The hard drive failure thread
Re: The hard drive failure thread
They have no legal ability to do so. You purchase something, it needs to be repaired, you send it in for a repair, and now your warranty is shortened to 90 days after the replacement was issued? Where's the logic behind that?!
HP has a policy that you get an additional 90 days after a repair or replacement, so that even if you RMA the item a day before the warranty is up, you have an additional 90 days after receiving the replacement. Maybe you are thinking of that...Comment
or the warranty database needs to refresh with updated data for your drive.
had brand new seagate drives of a just introduced model that were not in the warranty lookup.when i called the csr stated these were just shipped a few days before and it took a few days to update.
yes i had a doa.Comment
From the point of view of making more profit it is logical, although you are right, it doesn't really make sense, I must have been thinking of something else."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Ok, this clears things up. A link I found on a thread about this exact topic on their forum:
http://wdc.custhelp.com/app/answers/detail/a_id/1058
Once we received the defective drive, the warranty on the replacement drive is updated...
Now to check if I can get a replacement for that nearly brand new Caviar Blue I got out of an Acer where the customer couldn't wait for the RMA so he just paid for a new drive (Another Caviar Blue - yea yea I know... But WD is still the most consistent in my opinion).Comment
I tried to RMA a drive that came from a Seagate NAS, they refused saying taking it out voided the warranty.
WD will probably tell you to take it back to Acer."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
2 640gb toshiba laptop drives.
both less than a year old.1 in a customers laptop with a ton of bad sectors and more in current pending.was very slow.
other in a neighbors laptop.
dropped dead.
no spin.
seagate 7200.11 1tb with bsy bug.was backed up so my neighbor will just rma.
had reallocated sectors and a few current pending before it died.i told him to back it up now.at least he listened!_________________________________________________________________Free Computer Service!!!!!!!!!
If We can´t Fix the problem.Comment
ive got a lot of costumers with WD hardrives and they most of the time have a lot of bad sectors._________________________________________________________________Free Computer Service!!!!!!!!!
I just put a 1 TB SAMSUNG FAILPOINT in my 2006 MacBook, Wish me luckMy Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
I've had too many hard drives die or become too unreliable to use on me. Yes these are all my own disks, not a company or anything... These are the ones I can think of, off the top of my head, there are more...
A lot of these are estimated POH. My current record for power on hours is around 70K and it's still working (120G Maxtor). I really should replace it, it's part of a RAID5 though.
500G Hitachi - Ate as loss - 10000 POH - media failure
500G Hitachi - RMAed - 300 POH - Controller board failure
120G Maxtor - RMAed - 4000 POH - media failure
60G WD - Ate as loss - 20000 POH - Unreliable
30G Quantum - RMAed - 10 POH - bearing failure
20G Hitachi/IBM - Ate as loss - 10000 POH - unreliable/unknown failure
6.4G Maxtor - Ate as loss - est 8000 POH - unknown, then fried with a bad PSU during debug
2G WD - Spared - est 8000 POH - Unreliable (sometimes it works so I use it when needed)
400M Maxtor - Ate as loss - est 5000 POH - unknown failure
330M Seagate - ate as loss - est 6000 POH - killed with bad PSU
260M Seagate - ate as loss - est 6000 POH - unknown failure
40M WD - Ate as loss - est 6000 POH - bearing/media failure
As seen I have all sorts of different HDDs die on me. I'm not going to use that as a reason to never buy a particular brand. They're all going to fail at some point - just get the one with the specs needed and BACKUP, BACKUP, BACKUP.Last edited by eccerr0r; 12-01-2012, 11:55 AM.Comment
I have these in my computer:
ST2000DL003-9VT166 (5YD0W48B) 14740 hours (2 tb drive, g*d knows what series)
WDC WD1002FAEX-00Y9A0 (WD-WCAW30053135) 18272 hours (1 tb drive wd black)
WDC WD20EARS-00MVWB0 (WD-WMAZA3290165) 14369 hours (2 tb , wd green i think)
WDC WD4000AAKS-00YGA0 (WD-WCAS84337477) 37237 hours (400 gb, wd black)
I actually upgraded the computer yesterday with new mb and cpu and memory so took advantage of that to snap some pics and clean the dust.. here you go
Also had a WD Green 1TB that I shipped to the datacenter my servers are at, but I don't have any tool to see the smart info directly.
(knock on wood) Maybe I was lucky, none of my drives have failed in the past, and I had a 640 GB seagate I sold, a 250 GB wd probably I gave to my sister... only a Maxtor 3.2 or 4.2 GB developed bad sectors after 1-2 years of usage.
BUT my system usually runs 24/7, it's powered by a quality psu and kept at decent temperatures.Last edited by mariushm; 12-01-2012, 12:26 PM.Comment
The 2TB Seagate is a Barracuda Green (3 x 667GB, 5900RPM).
In my experience heavier drives (for the same number of platters) are more reliable. The only (somewhat) recent drives I've used are Seagates, and only 1 out of 4 still works. My PC has that drive (ST31000528AS) for A/V (mostly backups of CDs and DVDs, as I'd trust any HDD except a 75GXP/60GXP or slimline Maxtor over them) and 2 x WD800JD-00LSA0 (1 system, 1 data). The backups are asas they get - random old HDDs being plugged in occasionally and the data manually copied over. But I think there's a 97% chance it'll be okay.
Be careful with the new Barracudas... They have head parking which can only be temporarily disabled (Resets on cold boot) with hdparm.Comment
I know a single unverified case is not proof of anything, but note also Seagate released a firmware update for these drives after much complaint from users - and the update only made the heads park in a quieter fashion.
My intense speculation and tentative opinion is, the drives must park heads or somehow end up with bad sectors. Otherwise why did Seagate not just disable the 'feature' completely with the firmware update instead of slightly tweaking the noise?
Makes me suspicious. In any case, time will tell."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
A user on the Seagate forums reported increasing numbers of reallocated sectors on two drives shortly after disabling the head park feature with 3rd party software.
Also, the last two posts don't make sense.Comment
Are you saying my post doesn't make sense? Or the posts on Seagates forum?
I agree, mine could sound a bit far-fetched, but I am not stating it as fact. Just a guess and opinion.
If parking the heads is unnecessary and users are complaining about it, why did the firmware update not disable the entire 'feature' completely, or at least provide a utility like WD did to let the user configure it themselves? They made the head parking feature, I'm sure they could get rid of it too. Haven't seen anyone yet who said they thought it was a good feature.
Yet the feature is still there and Seagate refuse to answer whether or not disabling it via 3rd party software is "OK".
I don't think that the conclusion of perhaps it has to be there for reliability purposes is senseless. It's not the first time a firmware-based feature has been used to extend the life of something with a design problem. Remember the IBM Deathstars?"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
EDIT: Maybe Seagate programmed the firmware to artificially increase the reallocated sector counter if third-party modifications are made.Comment
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by reformattI thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...12-18-2024, 10:34 PM -
by tmcwA friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
Now, the case is a CiT Gaming Case, and...-
by madura2010Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
i checked the connectivity of ribbon=good communication with hard and motherboard
changed hard disk and checked=3f0 error persist
sata power=+5v available
Then checked data capacitors=all good
Then checked data lines path connectivity to pch=all good
reflashed... - Loading...
