Hello I have an old computer which got infected with malware.....
and will only boot in safe mode with command prompt. I am not able to access a usb stick because it says does not have a recognized file system, I cannot use floppy dive because i have no computer to read floppies, and the disc drive just sits there blinking.
So I tried plugging the hard drive in to my good realitively new pc IDE port (unplugging my disc drive) with my good two hard drives plugged into the SATA ports. I booted it up and it tried booting from the infected hard drive even with the drive set to slave.
My main question is can i plug my hard drive into my pc while it is running or will that kill something?
Thanks for any help
canadaboy25
and will only boot in safe mode with command prompt. I am not able to access a usb stick because it says does not have a recognized file system, I cannot use floppy dive because i have no computer to read floppies, and the disc drive just sits there blinking.So I tried plugging the hard drive in to my good realitively new pc IDE port (unplugging my disc drive) with my good two hard drives plugged into the SATA ports. I booted it up and it tried booting from the infected hard drive even with the drive set to slave.
Thanks for any help
canadaboy25
