old OC rig suggestions
Re: old OC rig suggestions
I suggest you look up the wikipedia page on XP editions. there is a large hint there.sigpic
(Insert witty quote here)Comment
crap. recapped the psu, still dead.
the manual tot he board says it needs at least a 400W psu, and my only other spare unit is a 300W delta.
suggestions?sigpic
dualies tend to.
just like graphics cards do.
to prove the point, I i will reveal that the mobo is a Gigabyte GA-7DPXDW
manual attached.
off topic- the manual as a lot of engrish in it...
still looking for advice on the psu issue.
Attached Filesif you find these attachements useful please consider making a small donation to the site
sigpic
FYI- the 400w bit isn't in the manual, but in the FAQ on GB's site:
http://www.gigabyte.com/support-down...id=466&pid=995
sigpic
well, a datasheet on my psu:
the psu label says
12v 15A
5v 30A
3.3v 16A
-12v 0.8A
5vsb 2A
-5v 0.3Asigpic
Very nice board there!
Like shovenose, I too have to raise the BS flag on the wattage rating that they gave on the FAQ, it's just unrealistic.
I see a AUX 12v connector on the motherboard, so that means the CPU VRM is powered from the 12v rail, which in turn means you need a PSU with a stronger 12v rail. Either way, you I'm sure you won't need a 400W PSU. Just look up the TDP or Maximum Power Dissipation rating of each CPU on cpuworld, then multiply that by 1.3 (assuming an unrealistically low 70% efficiency for the VRM) and then by 2 (since you have 2 CPUs). That will give you a rough estimate of the wattage you need on the 12v rail.
Okay, I just looked at all of the Athlon MP CPUs, and the highest Maximum Power Dissipitation I saw was 66 Watts. Using the numbers above, that gives you 171.6 Watts peak for the 12v rail just for the CPUs, which comes out to 14.3 Amps peak. And of course, that's only if your CPUs are the ones that use 66 Watts. The Athlon MP 2400+ are rated to dissipate 60W max, so that's 156W on the 12v rail, or 13A.Last edited by momaka; 11-18-2011, 11:54 PM.Comment
i ran some calcs and in my initial single cpu setup, the 300W will work. for the final dual setup, I will need some more juice.
that assumes that i keep the graphics card, which is an nvidia geforce 5200fx.sigpic
It will struggle with a dual CPU. It has too much current on the 5v rail and not enough on the 12V rail. That board may be a socket A, but it does have an ATX12V connector. If you were in Aus, you could have my thermaltake TR2 Bronze 600W.
http://www.ebay.com/itm/XPS-700-710-...item35b6be0c53 looks like it would be goof for the money. It looks like it might be standard ATX but you never know with Dell
http://www.ebay.com/itm/Seasonic-550...item1c20d16c01 That one is a bit more expensive, but also looks good.
EDIT, your Delta may be OK for a single CPU.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
so i assume a hipro made 250W unit i have from a p4 based dell is a no either. I'll check the specs on it.
edit- aside form the the 300w, all my spare PSUs are 14A or less. damn.Last edited by ratdude747; 11-19-2011, 12:04 AM.sigpic
fixed the 600W
noob over here had some primary side solder bridges (had to remove the primary HS to install a couple caps). fixed that, problem solved.
I feel so dumb right now...
good news: I got the board and recapped it. haven't had time to test.
bad news: the ****ing board doesn't fit the case at all.. 1cm ish too long and the tall registered memory conflicts with the hdd cage...
any suggestions on good but cheap used case brands with front USB headers? I don't need a sound header, as my board has no such header... but it does have a frount usb header and forn usb acess would be nice.
on a side note, I have matched coolers... went to a university surplus store and found a bunch of NOS aluminum vantec socket a coolers for $5 a pop... I grabbed 2 and braided the fan cables... now all i need are a couple of athon MPs... and a case that fits
sigpic
They do. - It's just impossible to find it.
All the traces on the board have amp limits.
That includes the ones going to the PSU connectors.
Also all the MOSFETs and IC's and so forth have TDP ratings - or something equivalent.
You -can- add it all up if you care to.
.Last edited by PCBONEZ; 11-30-2011, 02:10 AM.Mann-Made Global Warming.
- Dr Seuss
BTW, the NOS coolers were theese:
http://www.vantecusa.com/gl/product/view_detail/135
they were new in box, never used. good deal for $5/cooler and no shipping?sigpic
by sam_sam_samI have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
by sam_sam_samI was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
Now after replacing the two capacitors on the two 5 volt power supply rails
One is used for the up/down limit up/down force circuits
Second one is used for the radio receiver circuit
The main filtering capacitor ESR value was a little higher than a new one
https://www.northshorecommercialdoor...yABEgLxlvD_BwE
Assuming...7 Photos -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
