old OC rig suggestions
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: old OC rig suggestions
    Originally posted by gerg
    too much memory for a 32 bit os?
    really i have nothing but time to keep guessing tonight...
    it has the capability but no. keep in mind that anything socket a is 32 bit.
    sigpic
    (Insert witty quote here)
    • gerg
      • Nov 2010
      • 278
      socket a wanna water cool i could go through my junk pile and see if i still have my old dangerden setup maze 4 block and a z chipset block lol
      I am running out of guesses
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I suggest you look up the wikipedia page on XP editions. there is a large hint there.
        sigpic
        • lti
          • May 2011
          • 2557
          Dual CPUs?
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Originally posted by lti
            Dual CPUs?
            you have been awarded a virtual cookie.
            you can now guess the brand, and model. the brand's name is also a term used in electronics.
            sigpic
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              crap. recapped the psu, still dead.
              the manual tot he board says it needs at least a 400W psu, and my only other spare unit is a 300W delta.
              suggestions?
              sigpic
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Use the Delta! Since when does a mobo have a wattage rating, lol!
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  dualies tend to.
                  just like graphics cards do.
                  to prove the point, I i will reveal that the mobo is a Gigabyte GA-7DPXDW
                  manual attached.
                  off topic- the manual as a lot of engrish in it...
                  still looking for advice on the psu issue.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    FYI- the 400w bit isn't in the manual, but in the FAQ on GB's site:
                    http://www.gigabyte.com/support-down...id=466&pid=995
                    sigpic
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      It's BS I think... how much amperage you got on the +12V, -12V, +5, and +3.3?
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        well, a datasheet on my psu:
                        the psu label says
                        12v 15A
                        5v 30A
                        3.3v 16A
                        -12v 0.8A
                        5vsb 2A
                        -5v 0.3A
                        sigpic
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Meh just use it until you find a better one. It's a Delta, so it can probably do a little more than 300w anyway...
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            #33
                            Very nice board there!
                            Like shovenose, I too have to raise the BS flag on the wattage rating that they gave on the FAQ, it's just unrealistic.
                            I see a AUX 12v connector on the motherboard, so that means the CPU VRM is powered from the 12v rail, which in turn means you need a PSU with a stronger 12v rail. Either way, you I'm sure you won't need a 400W PSU. Just look up the TDP or Maximum Power Dissipation rating of each CPU on cpuworld, then multiply that by 1.3 (assuming an unrealistically low 70% efficiency for the VRM) and then by 2 (since you have 2 CPUs). That will give you a rough estimate of the wattage you need on the 12v rail.
                            Okay, I just looked at all of the Athlon MP CPUs, and the highest Maximum Power Dissipitation I saw was 66 Watts. Using the numbers above, that gives you 171.6 Watts peak for the 12v rail just for the CPUs, which comes out to 14.3 Amps peak. And of course, that's only if your CPUs are the ones that use 66 Watts. The Athlon MP 2400+ are rated to dissipate 60W max, so that's 156W on the 12v rail, or 13A.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              i ran some calcs and in my initial single cpu setup, the 300W will work. for the final dual setup, I will need some more juice.
                              that assumes that i keep the graphics card, which is an nvidia geforce 5200fx.
                              sigpic
                              • c_hegge
                                • Sep 2009
                                • 5219
                                It will struggle with a dual CPU. It has too much current on the 5v rail and not enough on the 12V rail. That board may be a socket A, but it does have an ATX12V connector. If you were in Aus, you could have my thermaltake TR2 Bronze 600W.
                                http://www.ebay.com/itm/XPS-700-710-...item35b6be0c53 looks like it would be goof for the money. It looks like it might be standard ATX but you never know with Dell
                                http://www.ebay.com/itm/Seasonic-550...item1c20d16c01 That one is a bit more expensive, but also looks good.
                                EDIT, your Delta may be OK for a single CPU.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  so i assume a hipro made 250W unit i have from a p4 based dell is a no either. I'll check the specs on it.
                                  edit- aside form the the 300w, all my spare PSUs are 14A or less. damn.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    fixed the 600W
                                    noob over here had some primary side solder bridges (had to remove the primary HS to install a couple caps). fixed that, problem solved.
                                    I feel so dumb right now...
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      good news: I got the board and recapped it. haven't had time to test.
                                      bad news: the ****ing board doesn't fit the case at all.. 1cm ish too long and the tall registered memory conflicts with the hdd cage...
                                      any suggestions on good but cheap used case brands with front USB headers? I don't need a sound header, as my board has no such header... but it does have a frount usb header and forn usb acess would be nice.
                                      on a side note, I have matched coolers... went to a university surplus store and found a bunch of NOS aluminum vantec socket a coolers for $5 a pop... I grabbed 2 and braided the fan cables... now all i need are a couple of athon MPs... and a case that fits
                                      sigpic
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        They do. - It's just impossible to find it.
                                        All the traces on the board have amp limits.
                                        That includes the ones going to the PSU connectors.
                                        Also all the MOSFETs and IC's and so forth have TDP ratings - or something equivalent.
                                        You -can- add it all up if you care to.
                                        Mann-Made Global Warming.
                                        - Dr Seuss
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          BTW, the NOS coolers were theese:
                                          http://www.vantecusa.com/gl/product/view_detail/135
                                          they were new in box, never used. good deal for $5/cooler and no shipping?
                                          sigpic
