Will an HP DV9000 Boot from SSD ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Will an HP DV9000 Boot from SSD ?
    Fail.
    Going to download a bootable stress test program and try to isolate the assumed faulty hardware before opening this thing up.
    • mmartell
      • Oct 2013
      • 3189
      Turns out the freezing was a driver issue - the default Ubuntu one is no good for the installed Nvidia card.
      So now the OS boots - most times. Other times it errors out into a shell. Sometimes on boot I see the Grub menu, sometimes I don't. What's up with that ?
      Also tracking down one more issue. When the system boots into Ubuntu I'm faced with a blank desktop, no unity and no icons. If I wait until the screen goes to sleep when I wake it I'm faced with the logon from which I can switch users instead and logon as Guest. The Guest account looks as it should. Strange, no ?
        • 31204
        the grub menu lets you enter parameters.
        try "XDRIVER=VESA"
        i cant remember if it needs to be uppercase.
        that should override the video driver - because the 3rd party nvidia one is crap.
        • mmartell
          • Oct 2013
          • 3189
          I've already switched to an alternate one and it's working fine. Just have to solve my missing desktop and erratic boot and will be golden
            • 31204
            as it leaves the bootloader and starts to boot, hit Esc to go to text and watch the messages for anything in red.
            • mmartell
              • Oct 2013
              • 3189
              That probably flies by how do you log it ?
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                #67
                I think you'll find what you want gets logged in /var/log/dmesg (a text file)
                You can also print the whole log out on the console with the 'dmesg' command
                -David VanHorn
                • mmartell
                  • Oct 2013
                  • 3189
                  Just by typing 'dmesg' ?
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5037
                    • New Zealand
                    #69
                    Yes. You will also need to press enter of course
                    But looking at the text log file in an editor is easier to scroll through. And to copy out any relevant sections.
                    If you want to see the start of the file in the console, type 'dmesg | head' (this pipes the output of the dmesg command into the head command), which shows the first part.
                    You can also look at the end with 'dmesg | tail' (although not much use since dmesg will already show the whole file to the last entries anyway)
                    You can also send to the 'less' command which lets you scroll through it easily with 'dmesg | less'
                    -David VanHorn
                    • mmartell
                      • Oct 2013
                      • 3189
                      Ok thanks
                      • mmartell
                        • Oct 2013
                        • 3189
                        I had an Acer laptop here with a standard 250gb platter drive here and pulled it out not realizing they were compatible. Put the ssd in it and the damn thing boots up error free to the desktop in about 10-15 seconds after post. So in answer to the title of the thread NO the DV9000 will NOT boot from SSD at least not my dv-9-zero-zero-zero and not with my pny 80gb ssd.
                        When I put the other hard drive in the dv9000 I could install Ubuntu and boot to it but was still seeing many errors and it wouldn't shut down. After removing the wireless card most of the errors are gone and it shuts down by itself but it takes almost a minute and a half to boot up so there are still problems, probably still hardware/driver related.
                        For such a nice looking unit I've come to the conclusion it's just a piece of shit with endless compatibility problems unless you're running the Vista it came with.
                        Will mess with it again this week when the replacement wireless nic comes in.
                          • 31204
                          try the very latest SuSE linux if it's out yet.
                          http://www.opensuse.org/en/
                          1 day to release as i type this.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            #73
                            STOP. If you're having wireless issues, it's 100% the nvidia chipset to blame. Replacing the wireless card will not fix anything.
                            A working TV? How boring!
                            • mmartell
                              • Oct 2013
                              • 3189
                              That MAY be true. However when I googled the Broadcom 4311 chipset I found there was a known driver issue and a workaround which I did not try as that is the same time I found out the card was only wireless G.
                              And I am not having display issues either. Another known driver issue forced me to switch to the Nvidia driver from Xorg and all is good.
                              I will say I have not used the system for any length of time yet so I am still open to your suggestion.
                                • 31204
                                so you switched from Neuvou to NV driver?
                                cant you use the real nvidia driver?
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Dunno, there were two alternatives and I have tried them both. One seems as good as the other, which is to say either works fine.
                                  I was under the impression judging by the name that one of them is the real Nvidia driver but don't know that for fact.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    I've installed the new wifi card now I can see all wireless networks but cannot connect. I put the card in my other laptop and same thing. Both lappies are running Ubuntu 14.10
                                    So to rule out a bug or software issue with Ubuntu I've installed Win XP on the DV9000 but am having trouble finding a good driver. Windows seems not to even try its own database is there a setting somewhere for that ?
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5037
                                      • New Zealand
                                      #78
                                      What chipset is the WiFi card?
                                      -David VanHorn
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Broadcom 94321mc
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5037
                                          • New Zealand
                                          #80
                                          I think your Ubuntu issue may be a firmware\driver one: https://help.ubuntu.com/community/Wi...Driver/bcm43xx not sure though, never used one of those chips myself, I think mine are all Atheros, Realtek or Ralink.
                                          -David VanHorn
                                          • privato89
                                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                            by privato89
                                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                            Let's begin:
                                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                            03-26-2024, 06:37 AM
                                          • Luke Anders
                                            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                            by Luke Anders
                                            A few details about the laptop itself:
                                            Name: Lenovo Legion 5
                                            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                            BIOS Version: GKCN60WW
                                            EC Version: GKEC65WW
                                            Serial Number: PF39AQ7Z
                                            Board Model: NM-D562 Rev 3.0
                                            RAM: 16GB Installed, DDR4 (brand new)
                                            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                            I bought this laptop recently from eBay as a faulty device....
                                            10-12-2024, 05:13 AM
                                          • hinisa
                                            Xiaomi router freezes at boot after re-capping
                                            by hinisa
                                            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                            07-08-2023, 05:58 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • praveenramavath
                                            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                            by praveenramavath
                                            Hello All,
                                            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                            https://www.hifivision.com/threads/m...-screen.98243/
                                            Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                            04-26-2025, 09:08 AM
