Maxtor 6Y080L0 only works in one system.
  • Logistics
    • Apr 2007
    • 721
    I keep trying to swap my dads hard drive into another system, but it just sits at a blinking cursor when it comes time to begin loading Windows in any other system besides the HP its sitting in. Is this some sort of strange security measure?
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Maxtor 6Y080L0 only works in one system.
    Is the drive not accessible in the other systems, or does Windows just not load? Have you tried forcing SATA I?
    • Logistics
      • Apr 2007
      • 721
      It's an ata drive. I put the drive in a different 478 system and then my 604 based server and both just do the blinky cursor when I should be loading Windows.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        You can't just move Windows to another computer. You have to re install it.
        • cheapie
          null
          • Jul 2010
          • 849
          So you can access it from a different computer, you just can't boot from it?
          • Logistics
            • Apr 2007
            • 721
            That's the way I've always done things, and yet my paps has done this a few times. Technically, since 95 you're supposed to be able to just swap. But since I don't consider this clean, I always format and reinstall.
            I'm not sure if I can access it in a different system as I haven't put it in a system with an up and running OS, but i definitely can't boot from it in a different system.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Clear the MBR.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Logistics
                • Apr 2007
                • 721
                I'm trying to keep it untouched. I would throw mbrwizard at it if I was starting fresh
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3266
                  • Singapore
                  exactly what version of windows is in there? from the size of the hard disk im guessing its either windows 2000 or xp.
                  if its winxp in there, ditto. esp the oem ones. booting it on a different machine *might* also mess up the WPA. your copy of windows might just end up being deactivated by m$ if they detect that copy of windows is being used on a different computer it was installed on.
                  the proper way to do it is to boot a linux distro off a live cd (ubuntu etc.) or mini-xp from hiren's boot cd.
                  if its the ancient dos kernel based windows os-es like 95/98/me yes. but if its the winnt kernel based os-es like 2000/xp, no, it does not necessarily work that way.
                  • Logistics
                    • Apr 2007
                    • 721
                    True, it doesn't always work, and in my experience it usually doesn't... at least not cleanly. But I would expect Windows to at least try to boot, to get errors and fail, but not get a blinking cursor.
                    Oh, well it will just give me a good excuse to let him tool around on his new 478-based system he just got for free so I can keep my Dual Xeon rig, which I just found out has two 3.2GHz 1MB L3 Gallatins, which I was going to order for it because I thought I had the regular ones with 1MB L2.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      was the drive autodetected in the original box or a oddball chs setting?
                      i run into this on old stuff all the time.
                      • Logistics
                        • Apr 2007
                        • 721
                        It's hard to imagine it being anything, but auto-detected in a P4, but that's a good question, and ill check. Thank you.
                        • Spitz
                          • Oct 2010
                          • 95
                          It depends on the cpu and chipset of the two boards. I think what you are seeing is the hard drive controller drivers of the first board are not compatible with the drivers of the other boards. If you have the windows disk, you could boot on it and do a windows repair. The second option is to put it back in the original system and change the hard drive controller drivers to the standard drivers that come with windows, and then when you put it in the other system it will trigger plug & play to load the correct driver. The third and best option is to reload windows from scratch and reload all programs and data.
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            no you cant really swap drives like that. the only drive swap that was successfully was from and old dell optiplex with a slower p4 to a newer dell optiplex with a faster p4(from on with a xp home key to an xp pro key) with no problem.
                            and then there is LINUX where you can swap the same HDD from different machine to different machine to different machine 20 times then back to the origin machine and it runs fine on all of them!
                            Follow the white rabbit.
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              is the jumper set to CS? some systems don't like some hard drives CS
                              also, you can't spell 6Y080L0 without YOLO. Just saying, it might be an asshole drive.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Whew, I'm not the only one who saw this!
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  /\ wow
                                  • Logistics
                                    • Apr 2007
                                    • 721
                                    That is good info. I appreciate that, actually. And I am with you as far as a clean install. Soon as Paps saves his data, I'm gonna wipe the MBR on that drive and low-level it; start fresh. Probably, align it with Paragon while I'm at it.
                                    • seanc
                                      • Nov 2008
                                      • 1319
                                      Try the MBR, but before you do, put it into the original system and install the disk controller drivers for the new system, then set the controller drivers to standard IDE, that should ensure you don't get a stop 7B on the new PC.
                                      • Logistics
                                        • Apr 2007
                                        • 721
                                        I finally got around to trying that and it still didn't get anything but a blinking cursor. Oh, well I'll just start fresh. I installed xp on this system with one of my old clunker drives and it ran great. I was going to use the SCSI drive my cousin gave me, but then I realized it was a 15k rpm cheetah and I don't have any drive cooling.
                                        • CapLeaker
                                          Dell ATX PSU won’t start, but forcing it works fine?
                                          by CapLeaker
                                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                          10-28-2024, 06:59 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ex250
                                          Kenwood SW-505D no sound issue and pops from time to time when it works
                                          by ex250
                                          Hello mates,
                                          I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                          It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                          12-29-2024, 03:27 PM
                                        • eurowill
                                          a2141 820-01700 internal display not working / external works
                                          by eurowill
                                          Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
                                          Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
                                          07-23-2024, 10:06 AM
                                        • vf fa
                                          EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                                          by vf fa
                                          Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                                          I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                                          So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                                          01-31-2024, 01:40 PM
