fancy heatsink
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    fancy heatsink
    didnt want us to forget who named it!.
    wonder what the extrusion die for this cost?
  • SuperDuty
    • Mar 2011
    • 299
    • France
    Re: fancy heatsink
    I have a Radeon 9250 with this heatsink. They were common on their retail low end cards : Radeon 9200, GeForce FX5200. The OEM ones didn't get the cool heatsink.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Re: fancy heatsink
      is that an mx4000? I think I had the same one at one time
      • c_hegge
        • Sep 2009
        • 5219
        Re: fancy heatsink
        I've seen that heaps of times. Abit motherboards sometimes had ABIT shaped fins (http://www.hardwareinsights.com/wp/p...tually-work/4/)
        • larrymoencurly
          • Oct 2004
          • 960
          Re: fancy heatsink
          I have an MSI Radeon 9550 card like that and its clone from Gigabyte, which has a plain looking heatsink.
          Here's an MSI Big Bang XPower motherboard with one heatsink that looks like bullets and another that resembles a gatling gun. 98% of the buyers also bought truck nuts.
          • harp
            Metod for removing glued heatsink from fragile component
            by harp
            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
            06-23-2025, 02:01 PM
          • Ven
            Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
            by Ven
            I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
            The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
            I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
            If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
            07-08-2024, 09:32 AM
          • piernov
            Core 2 "gaming" build with SLI
            by piernov
            My turn to post a build I guess, wasted way too much time on this one…
            First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
            Everything done with random parts I had lying around.
            Specs :
            • CPU: Core 2 Quad Q9450
            • RAM: 2x2GB KHX6400D2K2
            • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
            • MB: P5N-E SLI
            • PSU: Antec Basiq Power 550 Plus
            • HDD: Hitachi Ultrastar A7K2000 1TB
            • ODDs: DVD ROM, DVD RW
            • Case: not sure
            Cooling:
            • 92mm rear fan
            • 120mm front fan
            • Additional heatsink on southbridge
            05-20-2023, 11:38 AM
          • harp
            can fanless heatsink replace poor original on RX26PG2
            by harp
            I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
            06-25-2025, 10:56 AM
          • nobbnobb1
            Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Question
            by nobbnobb1
            I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
            There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor....
            09-08-2022, 09:58 PM
