Computer fan noise and maintenance
  • Cableaddict
    • Nov 2016
    • 8
    Re: Computer fan noise and maintenance
    Originally posted by tazwegion
    I'm curious has anyone tried a dry lubricant like graphite powder (or the superior) Molybdenum disulfide powder (Chemical symbol=MoS2) to lubricate these case fans?
    I've thought about it, but figure the powder might not stay for ong.
    I've used Tri-Flow a few times, and so far it seems to work great. It bonds to metal surfaces, so won't fly off like powder might, it's super-light, and it doesn't attract dust.
    The problem with a noisy fan is getting the dirt / dust OUT, first. I dunno what's best, though I've used WD40.
      • 31201
      wash them in the sink.
      then re-lube them.
      • 999999999
        • Sep 2006
        • 774
        Graphite is cheap, if it worked then that's what fan manufacturers would use from the factory.
        Practically all of the sleeve bearing type use a sintered bronze bearing which has pores in it. Due to this you want a thin oil base that is absorbed into the pores, and a longer chain grease suspended to make up for the excess play and keep the oil in place so more of it has a chance to soak in.
        No fancy lubricant additive is needed. It merely needs to keep the shaft from wobbling around, pumping out the lubricant once there is wear, and to absorb enough that it doesn't dry out soon which was the problem in the first place.
        Some bearing may be impregnated with a very small % of graphite, but in that case the pores remain, while if you start adding too many solids to the lubricant it can clump and clog them. The same is true of too much grease. That won't keep the fan from working fine but it will run out of available lubricant sooner. On the other hand if the fan has a well sealing rubber plug, you can put a lot more lube in with that to hold the reservoir and it may not completely run out for quite a long time regardless of the above.
          master hoarder
          • May 2008
          • 12175
          #124
          then re-lube them.
          Wouldn't that cause rust to build up on the stator over time, though?
          I've never had to wash any of my fans, even the really gross ones I found. Usually, I just take them apart and clean the rotor blades with a damp paper towel. For really dirty fans, I use alcohol afterwards.
            • 31201
            no, because after you wash it you remove the clip and extract the blade assembly etc.
            then dry it out - i use a fan heater.
            you could strip it first, but i dont want to get all that dirt on me.
              master hoarder
              • May 2008
              • 12175
              #126
              Ah, I see.
              I personally hate "wasting" too much energy on these things, so I always let things dry in the sun instead. Last June, we had one day where it was so hot here that I had a motherboard dry in 20 minutes after washing. After 1 hour in the sun, I could barely hold it - it was over 50°C. I guess that is one good outcome of the dark-colored PCBs that are popular these days.
              Meh. By the time I get to the fans (be it in a PSU or not), my hand are already super dirty anyways.
              • 999999999
                • Sep 2006
                • 774
                I've washed fans before just to get gunk like tobacco tar off the blades and frame, and didn't disassemble them at all, just shook excess water out and set them over a HVAC register if I was in a hurry or just sitting on a shelf if I wasn't.
                The main thing was to just wait until I felt they were dry before applying power. Never had a problem doing that, though I didn't leave them soaking in water, just sprayed Mr. Clean on them and a toothbrush to loosen gunk, then a brief rinse under tap water. FYI Mr Clean is a lot better at getting old tobacco tar off than the typical off the shelf detergents, even if it's so bad that it looks like the prior system owner must have set their ash tray right in front of the system.
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  #128
                  I think this method is the best and i usually do the same .. Disassembling a fan can kill it for good .
                    master hoarder
                    • May 2008
                    • 12175
                    #129
                    Only if one is careless.
                    I find that I often need to take sleeve bearing fans apart for oiling anyways. Most sleeve bearing fans are not properly oiled from the factory, especially the cheap ones. Adding a drop of oil on the back is not good enough.
                    For example, I just recently took apart an 80 mm fan from an Antec PSU with very little use. The fan seemed to have lots of grease/oil in the back, but it sounded a bit "dry" to me when I spun it. After taking it apart, I found that there was barely any oil towards the front of the sleeve bearing, and hence why the fan was noisy. I cleaned the shaft and bearing from the old oil/grease mix and put fresh oil in there. The fan in that Antec PSU sounds even more quiet now.
                    So in many occasions (but especially with sleeve bearing fans), it is better to take apart the fan fully, clean it, and then oil it. Also, some fans you just have to take apart because it's not easy to find replacements (or it is, but it takes a while for them to get shipped). So I take apart fans all the time. Never damaged one.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      I dont oil fans, I grease them. Hotwash in a sink after disassembling, blast dry with air compressor. Some ball bearings may not get clean with just soap if the original grease has hardened and gotten crusty, these need to be removed from the sleeve and soaked in Brakeleen. Don't get brakeleen on the plastic, it will melt it. Then pack the bearings (or bushing sleeves) with ZEP2000 spray grease. A can of this isn't cheap, but its awesome! Well worth the price.
                      The key for a long quiet life after repacking them is replacing the dust seal sticker...most the time once you peel it off, it won't stick again. go get some Gorilla tape (a very potent duct tape), cut it in a circle the size of the old sticker. Then clean the sticking surface on the back of the fan with alcohol on a rag, and put the tape on. it won't come off. I've got some fans 10+ years old running quiet 24/7/365 after doing this.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #131
                        ^this
                        And if you want to keep the original sticker, clean the remaining adhesive off with a solvent, and then use rubber cement to stick it back on over the rubber seal.
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          #132
                          Yes Momaka , disassembling a fan can kill it only if one is careless , that's what i intended to say . I always speak from my experiences , and in this case , i was thinking of a scrooge client who , insisted on cleaning a fan himself in a Hp Icore 7 . I told him i can sell you a new fan or i recommend me cleaning it . He didn't listen , and the lap is right here with a burnt motherboard .
                          • Drack
                            Yup it's me
                            • Nov 2016
                            • 297
                            • Venezuela
                            #133
                            I use hydraulic oil, 2 drops when the fan is not making weird sound and they just last a lot, even cheap sleeve bearing fans, I do that once a year and check if the fans have enough oil when I bought them, grease don't work that well for me at least, the fans don't die but sounds like a Chinese car (Cherry qq lol)
                            • 999999999
                              • Sep 2006
                              • 774
                              Unfortunately I'm finding more and more cheap fans that are permanently sealed, no lube bung and have some kind of press-fit assembly. Some are even semi-popular brands like Coolermaster and otherwise appear to be fair quality for their low price.
                              Some day if I get bored enough I might try drilling a little hole to lube one, but I have plenty of other fans so am in no rush to bother.
                              • Drack
                                Yup it's me
                                • Nov 2016
                                • 297
                                • Venezuela
                                #135
                                Already did it, worked ok, for an Intel fan, it lost one pressure metal bung or something like that but it has been working for a year since then
                                • BadCon
                                  • Jan 2017
                                  • 16
                                  • Croatia
                                  #136
                                  I found Arctic fans (their patented FDB bearings) is what I think sealed. I dissasemble them using force to remove blades from frame, clean it and put a drop or two of oil on fan shaft. Push it back altogether and works fine. Is that a proper way to relubricate them or that kind of fans should not be dissasembled (as I read that FDB should not be changed?).
                                  Originally posted by davmax
                                  How can PC fans be maintained? (bearings, lubrication, cleaning off dust & particulates)...
                                  For lubrication I use a synthetic oil 10-50 grade, it is thin and will not gum up or evaporate.
                                  Recently a 135mm fan (I suppose ball bearing, because PSU is good quality FSP made) in my PSU start to make annoying noises, so I cleaned it and lube with a 2t motor oil as I was unable to find 4t engine oil I used to lube before. Fan is silent and no annoing noise anymore.
                                  Now I'm asking is two stroke motor oil good to lube ball bearing fans? What about sleeve bearing ones? If its bad to use and I'll have problems afterwards, I'll clean the fan and lube with another type of oil.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #137
                                    I have a few of those well - already drilled out too. Not that hard to do, but annoying indeed compared to "normal" fans with rubber plugs.
                                    Well, if this method works and the fan lives long enough, then I guess it could be considered "proper" .
                                    Originally posted by Drack
                                    ... the fans don't die but sounds like a Chinese car (Cherry qq lol)
                                    Oh no, you have those where you live?!? Last time I saw crash test videos of those, they didn't fare well at all - about as bad as a Trabant and Pinto, if not worse.
                                    • RukyCon
                                      A Fake Rubycon
                                      • Jan 2017
                                      • 816
                                      i have 2 cheep PC fans i use while i'm soldering one is a blue LED fan the other is a standard PC fan both of them are 120mm x 25mm
                                      but the blue one has started to make a clicking sound
                                      and i know it's because it's a cheap fan from Ebay
                                      and the reason i chose Ebay is because i was on a tight budget at the time and they were less then $3ea but now i can get better ones if i wanted to but i not going to yet because the old ones still work
                                      I'm not a expert, I'm just doing my best.
                                      • Drack
                                        Yup it's me
                                        • Nov 2016
                                        • 297
                                        • Venezuela
                                        #139
                                        Momaka, they are everywhere over here, but we do not own one of those, I imagine they are like that, they are as light as a gutless wonder
                                        • BadCon
                                          • Jan 2017
                                          • 16
                                          • Croatia
                                          #140
                                          Now I'm asking is two stroke motor oil good to lube ball bearing fans? What about sleeve bearing ones?..
                                          I'm sorry for 'bumping' my own post but I'm a little worried about this one (that 2t oil will gum up unlike 4t oil?), I dont want to damage 135mm fan which is hard to find/replace replace (there is not a single one 135mm in local stores). Thanks.
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • stvhop
                                            HP1955L Buzzing noise & interference
                                            by stvhop
                                            Hello, This is my first post so please forgive me if I miss out some vital info.
                                            I have a problem with my HP1955L monitor from 2005.
                                            The first thing to say is that it is still basically working, ie the picture is fine.
                                            However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                                            The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                                            11-07-2020, 07:13 AM
                                          • tony359
                                            by tony359
                                            11-28-2023, 05:18 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • b-slayer
                                            Asus Strix-G15-G513RM fans don't work
                                            by b-slayer
                                            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                            09-04-2025, 04:58 AM
