Computer fan noise and maintenance
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    #161
    Re: Computer fan noise and maintenance
    Originally posted by momaka
    Well, it certainly is nice when you have that option.
    I had to fix two small fans today - 40 and 50 mm. Both are ball-bearing fans with very noisy and dry bearings. They both spun fine, but the noise they made was terrible. A few drops of oil made them a lot more quiet. Definitely not perfect, but much better than before.
    Yes, I can buy cheap replacement fans on eBay, but it would take forever for them to get here and who knows how long they will last. And if I were to buy high-quality fans, that would probably cost more than what the video card and the motherboard these came out of are worth.
    So sometimes you have to work with what you have on hand and do your best to fix it right.
    Oh yes Momaka , sometimes you have to work with what you have on hand and do your best to fix it right , but here , it seems it is the most busy season of all seasons my friend . I'm doing my best to keep honesty in repair's time delivery .. But not much sad , money is flowing good , lol .
    By the way , which kind of Oil you use Momaka ? , any brands , labels ?
    • shakyshee
      • Oct 2017
      I haven't done any major maintenance to my fan aside from sweeping off the dust in it. What I do is keep it from exceeding its maximum performance, and if I have to do so, I also keep it cool as much as possible — there are some background running apps that can be closed for you to maximize the efficiency of your pc.
      • emil_t
        RTX3090 working fine but fans not spinning
        by emil_t
        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
        04-12-2024, 06:54 AM
      • stvhop
        HP1955L Buzzing noise & interference
        by stvhop
        Hello, This is my first post so please forgive me if I miss out some vital info.
        I have a problem with my HP1955L monitor from 2005.
        The first thing to say is that it is still basically working, ie the picture is fine.
        However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
        The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
        11-07-2020, 07:13 AM
      • tony359
        by tony359
        11-28-2023, 05:18 AM
      • MegaZAC
        Onkyo TX-SR805 noise in one channel
        by MegaZAC
        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
        There's some logic behind it. As soon as I select an input I get only left...
        04-23-2025, 10:09 PM
      • b-slayer
        Asus Strix-G15-G513RM fans don't work
        by b-slayer
        I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
        The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
        (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
        (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
        ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
        09-04-2025, 04:58 AM
