The hard drive failure thread
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #81
    Re: The hard drive failure thread
    Perhaps smartmontools?
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • diif
      • Feb 2014
      • 6978
      • England
      #82
      Anybody know what this thing is ? It's not my identical board but the device looks similar. is it a fuse for the motor ? It had the marking 2E H
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Is it a shock sensor?
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          #84
          yes.
          http://www.hgst.com/tech/techlib.nsf...Drop_proof.pdf
          Follow the white rabbit.
          • diif
            • Feb 2014
            • 6978
            • England
            #85
            Thanks guys, it was broken on a drive i had on my bench.
            I'll see if i have another dead board and transplant it.
            • Ascaris
              • Nov 2015
              • 54
              I've had pretty good results with the scores of hard drives I have owned over the years. Most of the failures have been laptop drives... I'm guessing because the lack of ventilation tends to make them run hotter than their desktop counterparts. Nearly all of the drive replacements have been because of obsolescence rather than failure.
              One of them is a 250GB laptop drive that was originally inside a WD Passport enclosure (WD2500BEVS drive p/n), which I used for backup purposes years ago, before my backup set became much larger than it could hold. It has low hours (only 378) and reports as healthy in SMART when the computer can see it. Sometimes it just doesn't respond at all when I plug it into my USB3 to SATA adapter and plug that into my PC. No device connected sound, no listing in diskmgmt.msc. And then it just decides to work the next time I plug it in!
              I replaced the OEM hard drive (another Western Digital 250gb WD2500BEVS) in my Asus F8Sp laptop several years ago. As I am a pack rat, I kept the old drive, and I have it plugged into my PC via the aforementioned SATA to USB3 adapter now, and it's working fine, other than having 1 pending sector in the SMART data. WD's Data Lifeguard utlity says the drive is healthy, and I am not really sure why I replaced it all those years ago. The pending sector has been at 1 forever, and reallocated is still at 0, so I would now be inclined to watch and wait (and keep backups, but I do that anyway). That drive has a touch over 14,500 power-on hours on it (and all but ten or twenty have been in the laptop).
              I replaced that one with a Seagate 500gb/7200 RPM (ST9500420AS). After I rediscovered that old laptop (as a focus of interest... I never forgot I owned it) a few months ago and decided to upgrade from the Windows XP that was still on it, I noticed I'd had that little drive in service for 28,000 power-on hours, and without a single hiccup. No reallocated sectors or any sign of failure, and this was on a laptop drive that was hot for most of its life in the poorly-ventilated F8Sp (45C temps were normal).
              I even called Seagate and gave them the serial number so they could verify the manufacturing date on it... it was nearly five years old, they told me, and still under warranty (I do recall having bought the Seagate because of the warranty back then, before the warranties fell to a year or two across much of the industry). No need for RMA, I told them; it was working just fine, and I was just curious to know how old it was. I was so impressed with the little Seagate that I posted about it on Newegg.
              So then I began the process of reinstalling Vista from a drive image I'd made when the laptop was fresh out of the box before downgrading to XP (on an 80GB PATA Maxtor Diamondmax 3.5" drive, currently in a USB 2.0 external enclosure with a bulging Suncap capacitor-- despite that, it worked fine to get the data onto another hard drive). As soon as the umpteen cycles of update, reboot, update were completed, but before I reinstalled all my stuff on it, I decided to try 7 out instead to see if I could get everything working... and as soon as I got it all set up with 7 x86 and verified it was going to work (but not activated yet), I decided to add more memory and go for the 64 bit edition of 7. Started all over...
              In the process of all of that (before it was all done), the little Seagate... died. Unceremoniously and without warning, Windows froze on the laptop. I don't recall exactly what happened when I tried to reboot it, but it didn't make it into Windows again. Fortunately, I am a fanatic when it comes to backups, and I had drive images of every step along the way as I was going through the process, so I would not have to redo all my work again.
              I took the drive out and attached it to my USB3 to SATA cable and did the Seatools diagnostic on it. Failed the short test, failed the long test... could not make it through an attempt to mark the bad sectors and get the drive back into a state of usability.
              The drive went back to Seagate (in its original box, which I had kept), and I was a little nervous about trusting a refurb drive, which I know is what they would send, so I bought a WD Black 750MB for the laptop.
              I got the refurb Seagate drive back as expected, and it is currently the boot device for my sorta-NAS pc (which is cobbled together from leftover stuff, like having a laptop drive in a desktop). All the important data on that PC is on a separate physical hard drive.
              I still think the Seagate did a great job, even if it did die right after I lauded it for not dying for so long. 28k hours power on time in 5 years is 64% duty cycle, and with the kinds of temps you see in laptops (especially after the stock TIM hardened and stopped working, before I finally got tired of the fan being on full speed all the time and fixed it).
              Part of the reason for the long hours on the drive was that I had the laptop doing phone sentry duty for a while, running 24 hours a day. I've been slammed with bill collector calls looking for people I've never met for years, and I had the laptop running PhoneTray and blocking them.
              Other older drives I have that are not dead include a WD Caviar SE 160 GB 3.5" (WD1600AAJS, unknown hours) and a Hitachi 640 GB 3.5" (HDT721064SLA360, 27k hours, healthy but with 11 reallocated sectors that have been that way a long time). I know, you asked for failures, but maybe it's relevant to report older drives that still work!
              • fzabkar
                • Mar 2009
                • 772
                This article is a useful primer:
                http://hddscan.com/doc/HDD_from_inside.html
                Murata piezoelectric ceramic shock sensors:
                https://cdn.badcaps-static.com/pdfs/...4bed671192.pdf
                • mariushm
                  • May 2011
                  • 3799
                  #88
                  My oldest installed drive is a 1TB WD Black with 44463 hours (and only 288 start/stop count) - I like to keep my computer running 24/7. That's about 5 years of almost uninterrupted operation.
                  It has a value of 8 for current pending sector count but the drive works perfectly.
                  My next oldest drive is a 2 TB Seagate, with 40970 hours (and 179 start/stop count) .. but this one had a "failure" some time ago, there's an area which is loaded with bad sectors so i basically isolated that section of the drive in a partition that I left unformatted. The rest of the drive (about 1.4 TB) works perfectly still.. and it's months since that failure started to manifest itself)
                  • Gabriel
                    • Jan 2010
                    • 620
                    • Norway
                    #89
                    Had a check on my wd green - WD10EACS, so far it's done 39080 hours and still running just fine.
                    That's my oldest drive, never thought it would last for so long
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3264
                      • Singapore
                      #90
                      lately, i had one out of a lot of five hitachi p7k500 500gb ide drives i got off trashbay fail on me during testing. first sign something was wrong was during power on. the drive seems to vibrate quite badly so much so that it made the hard drive cage fan rattle! unplugged all other drives to make sure it wasnt the other drives and also checked the screws to make sure its securely mounted as well as the fan. the other drives when run individually dont vibrate as much as that one until the hard drive cage fan rattles!
                      next, booted up hiren's boot cd on a live session of mini-xp to run the victoria hard drive testing program and hdtune benchmark. the hdtune benchmark graph was really fugly. the transfer rate spiked up and down all over the place from 0.1mb/s to 70mb/s. replaced cable, tried different ide channels to no avail. doesnt look like ide cable problems as there are no ultra dma crc errors in the smart data. what was telling was the normalized value for raw read error rate. the raw data value is useless and not exactly useful as its normal for a hard disk to hiccup once in awhile but having a low or decreasing statistical normalized value means a chronic problem with reading from the drive. the normalized value was 80 then.
                      i then proceeded with a surface scan trying to read every sector. scan found 3 unreadable sectors and the normalized and worst value for raw read error rate deteriorated to 60! next, i tried a write scan by writing lba numbers to the drive. that caused the drive to reallocate 3 sectors. i now have 3 sectors in the reallocated sector count and event count. furthermore, the write scan took unusually long at 6 hours to complete. it shouldnt have taken longer than 3-4 hours.
                      i also noticed that this live session of mini-xp started to stutter after the overnight write scan. strange... also, i have something like 200-300 slow sectors that take >600ms to be readable/writeable. i think im going to try to make the drive reallocate the slow sectors with >500ms response time using victoria.
                      going by momaka's advice, i would try to see if the bad sector count can stabilise and see if there are no more increases in bad sector count because this drive is actually quite "young". it has only around 4400 power on hours. in addition, its an ide drive which is no longer being made, so ima see if i can salvage or stopgap the drive instead of just chucking it. if it was a sata drive, i would have instantly just trashed it and used the drive for frisbee! wheeee...
                      anyway, contacted the seller on ebay with a screenshot of the proof with the victoria smart data showing the reallocated sectors. seller agreed a refund for the one unit because it costs US$50 to ship things back to the usa here. doesnt make sense to ship something back that costs less than the shipping cost itself. much less paying so much to get back something that is faulty.
                      lastly, if even a live session of windows can stutter when its not even the system drive that is bad, it shows evidence is really crappy coding by m$. no wonder all the good data recovery programs are on linux or run off a boot disk or cd!
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #91
                        Might not make it too far if its vibrating excessively. But once you move your important data off of it, try it and see what happens. Generally speaking, though, desktop use won't put much stress on the HDD (especially if it's a secondary drive). However, if you want to see whether or not it really would make it (and possibly get beaten to death), then do a zero-fill / low-level format twice on it. If the sector count doesn't increase considerably after the first pass and stays the same after the second pass, it should be stable and okay to use.
                        Also, I hope Hitachi uses the spin-up retries entry here for some different data. Otherwise, that could be indicating a dying spindle motor or that the heads were stuck on the platters at some point. Both of these are usually terminal issues.
                        A 500 GB Seagate ST3500620AS of mine is like that. Actually worse. If I do a read scan, it will take hours to get through even a 10th of the drive's capacity and many sectors will show as red in HDTune. For some reason though, the HDD would drop out and thus not mark the sector as bad. So I was never able to complete a full scan on it. Decided to not mess with it and stuck it in an experimental PC that I use for games only. It's been almost 2 years since I've had it in there. Bad sector count has gone up only by 3: from 741 to 744 bad sectors . But as PhotonicInduction would say, "I ain't having it", so I will continue to use it until it croaks on me.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4958
                          • New Zealand
                          #92
                          If it vibrates excessively, something is wrong with it, regardless of whether or not there are bad sectors.
                          You can get SATA to IDE adapters... http://www.satacables.com/html/sata_to_ide_adapter.html so who cares?
                          -David VanHorn
                          • fzabkar
                            • Mar 2009
                            • 772
                            Seagate's drives have a serial diagnostic interface. You can test the resistances of the heads, dump the defect lists, and much more.
                            http://ts.acelaboratory.com/index.ph...est-seagate-f3
                            Note that the above procedure applies only to F3 architecture models (those that give an F3 prompt). Also be aware that lowercase is not always kewl. Typing commands using the wrong case can result in disaster. Also, you must be at the correct level, eg T or 7. The same command issued at different levels will produce disastrously different results.
                            • ChaosLegionnaire
                              HC Overclocker
                              • Jul 2012
                              • 3264
                              • Singapore
                              #94
                              ooops i forgot to mention that if a hard drive can fail in so many different ways aside from the traditional click-click-click of death we are so familiar with, personally i think hard drives deserve to become obsolescent and be replaced with something else better. its just such a complex, precise and highly sensitive instrument that there are just way too many scenarios for things to go wrong with it...
                              • Compgeke
                                • Feb 2014
                                • 524
                                Spinning rust does have two operation modes: failing and failed.
                                SSDs are getting to the point they'll probably outlive the average platter drive however they're still quite expensive for the same capacity. Keeping backups on more than one format in more than one place is the best for anything important.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4958
                                  • New Zealand
                                  #96
                                  The same goes for any storage device really, and in fact, all forms of computer hardware. Arguably it also applies to the entire known universe...
                                  SSDs are not significantly better than anything else in the long run.
                                  -David VanHorn
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3264
                                    • Singapore
                                    #97
                                    argg! i think that heavily vibrating hitachi p7k500 500gb is a bust. tried doing a write scan again and this time 250+ bad sectors popped up! however, the bad/slow sectors appear to be towards the end of the drive starting at around the 375gb mark. the beginning of the drive appears to be more or less fine. guess that drive will be relegated for testing purposes and os install testing only...
                                    that aside, i also want to talk about a hitachi micro hard drive failure in a 1.5gb creative muvo² portable mp3 player that occured several years ago. i bought that mp3 player in 2002 or 2003 during my national service days to kill time during slow days when i didnt have any ambulance calls.
                                    the mp3 player served me well waay past my service until 2010, when it started to accumulate one too many drops to the ground by that time. i put the player in my shirt pocket and everytime i bend down to adjust/put on my socks or shoes or to pick stuff up off the ground, the player would sometimes fall out of my shirt pocket and onto the ground. first sign that the micro hard drive was failing was some slight clicking noises and skipping during playback. it suffered a few more drops until one day, it just refused to finish booting up on power on. player hung at the creative boot screen with a constant clicking coming from the micro hard drive. guess this should be in the dumbest electronic mistake thread as well...
                                    i had my music collection on my pc so no loss there. what i didnt realise when i bought it in 2002/03 tho, was that those hitachi micro hard drives at the time were going for 600-700 bucks alone and the mp3 player that came with the micro hard drive was being sold for only 250-300 bucks. ppl were buying those creative mp3 players and tearing them apart to extract the micro hard drive on the cheap and used them in their other mobile devices like palm pilots etc. didnt realise all this until reading and hearing about it in a comp magazine and hearsay from colleagues who saw my mp3 player sometime in 2004.
                                    makes me feel sad to see good ol' stuff like those costly hitachi micro hard drives kick the bucket from my carelessness at dropping my mp3 player. i was a noob back then and just tossed the mp3 player when it failed. now that i have turned a collector, in hindsight, i should have extracted the failed micro hard drive and just use it for display for posterity. my mp3 player now is a 16gb creative zen x-fi2 which uses flash mem for storage. no more screwing up the player from dropping it anymore. its endured several drops to the ground with no problems aside from more scuff marks... lol~
                                    anyway, im starting to see the benefit of going with flash mem for mobile applications. hard drives are just too fragile to handle the rigors of mobile usage. if hard drives are going to become obsolescent and replaced with something better, its definitely going to start with the mobile arena. hard drives will still persist for fixed position, bulk storage usage tho. ok i will shut up now. this is a forum not a blog...
                                    • ChaosLegionnaire
                                      HC Overclocker
                                      • Jul 2012
                                      • 3264
                                      • Singapore
                                      #98
                                      take a look at the reallocated sector phail from the smart data...
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        #99
                                        Just divide it into several partitions and use only the good ones. That's how I'm still using my 500 GB Seagate ST3500620AS I mentioned above. If the read and write tests are making it reallocate more sectors, but the drive is otherwise functional when you store files on it with your PC, then don't do anymore tests or benchmarks on it. My Seagate above is in the same boat.
                                        That's crazy! I never heard of this.
                                        I still have my Rio Carbon Pearl 6 MP3 player, which has a 6 GB Hitachi micro HDD in it. Actually, when I first bought the MP3 player back in 2006, someone in Best Buy must have dropped it, because it came with a dead HDD straight out of the box. I had to send it in for warranty to get it fixed. Ever since then, it's been running great - granted I put very very little use on it. I still like its design though, despite having only a monochrome screen.
                                        • ChaosLegionnaire
                                          HC Overclocker
                                          • Jul 2012
                                          • 3264
                                          • Singapore
                                          #100
                                          well my wd caviar black 2tb kicked the bucket today. was trying to test a video card i bought on ebay so i booted up the system and while installing the video driver, the system was extremely sluggish copying and installing the files. i thought the sata cable was focking with me again and producing lots of ultra dma crc errors so i fired up crystal disk info to check. the cable was fine. instead i saw "caution" and it had one pending sector in smart, so it looks like the drive is failing.
                                          im on ubuntu now running gnu ddrescue to pull all the data off it. i attached a screenshot of the smart data in linux. note that it has less than a year of poh on it. modern drives these days just dont last! sheesh!
                                          • federalhouse
                                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                            by federalhouse
                                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                            **Background:**
                                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                            **What I've Tried So Far:**
                                            1. I accessed
                                            08-01-2024, 07:03 PM
                                          • tmcw
                                            PC case - Hard drive rails
                                            by tmcw
                                            A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                            So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                            I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                            Now, the case is a CiT Gaming Case, and...
                                            05-22-2022, 12:04 PM
                                          • reformatt
                                            Intel iMacs, 3rd party SSD failures and Fusion setups
                                            by reformatt
                                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                            12-18-2024, 10:34 PM
                                          • madura2010
                                            DAY11AM6E0 hard disk drive and optical disk drive not detected
                                            by madura2010
                                            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                            i checked the connectivity of ribbon=good communication with hard and motherboard
                                            changed hard disk and checked=3f0 error persist
                                            sata power=+5v available
                                            Then checked data capacitors=all good
                                            Then checked data lines path connectivity to pch=all good
                                            reflashed...
                                            03-12-2023, 09:09 AM
                                          • ash91
                                            Hp pavilion 15 not detect hard drive
                                            by ash91
                                            Hello gentelmen .... this is my first post and sorry for my bad english,
                                            so my proplem is my laptop keep losing hard drive even if i but the
                                            hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                            when i turn the laptop on the massage that said no boot media found pop on
                                            the hard disk is fine and to be sure i try another hard
                                            i also update my bios to the last update
                                            the 5 volt is present on the hard connector on the motherboard
                                            the dvd rom work fine when i but a windows dvd in it
                                            also when i boot from flash...
                                            06-07-2023, 01:45 PM
