Computer fan noise and maintenance
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    #141
    Re: Computer fan noise and maintenance
    My hp Icore7 fan is really getting on my nerves , it now sounds like a harley davidson , lol . Around midnight , Some neighbors already complaining , and this is an original and new one . What can i say ? , i told them it is a heater with a powerful fan as it's very cold at nights now .Hey HP , why don't you do something good anymore ? , lool ...
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      a pc fan i have has lost a blade do to it falling off my table [it's the same one i use while i'm soldering]
      so i'm going to need a new one
      I'm not a expert, I'm just doing my best.
      • Drack
        Yup it's me
        • Nov 2016
        • 297
        • Venezuela
        #143
        Super glue it!
        I use ATM oil as I said, it works perfectly
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16951
          I tend not to use oils. They will always run off or evaporate. For the long haul, a good grease is the only way.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            I can not find the blade at all.
            Tho it was a cheap fan anyway. [price 2.58$]
            • Drack
              Yup it's me
              • Nov 2016
              • 297
              • Venezuela
              #146
              Lol, my fans, have had that oil for one year, it's still there, working ok
              • Drack
                Yup it's me
                • Nov 2016
                • 297
                • Venezuela
                #147
                I have bought fans for 80 cents, and those have lasted a while(5/6 years)
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  I'm waiting for the fans at HSC to go on sale again.
                    master hoarder
                    • May 2008
                    • 12160
                    #149
                    Some people swear by oil, others by grease.
                    I think it really depends on what kind of grease/oil one uses and also the quality.
                    For grease, I would NEVER use regular grease, as that is the stuff that dries rather very quickly. Good quality Lithium grease (the white stuff typically used on gears), on the other hand, could probably be used and wouldn't not dry in a very long time.
                    So I think it really depends on the quality and type of grease/oil used.
                    I personally have cheap fans that are over 10 years old that I oiled with regular engine oil, and they still work fine to this day (no, not in 24/7 operation, as I don't run any of my computers 24/7). The oil in them is not dry yet - I've checked recently.
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      Is it possible to fix the clicking sound that's coming from one of my fans.
                        master hoarder
                        • May 2008
                        • 12160
                        #151
                        If it's a ball bearing fan, then probably not. I have a BB CPU fan that does it and even after I put oil in the bearing, it still does. Also have two other fans with BB, and they are noisy simply because the bearings are very worn - nothing that can be fixed with oil or grease. They just need new bearings.
                        On the other hand, if your fan is sleeve bearing, then YES, lubing the fan should stop that noise. If the noise persists, you need to fully take apart the fan and clean the sleeve bearing, then put oil or grease in it (again, this will depend on preferences here), then close it back together.
                        • RukyCon
                          A Fake Rubycon
                          • Jan 2017
                          • 816
                          How can i tell of it's a ball bearing fan or a sleeve bearing fan?
                          With the fan i have the casing is transparent so i can see the motor inside. I can take photos if you need any.
                          • Drack
                            Yup it's me
                            • Nov 2016
                            • 297
                            • Venezuela
                            #153
                            Probably a sleeve bearing, put a bit of oil and see if it is quieter.
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              What type/brand should i use?
                              This is my first time doing this.
                              • Drack
                                Yup it's me
                                • Nov 2016
                                • 297
                                • Venezuela
                                #155
                                I use ATF oil or motor oil two drops and it should be a bit more silent, is not going to be like new but it will be better
                                • jiroy
                                  • Jun 2016
                                  • 2416
                                  • Lebanon
                                  #156
                                  Until Topcat and Momaka reach an agreement on what's better , Grease or Oil , i'll order another new fan from HP , ...
                                  • Drack
                                    Yup it's me
                                    • Nov 2016
                                    • 297
                                    • Venezuela
                                    #157
                                    Oil FTW!
                                      master hoarder
                                      • May 2008
                                      • 12160
                                      #158
                                      Well, it certainly is nice when you have that option.
                                      I had to fix two small fans today - 40 and 50 mm. Both are ball-bearing fans with very noisy and dry bearings. They both spun fine, but the noise they made was terrible. A few drops of oil made them a lot more quiet. Definitely not perfect, but much better than before.
                                      Yes, I can buy cheap replacement fans on eBay, but it would take forever for them to get here and who knows how long they will last. And if I were to buy high-quality fans, that would probably cost more than what the video card and the motherboard these came out of are worth.
                                      So sometimes you have to work with what you have on hand and do your best to fix it right.
                                      • Drack
                                        Yup it's me
                                        • Nov 2016
                                        • 297
                                        • Venezuela
                                        #159
                                        Just fixed and industrial fan with sleeve bearing,
                                        The grease was dry and that made the fan spun sloooooooow, disassemble it cleaned the grease put ATF oil and like new, it didn't have much use so no damages on the bearing
                                        • RukyCon
                                          A Fake Rubycon
                                          • Jan 2017
                                          • 816
                                          Do i have to open up the fan to put oil in?
                                          And the blue LED fan i have looks like it had oil/grease in it but it looks like it all dried up.
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • stvhop
                                            HP1955L Buzzing noise & interference
                                            by stvhop
                                            Hello, This is my first post so please forgive me if I miss out some vital info.
                                            I have a problem with my HP1955L monitor from 2005.
                                            The first thing to say is that it is still basically working, ie the picture is fine.
                                            However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                                            The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                                            11-07-2020, 07:13 AM
                                          • tony359
                                            by tony359
                                            11-28-2023, 05:18 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • bulkchart32
                                            i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
                                            by bulkchart32
                                            i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
                                            Today, 02:37 AM
