Re: Why did my motherboard catch fire? Also, what can be saved?
either way, you will need to go on an expedition to ebay to hunt for a new board.
This just may be the dumbest mistake I have ever made with a computer. Quick, I need to get inside the internet and delete this entire thread before anybody can ever read it.
If I understand right, it is irrelevant whether anything was ever plugged into the port since the USB port would be grounded where it was attached, and that would indeed ground the +12V line on the firewire circuitry.
Firewire was disabled from within BIOS, but I doubt that actually powers down the firewire power circuitry.... that means it ran 850+ days with the firewire power shorted to ground, and it probably ran for ~250-300 days before that last reboot the same way too. If this is all correct, then I am now confused whether I should be happy that it ran so long like this, or furious that it didn't shutdown immediately when connected up this way...Leave a comment:
Looking closer at the picture (the computer is located out of my house right now for... smell... reasons so I can't physically look at it right now), it does appear whatever failed flared on the back first, then the front melted after. I think that might be important.
I have a new motherboard/cpu/ram on order and I will post an update with more pictures when I get this old board out and can take a proper look at it. New components should be here this week assuming NCIX isn't too backlogged with boxing day orders. I decided it wasn't worth throwing $80 in a new (unreturnable once tested) motherboard at this problem without knowing whether the other related (architecture-wise) components were any good. For an extra $160 I upgraded from my E6300 Core2Duo to an AMD Phenom II X6 1055T (2x1.86GHz --> 6x2.8GHz with better architecture) and from 2x2GB 800MHz ram to 2x4GB 1333MHz. This gives me the advantage of being able to switch the main OS over to Solaris and still run the linux stuff I need inside a virtual machine with acceptable performance.
Thanks for all the input, and the offers for instructions / suggestions on fixing the board
, but as much as the tinkerer in me REALLY wants to dig in and try fixing the board I really think fixing it was never an option given the extent of the damage.
my beef with intel regardign said baord (a dp35dp) is that they ditched one of the 2 IDE ports, the floppy port, and the ps/2 ports. the IDE i understand, since the controller chip is a single port marvell... but the rest perplexes me... at least they gave me 6 SATA ports (5 SATA+ one internal eSATA) and 12 usb 2.0 ports (6 internal headers, 6 external ports). I guess they were using Macintosh design concepts (ironic I put it in a mac clone case).Last edited by ratdude747; 12-27-2011, 10:44 PM.Leave a comment:
All hail the mighty Intel....
Can we go back to PowerPC yet?Leave a comment:
Who'se idea was it to make the USB and 1394 headers identical, even though getting it wrong blows the board up?Leave a comment:
the board's soul has crossed the rainbow bridge to computer heaven... (plays taps).
time for a new board.Leave a comment:
That's not the USB header!
Now it's pretty clear what happened - 12V to ground short.
The other pictures I could find of this board show that area has almost no components, so even cutting the whole area out, it would probably still work (maybe no more audio out.)Leave a comment:
had an abit socket 462 board that had a burned polyfuse on the firewire.
i cleaned it up and replaced the pf.
its still in use today.never did find out why this happened but the customer was very happy to get it fixed.abit returned it unrepairable and warrenty void.on a $300 board that was unacceptable.
the o.p's board is too far gone.sorry!
another thought is possibly a short developed between layers.i remembe this happening to some expensive servo drive boards.the mfr had to hipot the bare boards before assembly to prevent this.Leave a comment:
The only fires I've seen in my career have been Lexmark Laser printers, Tripp-Lite UPSes and Asus motherboards.Leave a comment:
Like smason said, the fact that the board is an ASUS explains it. They love goingwith no external cause. It's known here as the ASDS (ASUS Sudden Death Syndrome)
The back side of the board looks like it flared too, along with the front surface. This burned through traces unrelated to the USB polyfuse that went poof ultimately killing the board. Repairing this damage is likely going to be a pipe dream. The polyfuse is intended to protect the motherboard from USB port shorts/overloads. I went through this with a Tyan board a year or so ago...but thankfully, it was repairable. For whatever reason, it incinerated itself. If you're lucky, all that doesn't work is the USB port the fuse was on...but if the board is dead, there was some severe trace damage....time to replace the board.Leave a comment:
I can confirm that the USB port assembly that was plugged into that header is not shorted, however I had to cut the wires leading to it to check it, and since it is generally unused I will just leave it off the replacement board. I can find no signs of any foreign objects against the pins for the header either on the front or back of the board so I don't think that this was a short on the USB lines, plus, as mentioned above, that should be current limited... I have no idea what else could prompt such a failure though
If the thoughts are that the CPU/ram have a fighting chance then I will just replace the motherboard and hope for the best. I appreciate all the opinions so far, I was hoping that I wouldn't have to replace much more than that.Leave a comment:
clean the soot off the board and then upload a pic... looks like a polyfuse went boom. if thats all, then you could have someone replace the fuse (be sure to find the cause of the short first!
from the looks of it, it looks like some wires and a polyfuse burned but the rest of the board is intact, as I can see the outline of traces under the soot.
to clean it, use a nylon/plastic brush, dry.
to replace the poly fuse, it takes skill... not for the faint of heart. it essentially an SMD repair operation. what one does is desolder the remains of the old fuse off the board, desolder a good fuse from a junk board, and solder on the new fuse. the second part is the hardest.
just my $0.02.Leave a comment:
Don't think they're conductive enough to short out 5v.Leave a comment:
Cockroach behind the board?Leave a comment:
burned through a multilayer board?even if it still runs its no longer reliable or safe.just replace the board.eveything else ok.dont use whatever was plugged into that header again.
by glovecapsHello,
I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by DocusHi everyone 😀,
I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:- I already own the exact same model, but its plastic chassis is badly damaged.
by paulocoobHello forum friends.
I want to ask for help diagnosing this GPT52 LA-k201p HP 250 G8 card (without dedicated GPU).
The motherboard turns on and consumption is 2.2A (CPU fire)
All voltages seem OK.
The coil resistances are these
[FONT="<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Lucida Sans Unicode</font></font>"]PL302 = 3.2kΩ
PL301 = 30.1kΩ
PLB2 = 10.1MΩ
PLZ1 = 22Ω
PLZ2 = 22Ω
PLG1 = 77Ω
PLM1 = 5Ω[/FONT]
Could...11-13-2023, 07:54 AM -
by ArchimedesSubject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
Fans are spinning. Blindly could install windows11 and got the device manager... -
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... - Loading...
