that ! Will check it out tomorrow.
          • diif
            • Feb 2014
            • 6978
            • England
            #45
            There's also http://hddscan.com/
            • mmartell
              • Oct 2013
              • 3189
              Those are for Windows installs I need a self-boot program.
              Anyway I think that's not the problem. Moved the drive to the secondary port and managed a full install of Ubuntu but of course it won't boot from there. Loaded up the Live CD again and when I went back to it shortly thereafter the laptop was off. Loaded live-boot Memtest and came back 15min later and again laptop was off.
              Something is seriously screwy, maybe one of the bga's needs a reflow/reball ??
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                #47
                Overheating problem? Is the heatsink clean?
                -David VanHorn
                  • 31204
                  you should be able to set he bootdrive in the bios.
                  unless it's one of thoe half-ass INSYDious ones.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Uh oh. WHAT heatsink ?
                    If I remove the access door to get to the ram and wifi card I can see the nvidia chip there. No heatsink in sight...
                    • mmartell
                      • Oct 2013
                      • 3189
                      There is no way to set the secondary hdd port as bootable.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5037
                        • New Zealand
                        #51
                        The CPU\GPU heatsink. I assume it has one... most laptops have a heatsink and fan of some kind.
                        Laptops are more prone to getting theirs full of dust, because people use them on carpets, beds etc.
                        -David VanHorn
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          The symptoms sound like possibly a faulty drive.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • mmartell
                            • Oct 2013
                            • 3189
                            Ok scratch that, it's become obvious the nvidia chip I was looking at is not the gpu.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Tomorrow I will remove the drive from the system and run the Ubuntu Live CD and see how she behaves. Also I will check the fan/exhaust.
                              Failing an easy fix I will look at disassembly.
                              • reaper57
                                • Sep 2014
                                • 216
                                • Norway
                                #55
                                Ya the boot order is very simple and does not specify booting from Primary or Secondary.
                                I believe this was formatted as one partition originally.
                                I do remember now what happened last time I messed with this. The drive was not seen by the system so I moved it to the secondary bay and that allowed me to install Win7 to it but it wouldn't boot from there. Moving the drive back to the Primary bay gives the "No OS Found" message.
                                Gonna mess a little more with this in a bit.
                                The point of deleting and formating all partitions is not to have the whole drive as one partition, but to remove any left over bootloader files.
                                Keyboard not detected, press F1 to continue...
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Update: removed the ssd from the system and still could not boot the Ubuntu Live CD fully. By that I mean I get to the desktop but soon after the system freezes and becomes unresponsive.
                                  To rule out ram I used two pieces (3gb) from another lappie which is running the live cd fine. No change.
                                  But dig this. I downloaded Lubuntu for another older pc I have and tried that out on the dv9000. Works like a champ !
                                  I would think the Nvidia driver is the same for Ubuntu and Lubuntu but can't be sure. What do you think ?
                                  God damn I just had an epiphany !! I would bet my left arm the system doesn't have enough memory allocated to the gpu in the bios. I will try that in the morning!!
                                  As for the ssd I'm about ready to fire that out the fucking window.
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    #57
                                    ^ both use the same driver, nouveau. unity was always crappy with lower end, or older graphics. what SSD? my compaq CQ57 wouldn't work with an OCZ, but it worked fine with a sammy evo pro.
                                    Follow the white rabbit.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      PNY ssd
                                      • reaper57
                                        • Sep 2014
                                        • 216
                                        • Norway
                                        #59
                                        Have you tried using something like hiren's boot cd to windows?
                                        It has a lot of usefull tools that can get your os to boot.
                                        First try restoring the BOOTMGR and the NTLDR. If that doesn't work try changing the active partitions. And if all else fails why not try installing windows from another pc, then install the chipset and sata drivers or if they can't install just place them in the windows drivers folder with some live os from hirens boot cd of through another computer.
                                        P.S. One of the tools in the live cd had an option to force boot a drive, but I don't remember which one and I don't have it with me right now to check. :P
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          I am going to keep working at it. I'm not trying to recover anything just trying to get a fresh install to boot from the primary hard drive bay. Should be a nno brainer but it's not.
                                          • privato89
                                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                            by privato89
                                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                            Let's begin:
                                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                            03-26-2024, 06:37 AM
                                          • Luke Anders
                                            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                            by Luke Anders
                                            A few details about the laptop itself:
                                            Name: Lenovo Legion 5
                                            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                            BIOS Version: GKCN60WW
                                            EC Version: GKEC65WW
                                            Serial Number: PF39AQ7Z
                                            Board Model: NM-D562 Rev 3.0
                                            RAM: 16GB Installed, DDR4 (brand new)
                                            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                            I bought this laptop recently from eBay as a faulty device....
                                            10-12-2024, 05:13 AM
                                          • hinisa
                                            Xiaomi router freezes at boot after re-capping
                                            by hinisa
                                            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                            07-08-2023, 05:58 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • praveenramavath
                                            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                            by praveenramavath
                                            Hello All,
                                            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                            https://www.hifivision.com/threads/m...-screen.98243/
                                            Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                            04-26-2025, 09:08 AM
