Will an HP DV9000 Boot from SSD ?
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Re: Will an HP DV9000 Boot from SSD ?
    Yeah UEFI really sucks. I don't really find it useful for almost anything.
    mmartell did you try to format the drive the way I told you? And did it work?
    Keyboard not detected, press F1 to continue...
    • Agent24
      I see dead caps
      • Oct 2007
      • 5037
      • New Zealand
      Have you got the latest BIOS?
      I had an HP laptop, an old ZE4201, HDD was dead, put a new one in, but CD wouldn't boot anything, not even the official HP XP restore CD that came with it. Thought the drive was bad, tried USB drive, doesn't work either. Floppy doesn't work.
      BIOS is like 5 years out of date from latest version.. but I can't boot a floppy or CD to update it! Lucky it's socketed and easy to get to.. pull the EEPROM and update manually with my Willem. Now CD and floppy boot anything I throw at them! (WTF HP?)
      -David VanHorn
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        did you set the boot order in the bios?
        • mmartell
          • Oct 2013
          • 3189
          Ya the boot order is very simple and does not specify booting from Primary or Secondary.
          I believe this was formatted as one partition originally.
          I do remember now what happened last time I messed with this. The drive was not seen by the system so I moved it to the secondary bay and that allowed me to install Win7 to it but it wouldn't boot from there. Moving the drive back to the Primary bay gives the "No OS Found" message.
          Gonna mess a little more with this in a bit.
          • mmartell
            • Oct 2013
            • 3189
            As far as bios goes I think it will only flash from Vista and I'm having enough trouble as it is atm lol.
            • mmartell
              • Oct 2013
              • 3189
              Also the bios makes no mention of AHCI if that's important.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                What is the make/model is the drive?
                What exact model is the HP? There several variants of the DV9000 designation IIRC.
                These things may make a difference.
                BTW, I forgot to add that AHCI is a controller specification for SATA drives but is not a requirement for SATA drive operation. It may or may not be supported by the motherboard chipset.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #28
                  There's A TON, not several variants of the DV9000. I know of 6 major variations, there may be more than that. If it's an AMD version it's going to have nvidia chipsets everywhere - those are known problematic so it could be a hardware issue.
                  A working TV? How boring!
                  • mmartell
                    • Oct 2013
                    • 3189
                    Yes it is the amd version with Nvidia but...
                    As it turns out there is a more mundane explanation.
                    For whatever reason the adapter when seated wasn't making a connection inside the socket so I wedged it out some and it gets recognized by the system now every time.
                    Is Ubuntu a good "starter linux" or any recommendations ?
                      • 31204
                      you should start with Ubuntu or Mint
                      but with one important point.
                      choose the version with the KDE desktop, not cinamon or mate.
                      oh, you need a minimum of 1gig of ram for the Mint installer - not sure about Ubuntu
                      • mmartell
                        • Oct 2013
                        • 3189
                        What does it mean to choose a desktop ? Is that just the gui, like a theme or a layout ?
                          • 31204
                          exactly, it's the GUI.
                          KDE is very much like windows - you wont have any trouble trying to find things.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5037
                            • New Zealand
                            #33
                            I personally use XFCE, it has a nice classic Windows look. Definitely stay away from Unity, unless you are the kind of person who loves Windows 8 and Metro.
                            -David VanHorn
                            • mmartell
                              • Oct 2013
                              • 3189
                              Ok thanks for the tips!
                              • mmartell
                                • Oct 2013
                                • 3189
                                Now, I've read it's wise to keep the firmware updated on an ssd so how come there is zero information about doing that on the PNY website ?
                                Model is 69D03092-T.
                                  • 31204
                                  probably because they have not found any bugs.
                                  i mean, if they cant find any problems - what's to update!
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    #37
                                    Sometimes firmware (in general) is updated for performance or to add features rather than fix bugs.
                                    -David VanHorn
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #38
                                      PNY do have some firmwares on their website for SSD, i think they've just dropped support for them.
                                      • Mad_Professor
                                        A Mech Warrior
                                        • Feb 2011
                                        • 1587
                                        #39
                                        sounds like you need sata drivers during the install.
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          Where do you see these ?
                                          • privato89
                                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                            by privato89
                                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                            Let's begin:
                                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                            03-26-2024, 06:37 AM
                                          • Luke Anders
                                            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                            by Luke Anders
                                            A few details about the laptop itself:
                                            Name: Lenovo Legion 5
                                            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                            BIOS Version: GKCN60WW
                                            EC Version: GKEC65WW
                                            Serial Number: PF39AQ7Z
                                            Board Model: NM-D562 Rev 3.0
                                            RAM: 16GB Installed, DDR4 (brand new)
                                            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                            I bought this laptop recently from eBay as a faulty device....
                                            10-12-2024, 05:13 AM
                                          • hinisa
                                            Xiaomi router freezes at boot after re-capping
                                            by hinisa
                                            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                            07-08-2023, 05:58 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • praveenramavath
                                            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                            by praveenramavath
                                            Hello All,
                                            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                            https://www.hifivision.com/threads/m...-screen.98243/
                                            Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                            04-26-2025, 09:08 AM
