Re: Recommend GOOD cheap PSU
If your system is running OK now then your PSU probably does has enough power.
But with a name like E-Value I would be a bit worried about the quality. Even if the basic design is OK it probably uses cheap capacitors, which you might want to upgrade.
Of course if it's a crap design, you'd be better off just buying a reputable brand instead.
Hi-im going to upgrade PSU to my rig.
my spec is: Phenom x4 965be
Amd Radeon 6850
I'm currently using cheap PSU.E-Value 550w & 650w Bluewolf
Is my psu enough power? Or may i need to change psu?
ThanksLeave a comment:
Heh, I always thought of the GF series as "Get F**ked"Leave a comment:
And you can remember that because both Girl Friends and Good Luck are unreliable.Leave a comment:
My CX400 is from the older CX series, not the new one.
http://www.hardwaresecrets.com/article/750
(after re-reading that) that's right, mine apparently uses OST. Ugh.Leave a comment:
The CX V2 series use Samxon and Teapo - they're good enough considering the fan is usually also kept at higher speed therefore they're decently cooled.
See http://www.jonnyguru.com/modules.php...tory4&reid=239
You don't really need 500w power supply - that system will do 100w idle and about 300w load so even a good 350w would be enough.
Newegg has a 24h sale now on an CX 500 v2... 27$ after mail in rebates, 47$ usual price: http://www.newegg.com/Product/Produc...s-_-17-139-027Last edited by mariushm; 11-28-2011, 05:15 PM.Leave a comment:
Better see if the warranty on my CX400 has run out yet then...
You say they use Samxon rubbish series?Leave a comment:
yeah... warning on all the funky caps, especially in corsair CX (not cool cause they replaced the VX which were good with these)... last i checked tho, ablecom/supermicro was fine, but topcat knows more since he sees those all the time:
http://www.newegg.com/Product/Produc...82E16817377062 (400w delta, so not sure)
http://www.newegg.com/Product/Produc...82E16817377027 (500w ablecom)Leave a comment:
Yep - Capxon, Taicon and Asia-X or something similar.
Keep an eye on the Capxon!Leave a comment:
Last time I checked it there was a lot of Taicon and a few CapXon in there. I've been meaning to recap it but it runs super cool and it's a Delta.Leave a comment:
http://www.hypermicro.com/ProductDes...046&type=0&eq=
Been running my C2D rig for almost 2 years now. Rock solid and quiet.
We have a customer with a 300w variant of these in their PCs.
Some of the collection of caps inside are Capxon, which fail and then send the ripple to the mobo, which overheats components and takes out caps there too.Leave a comment:
I got a good deal on an "Antec Earthwatts 650", for $69 when the retail price was still $99. Now I see them on sale again, , , you guessed it, for $69 again.
I have two of them, one in each of my main systems and after more than a year, never a complaint. I run a lot of extra hardware and the PSU's take it in stride. I can think of nothing worse, than being Underpowered.
Remember, the rating on the label, is the momentary startup wattage, not the All Day, every day running wattage.
Cheers mates, and Happy Holidays!
I dunno what you have and I could be wrong but the odds are you'll find you are past just over-kill and well into hyper-over-kill.
.Leave a comment:
That's a pretty common way to mount the fan nowadays. Large, slow fan makes it quieter.Leave a comment:
by aaronkatriniHi all,
- Autorange
- DC volts up to 30V
- Accurate Resistance
- Diode test (Beep mode)
- Frequency up to 200MHz
- Capacitanze up to 5000uF
- as cheap as possible
Other functions are not needed but those which are needed... -
I did a cell salvage run on some Dyson batteries to build out a new fleet of Milwaukee batteries and the yield was a lot higher than expected, so I now have a lot of extra Sony VTC4s that are in reasonably good health. I'd like to build them into power banks, there's a glut of shells for 18650s on AliExpress but I don't know which are any good (read: won't explode). Can anyone recommend some (especially the ones that just fit a single cell)? Weld or weldless are fine, I have a spot welder
I suppose USB-PD and/or quick charge would be desirable too
Cheers -
by momakaFor today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
http://www.rmac.kingwin.com/products.../abt_650MM.asp
I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
What mostly drew me into buying it is its 2x PCI-E power connectors... -
by momakaBoston Acoustics fans, this thread might not be for you.
A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual.And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
- Loading...
