Clipped?
  • stevo1210
    • Oct 2006
    • 4156
    Clipped?
    Hello Everyone,
    I have a computer here which I got for free off a friend because of badcaps and a broken CPU heatsink retention clip.
    The badcaps are gone now, i replaced all the Chhsi caps and it boots well and loads Windows XP. But the CPU has a broken Heatsink clip so the heatsink has to be held down to cool the PC properly.
    I wish socket 370 was like socket 478 so I wouldnt get into situations like this.
    Anyone got a good idea I could try to fix this broken clip? I was actually thinking of some metal wire to tie the heatsink down to the remaining clips...... I know some people have tried that and it works.
    I'm trying to do this the cheapest way since this IBM Netvista 800MHz PIII computer isn't worth the money to get those special heatsinks with 3 clips.
    Thanks.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Clipped?
    buy a heatsink that anchors on all 3 of the tabs rather than just the center one. That has saved a lot of old socket 370 and socket 462 motherboards from being tossed on the scrap pile.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • stevo1210
      • Oct 2006
      • 4156
      Re: Clipped?
      Thanks Topcat, But theres one issue.... will a three anchor heatsink fit onto this board? theres only 2 tabs on each side. Not 3 tabs like socket A for AMD.... I know some people with success using a metal wire so i will probably try that next. I don't really want to spend money on a new heatsink....
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Re: Clipped?
        Yes, it will fit an S370 socket. It'll grab the big fat tab on the outer edge. That fatty is insanely strong, so if you manage to break that one, you're torquing it down way too hard.... lol... I've used 3 tabf heatsinks many times to save boards with a broken center tab (many S370's). Personally, I'd avoid any kind of gluing or attempting to wire it. It rarely works, looks like crap, and tends to not last very long.
        Team : 49813
        Join in!!
        Team Stats
        • Rainbow
          • Aug 2005
          • 1375
          Re: Clipped?
          Heatinks are cheap. Use the cheapest one you can find with 3-tab anchor.
          • Shroomie
            • Apr 2006
            • 356
            Re: Clipped?
            I agree with TC and Rainbow. You can get a decent heatsink pretty cheap, if you look; it's only a P3-800 so a cheapo HSF would be fine.
            You know there's something wrong when you open up a PSU and are glad to find Teapos.
            Why I don't buy cheap cases!
            • MD Willington
              • Sep 2004
              • 702
              Re: Clipped?
              +1 to that, even a cheap Socket A HSF combo will be overkill and work well. I ran a XP2800+ HSF combo on a P3-733... one cool processor there...
              Ya'll think us folk from the country's real funny-like, dontcha?
              The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
              • stevo1210
                • Oct 2006
                • 4156
                Re: Clipped?
                Um.... I decided to sticky tape my heatsink onto the CPU itself and It's been running for the last 6 months 24/7 with no problems.... but I have a feeling that the tape on the CPU isn't going to last any longer because this PC gets really really hot....
                I think I have to resort to a 3 clip heatsink....
                Or.... I could just replace the motherboard but I wouldn't be able to find one that would fit because this PC uses a motherboard thats even smaller than an mATX board.
                .... besides it would be too expensive anyway.... oh and the $20 of caps I spent on this motherboard can't go to the trash either.... Looks like I'm going to have to buy a 3 clip heatsink.
                • linuxguru
                  • Apr 2005
                  • 1564
                  Re: Clipped?
                  Vaguely (un)related, but Intel makes a $70 mini-ITX board called the D201GLY which can replace just about any old mATX board as long as you need just one PCI slot and have an 4-pin +12v connector on your PSU. It uses a 1.33GHz Yonah Celeron, 512k L2, one DDR2 slot, and consumes just 25W. The only catch is that the CPU is soldered on the mobo.
                  http://www.intel.com/products/mother...1GLY/index.htm
                  This pretty much destroys the Tualatin Celeron as the entry-level CPU of choice for me.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: Clipped?
                    i would never trust sticky pads to hold a cpu cooler.
                    look around at computer shops for a cheap one or maybe a friend has one they upgraded.
                    i bought 50 stock amd coolers from mendelsons at hamvention for $1 ea.
                    they had copper baseplates and 3 hole clips.
                    the deals are out there if you dig.
                    • Maxxarcade
                      • Jul 2006
                      • 973
                      Re: Clipped?
                      I put a 3 clip Athlon heatsink on my old K6-2 550 system that kept overheating, works fine now
                      I really think they should have had more 3 clip heatsinks around back in the socket 7/370 days. The sockets have always had the extra lugs, but most heatsinks at the time only used the fragile center lugs. The outer ones were originally for the heatsinks that had the "Z" shaped spring that held the heatsink on. My old Pentium Pro HP Netserver E40 used one of those.
                      The center lugs weren't bad until heatsinks started getting insanely heavy.
                      I'll never forget my first water cooling system, the waterbloack was held on the CPU by a flimsy spring. I ended up stabbing a screwdriver through my beloved Soyo 5EHM trying to mount the damn thing. And the water tank was a cooler with holes drilled in it for fittings. I got it from a place called Overclocker's Hideout back in 1999 if I recall. Now water cooling is all but mainstream compared to back then.
                      • bgavin
                        • Jan 2007
                        • 1355
                        Re: Clipped?
                        Alpha makes two that work very well. The original PAL 8045 required four through-bolts into the board. These was standard per the AMD spec, but not everybody adhered to that spec. Others put resistors, etc, in the protected zone around the socket.
                        Alpha came out with a second solution, which is an assembled clip-bracket that is assembled in pieces under the CPU socket. The kit comes with micro screws that I Loctite into place when building the bracket. It pulls against the underside of the CPU socket, and provides a secure mount point for the big Alpha heat sink.
                        I get a 4C delta on a Sempron 2400+ at stock clocking.
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • harp
                          Metod for removing glued heatsink from fragile component
                          by harp
                          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                          06-23-2025, 02:01 PM
                        • chth96
                          Is it possible bridging tiny broken trace
                          by chth96
                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                          cutting tiny trace.
                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                          12-03-2022, 11:32 PM
                        • Ven
                          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                          by Ven
                          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                          07-08-2024, 09:32 AM
                        • Delicieuxz
                          I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                          by Delicieuxz
                          I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                          Here's an audio clip of the sound coming from my speakers:
                          https://vocaroo.com/16HaryHwTx78
                          I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                          11-15-2023, 09:50 PM
