Will an HP DV9000 Boot from SSD ?
  • mmartell
    • Oct 2013
    • 3189
    I've read conflicting opinions. If it depends on the Bios does the system really need to have Vista installed ?
    I have Win7 on the ssd and all I get is "No OS Found"...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Will an HP DV9000 Boot from SSD ?
    I have a Crucial C300 SSD in mine with Windows 7. It works great. Try doing a clean install.
    A working TV? How boring!
    • mmartell
      • Oct 2013
      • 3189
      I did and it installed fine but will not boot from it. Is it bios dependent or maybe just finicky with the brand ?
      • diif
        • Feb 2014
        • 6978
        • England
        There shouldn't be a problem. It ideally needs Vista or above rather than XP as XP doesn't support TRIM but i can be done.
        What happens when you try and boot. do you get an error message ? What make/model SSD is it ?
        • mmartell
          • Oct 2013
          • 3189
          The message is "No OS Found". Can't remember what make/model the damn thing is but if I go into the bios it is not seen by the system.
          And it is Win7 not XP.
          • diif
            • Feb 2014
            • 6978
            • England
            Did you install Windows 7 or clone it from a hard drive ?
            I've fitted a few hundred SSD of various makes in many different types of machine. they do die, some more so than others like the older OCZ.
            Have you another PC you can test the drive with? Check to see if there is a newer firmware for it.
            • JuniperSprouts
              Solder Soldier
              • Aug 2010
              • 119
              mmartell,
              I recommend that you follow the advice on here.
              1. Confirm that the drive is OK (find diagnostic software from the manufacturer). We can help if you actually give us make/model.
              2. Try installing on a regular HDD. Confirm that the laptop boots it. Image the HDD install onto the SSD.
              • mmartell
                • Oct 2013
                • 3189
                The drive is well enough that Win7 was installed on it from an installation disc. The Windows disc could see the drive and so it could install to it but after rebooting the system doesn't see it.
                Just thought of something. Will get back...
                • reaper57
                  • Sep 2014
                  • 216
                  • Norway
                  I've had almost the same problems with HDDs. Try formating all of the partitions on the drive, deleting them and then allocating all space to one partition and formating that.
                  If it doesn't work try forcing the pc to boot from the SSD via the quick boot options or the BIOS.
                  Keyboard not detected, press F1 to continue...
                  • mmartell
                    • Oct 2013
                    • 3189
                    This thing is wacky as hell. I burned a Ubunto.iso both to dvd and usb flash and it loads sometimes, others it just goes off into the weeds with a black screen so there is something more at work here.
                      • 31204
                      is this a UEFI bios ???
                      • mmartell
                        • Oct 2013
                        • 3189
                        Ummm... what is that ?
                        • Compgeke
                          • Feb 2014
                          • 524
                          DV9000 is old enough it won't be UEFI at all.
                          • reaper57
                            • Sep 2014
                            • 216
                            • Norway
                            UEFI BIOSes are the new "Windows 8" BIOSes. An uefi bios has a few features like faster post, even faster post and a faster boot if the installed OS is windows 8/8.1. It also adds mouse support in the BIOS and some other features, some of which are useful, others are are just cool to have.
                            But, as said in the post above me, the DV9000 is old and it doesn't support that. In fact I think anything older than windows 8 doesn't come with an UEFI BIOS.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Ok thanks for that explanation. This laptop came loaded with Vista so no uefi here.
                                • 31204
                                that's BS UEFI bios has been in devices for well over a year.
                                and it's not for booting win8 faster, it's for locking down the machine so it wont boot "unauthorised code" as MS puts it.
                                http://www.uefi.org/
                                https://en.wikipedia.org/wiki/Unifie...ware_Interface
                                  • 31204
                                  older than you think.
                                  In 2009, IBM shipped System x machines (x3550 M2, x3650 M2, iDataPlex dx360 M2) and BladeCenter HS22 with UEFI capability. Dell shipped PowerEdge T610, R610, R710, M610 and M710 servers with UEFI capability. More commercially available systems are mentioned in a UEFI whitepaper.
                                  In 2011, major vendors (such as ASRock, Asus, Gigabyte, and MSI) launched several consumer-oriented motherboards using the Intel 6-series LGA 1155 chipset and AMD 9 Series AM3+ chipsets with UEFI.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Windows 8 gives the impression of booting much faster as it never shuts down only sleeps.
                                    UEFI has been around a while, Dell have been using in some of their laptops for at least a couple of years on some models. I also built 60 PCs a couple of years ago with Gigabyte motherboards that had UEFI.
                                    • reaper57
                                      • Sep 2014
                                      • 216
                                      • Norway
                                      Wow, I wasn't really expecting people to react to my post like that. Yes UEFI has been around for some time, but it became widely spread around the release of windows 8. I didn't say it was made only to boot win8 faster, that's just some of the things it does. I was simply trying to give a basic description of what UEFI was and the main features that most users get from it (I said most users to avoid posts of people telling me that it does much more). The sleep thing is mostly why the OS boots faster, but I've seen that on the few laptops that have UEFI support I've tested it does boot a tiny bit faster.
                                      Anyway I think that this is a bit of topic, the guy simply asked for a quick description of it not a wikipedia reference or us telling him the history of UEFI.
                                      Ow and thanks for the quotes and links, I did learn some useful things from them.
                                        • 31204
                                        the important thing is UEFI stores junk on a hidden partition and can be a bastard when you want to swap the drive or install a new o.s. unless you get the settings right and make sure the drive is really blank.
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
