Missing drivers - I'm lost.
  • stevo1210
    • Oct 2006
    • 4156
    I just installed Windows 7 32 bit on my HP TC4200 tablet. I only installed 7 because my university cut support for Windows XP on the tunnel guard software and authentication for Wi-Fi internet. Only Vista or 7 works with that shitty software now
    Anyway, everything works fine except I'm missing 3 drivers. (see screenshot). I don't know what devices these are for.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • mockingbird
    • Dec 2008
    • 5488
    Re: Missing drivers - I'm lost.
    Here you go:
    "http://downloadmirror.intel.com/18494/a08/infinst911autol.exe"
    If that link doesn't work, try this:
    "http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18494&ProdId=2032&lang=eng"
    The "PCI Simple Communications Controller" is a modem. Go to the details tab and post a screenshot.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      MK, his tablet uses an agere chip... so he needs the standard agere softmodem driver.
      what I do not know is whether they make a win7 driver for that...
      IMHO, unless you use dialup at all, I wouldn't sweat it.
      sigpic
      (Insert witty quote here)
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        May I ask why is Aero disabled?
        Windows 7 looks like shit without it :P
        If you are unable to enable Aero maybe one of those devices is the graphics?
        • stevo1210
          • Oct 2006
          • 4156
          I can't use aero because the 915 series graphics doesn't support it. I'm pretty pissed off that my university dropped support for Windows XP
          Anyway, I tried installing those chipset drivers above but they didn't solve anything I'm going to figure out if there's a root folder where all the INF files are.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Ah I see
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              stevo1210
              U may be able to find what the hardware is by using the Details tab of the device property's under property select Hardware Ids and it will have strings like this PCI/VEN_1002&DEV_6739
              Google the string for your device and you should find what it is.
              You also can right click on the device and select update driver withe it connected to the net if you are lucky windows has it in there online driver database.
              My pc
              CPU : AMD PHENOM II x4 @ 3.5Ghz
              MB : ASUS M4A89TD PRO USB3
              RAM : Kingston ValueRAM 16gb DDR3
              PSU : Cooler Master 850W Silent Pro
              GPU : ATI Radeon HD 6850
              • c_hegge
                • Sep 2009
                • 5219
                Mass storage controller is probably a card reader.
                Discontinuing support for XP? That's totaly rediculous!!! especially considering that the course I did only 1 year ago still had a lot of windows 98 and 2000 stuff. I won't downgrade to 7 or vistrash without a fight.
                • severach
                  • Aug 2007
                  • 1055
                  Windows 7 runs like shiznit with Aero turned on. Transparency makes captions hard to find. Popups from anywhere including the taskbar are bad, mmkay? Stacking, grouping, and intermingling running with non running taskbar icons were all bad ideas long before Vista.
                  Get the 4 digit hex codes for vendor and device. Search first at:
                  PCI Database
                  sig files are for morons
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    Originally posted by severach
                    Cool url Thanks.
                    My pc
                    • jpreza
                      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                      by jpreza
                      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                      Looking at the card, it appears to be missing the following:
                      1x 1.0uH inductor - orange square
                      2x...
                      11-01-2024, 10:54 PM
                    • BYTEHAT248
                      Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                      by BYTEHAT248
                      Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                      11-14-2025, 04:48 PM
                    • gurj1979
                      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                      by gurj1979
                      Hey guys.
                      Need help with this one.
                      Fan not spinning due to missing PWN Fan signal.
                      Also 5 seconds from powering up it freezes, unless in BIOS.
                      But as soon as Windows starts to load, it will freeze.
                      CPU is COLD / Room temp when it freezes.
                      I've replaced the CPU, same problem.
                      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                      Replaced fan - same problem.
                      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                      08-19-2024, 05:22 PM
                    • salopian
                      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                      by salopian
                      Hello. I would need some advice please.
                      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                      I have already replaced the logic board with another...
                      02-27-2021, 07:30 AM
                    • ein_individuum
                      Missing Capacitator Intel I9-12900KF CPU
                      by ein_individuum
                      I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                      I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                      Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                      08-06-2025, 01:36 AM
