Boston Acoustics fans, this thread might not be for you.
A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual.
And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the world, if nothing else.
On the outside, it looked in pretty decent condition. The front cover had a bit of staining from unknown liquid that I couldn't get out, but it's actually not as bad as the picture above shows.
Next is a picture of the name/model plate, as shown below. Made in USA
and the box has good weight to it.
Removing the front cover revealed rotten foam surround on the woofer driver. Of course, problems like that are to be expected on old speakers – especially on freebies.
The woofer is 8” (20 cm) diameter with a polypropylene cone. The soft dome tweeter is 1” (2.54 cm) diameter and actually looks like good quality stuff. Sticker above shows this:
And below is a closer look at the (now) 30-year-old woofer driver! Yes, production date on the woofer says “06/14/91”.
It wasn't quite 30 years old when I found it, but not like that makes any difference for the foam surround – it was still quite rotten when I took the pictures below.
In my opinion, the woofer driver is the only weak point on these speakers, as you will see later. Overall, it was built quite on the cheap side. The size of the magnet is disappointing at only 2 & ¾ “ (7 cm) diameter. Even if the motor has very tight gap tolerances, I don't think this magnet is strong enough for the 1” voice coil to produce good low-end bass (50 Hz and under.) Moreover, the cabinet is sealed type, which means the woofer driver will have to work even harder at very low bass frequencies, as the cabinet will present higher and higher load pressure. Also, the motor is not magnetically shielded, as far as I can tell. On the plus side, at least the motor bottom plate is “bumped” for extending the voice coil travel distance slightly. The basket is also decent, made of fairly thick steel with good folds to keep it sturdy. Under the speaker rim, there is a foam gasket as well, which should keep air from leaking around the speaker (this is something that cheap speakers always skip out on.)
Anyways, moving onto the soft dome tweeter…
It's actually has a good weight to it and seems to be of much better quality. What I find amusing is that its magnet is almost as big as the woofer's, measuring at 2.25” (5.7 cm) diameter.
Next, a look inside the speaker cabinet/box itself with the drivers removed.
That's very good construction, IMO. Holes are cut nice and clean. The front wall is made from decently thick particle board. There's also a good amount of poly-fill baffle inside for a sealed box. And although not visible in the picture, there are many big triangular pieces glued on the corners inside the box to make it stronger and reduce self-resonance.
Finally, here's a look at the crossover network:
Again, IMO those are some pretty good quality components right there. The woofer crossover has a nice big air-core inductor and a large cap to limit the high frequencies going into it. Meanwhile, the tweeter has the smaller series cap (the 4.7 uF one, I think), along with a 1.5-Ohm 10W resistor and another air-core inductor to remove any low frequencies from going into the tweeter.
So overall, this is a really well-built speaker, aside from the underwhelming woofer driver. But because the woofer plays such an important role (particularly in the bass department), I didn't really see a point in doing a proper surround repair (i.e. buying replacement foam surround online.) I was already pretty sure this speaker would lack a lot of low-end bass. On that note, a pair of these speakers might actually sound pretty decent with a separate subwoofer. Unfortunately, I didn't get a pair of these – only a lonely single speaker. So there's not much I can do with it. The only two things I can think of are either to use this speaker as a center channel in a home theater or just convert it into a portable/blutooth speaker as a fun project. The former probably won't happen, since I don't really watch TV and I already have a system for that. The latter… maybe I can see it happening (if I get really bored.) But in that case, I probably don't need a properly repaired speaker for such project anyways.
I also entertained the idea of giving it away for free… but I just couldn't see anyone who would want a single speaker like this. I'm sure the dome tweeter and X-over network will sell easily online… but that would leave me with a cabinet and broken driver to junk. Therefore, I figured it might be better to fix it cheaply / in DIY fashion, so that at least it's not sitting around broken. This would also allow me to hear how the speaker sounds overall. And if it really does sound good, I can always undo my crappy DIY surround repair and redo it properly. So off to that part next.
And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the world, if nothing else. On the outside, it looked in pretty decent condition. The front cover had a bit of staining from unknown liquid that I couldn't get out, but it's actually not as bad as the picture above shows.
and the box has good weight to it.Removing the front cover revealed rotten foam surround on the woofer driver. Of course, problems like that are to be expected on old speakers – especially on freebies.
It wasn't quite 30 years old when I found it, but not like that makes any difference for the foam surround – it was still quite rotten when I took the pictures below.In my opinion, the woofer driver is the only weak point on these speakers, as you will see later. Overall, it was built quite on the cheap side. The size of the magnet is disappointing at only 2 & ¾ “ (7 cm) diameter. Even if the motor has very tight gap tolerances, I don't think this magnet is strong enough for the 1” voice coil to produce good low-end bass (50 Hz and under.) Moreover, the cabinet is sealed type, which means the woofer driver will have to work even harder at very low bass frequencies, as the cabinet will present higher and higher load pressure. Also, the motor is not magnetically shielded, as far as I can tell. On the plus side, at least the motor bottom plate is “bumped” for extending the voice coil travel distance slightly. The basket is also decent, made of fairly thick steel with good folds to keep it sturdy. Under the speaker rim, there is a foam gasket as well, which should keep air from leaking around the speaker (this is something that cheap speakers always skip out on.)
(The first were these
Still working OK, though. If anything, the paper surround on those has gotten “better” – that is, it makes a lot less noise now, since it's had a chance to “break in”. I also made a second surround for another of the CV drivers (not pictured here), and on that one I experimented with latex paint. The results from this were very positive (oh, and the CV drivers are not ruined in any way, BTW – all these paper surrounds are easily undo-able.)
Still, I won't recommend that either. On a similar note, newspaper should also work… but IME will have the same problems as PC printer paper. So kitchen paper towel really is the best IMO, provided its layers don't separate easily (had that happen with one brand, and it made for a poor surround that needed re-gluing multiple times… but that was on a more recent speaker repair that I need to post.)
terrible as that may look, it was good enough for a test. Actually, it revealed that the HD8 woofer also isn't too bad in terms of bass, once placed in a larger ported enclosure. There was reasonable output down to about 50-ish Hz with the HD8 woofer and good output above 60 Hz… fairly linear too. In comparison, my SS-MB215 woofers go down only a little further – good output to about 40 Hz, some output to 35 Hz, and very quick drop-off below that, regardless of the port length. But this is to be expected – neither of these speakers have very big motors. So the HD8's smaller magnet will definitely loose some dB's at the lower frequencies. Also worth mentioning is that I tested both of these with the bass adjustment on my tone controls maxed out (about +10 dB.)
