Hard Drive Lifespan: Seatools for DOS
  • bigbeark
    • Jan 2010
    • 661
    I recently bought a box of 20 plus hard drives, a mixture of IDE and SATA.
    I downloaded all the Drive Tools I could find from Seagate, Western Digital, Samsung, Hitachi and Maxtor.
    The best tool by far was Seagate's Seatools for DOS. It evaluates any manufacturers drives, and allows error correction on Seagate (and Maxtors made by Seagate) drives.
    Since WD and Samsung only evaluate defects, which Seatools does already, why bother?
    At any rate the POH (powered on hours) was very interesting to me. Most of the drives had POH hours between 5000 and 18000. Some of the drives with unfixable media faults had hours as low as 1800. There were several newish drives with I guess bad logic boards as the drive was not detected at all. There were three or four newish drives with the "click of death", the heads refusing to park properly.
    Fortunately there was a 750GB with less than 1000 hours, two 250GB drives with no faults, one Seagate 250GB with one error that I corrected, a working 160GB laptop SATA drive, and surprisingly a couple of those skinny Maxtor IDEs which had big hours but no faults.
    What's your longevity record for consumer grade IDE and SATA drives.
    I still trust SCSI, median average failure time 1.5 million hours!
    Since there are only 8760 hours in a year isn't that 171 years?
  • lti
    • May 2011
    • 2545
    Re: Hard Drive Lifespan: Seatools for DOS
    I have two old Seagate drives with no bad sectors. One was made in 1998 and has a high Ultra ATA CRC error rate because the computer's FSB was set to a higher frequency than the chipset could handle. The other drive makes strange metallic ringing noises.
    I also have an IBM 20GB laptop drive that was killed by a cheap USB enclosure. Windows only sees a single empty folder, but 1.5GB of space is being used. I also have a Toshiba drive that developed bad sectors after almost exactly two years.
    • severach
      • Aug 2007
      • 1055
      There's no reason the software can't run on other brand drives other than to annoy the user. Error correction is not magic performed by the software. The firmware on the drive is where the magic happens and no special software is required to make it work. Just write a sector and the firmware does the rest. All the software does is to read the whole disk and write zeros to any bad sector it finds. This is a good technique if you are trying to recover data and there's a bad sector interfering. It's a bad technique if you're trying to validate a drive as fully functional.
      Writing zeros takes the same amount of time as reading the drive but is much more comprehensive. The drive will fix and remap all bad sectors including those that are in places the operating system never uses and at the end the drive sorts the bad sector list so the drive works faster. If there are too many errors then the operation will halt and you know the disk is bad. The tools trying to fix one sector at a time can make the bad sector map so convoluted that the drive will give up. Zeroing often fixes this problem.
      The drive will fix bad sectors on any write but only zeroing improves the speed. The drive will not rearrange anything when mersenne twister, random, imaging or any other random data is written.
      sig files are for morons
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        That's not what it means.
        It's not an estimate of longevity.
        http://www.faqs.org/faqs/arch-storag...ction-151.html
        To try and clarify.
        Lets say the bearings are good for 5 years 24/7 so they make 5 years the expected lifetime.
        The MTBF basically tells you the odds of it failing - before the 5 years is up. [Before the wear-out phase.]
        Once you hit the 5 years it's expected to die soon regardless of anything else.
        A 1.5 million hour MTBF means if you have 1.5 million drives under 5 years old you can expect to loose, on average, one per hour.
        And if you have 0.5 million drives under 5 years old you can expect to loose one every 3 hours, on average.
        Mann-Made Global Warming.
        - Dr Seuss
        • EagleTG
          • Jun 2011
          • 20
          Your study on a bit larger scale:
          Interesting read, if a bit long. There are some good summaries of the study out there too, like http://www.engadget.com/2007/02/18/m...resting-thing/
          Sadly Google took the high road and opted to not call drive manufacturers out by name (even though they saw a strong correlation of failure to manufacturer). I'd love to see if any of my suspicions from personal experiences with different manufacturers would be confirmed.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            I don't bother with any of the other manufacturers tools - I just use SeaTools. In Windows, I use HDTune Pro.
            Ludicrous gibs!
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              I was reading about this on Seagate's website...where in the program does it tell you how many hours are on the drive?
              • bigbeark
                • Jan 2010
                • 661
                The online windows version does not give you the POH (powered-on hours) or let you fix defects.
                You have to download the Seatools for DOS program. burn it to CD/DVD/Floppy, then reboot your computer. The program runs in Ram.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Yeah that's the one I got. This HDD has 35,000 hours!!!!!!! And only made in February, 2007
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    35,000 hours is almost exactly 4 years. So, have you been running the drive 24/7 since you got it?
                    Ludicrous gibs!
                    • PlainBill
                      • Feb 2009
                      • 7034
                      <SNIP>
                      You are confusing interface with quality of construction. At heart, a hard drive is an electro-mechanical assembly with an interface to the outside world. At one time SCSI was the favored interface for high performance drives. If I recall conversations with my sons correctly, that is no longer the case, fiber is the preferred interface. If you take an exquisitely engineered and constructed set of platters, bearings and heads and slap an IDE interface it will still be a reliable drive.
                      If you take something that was a rush design job, slapped together by a bunch of careless slobs using substandard materials it doesn't matter which interface the drive has, it's going to die early and ugly.
                      PlainBill
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        But such a drive was unlikely to be offered as IDE, which needed to be built to a price - was only likely to show up as SCSI, where its asking price could support the quality of construction
                        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                        • smason
                          • 1652
                          While I agree in theory, in practice I've seen next to NO failures in SCSI and SAS (serial attached SCSI) drives in servers, while I've seen tons of failures of SATA and IDE drives. SCSI and SAS just seem to be better built, whether there's any truth to it, I dunno.
                          Haven't seen fibre used in SANs lately. SAS drivrs seem to be the mainstream, and iSCSI over Gigabit and 10Gig copper is the latest greatest for SANs as the switches are way less expensive than the fibre ones.
                            master hoarder
                            • May 2008
                            • 12160
                            • Bulgaria
                            Beware that some drives don't report their Power-On Hours correctly. In my experience, Maxtor HDDs are the biggest offenders. Some newer Hitachi and Samsung drives also mis-report the POH - they usually show much higher than normal.
                            On the other hand, old IBM/Hitachi are very accurate. I've timed both my 305030 and 307020 IBM Deskstars and they count the hours very accurately. The 305030 just turned 23078 hours today. It has 20 reallocated sectors. I found it in a computer about 2 years ago. Back then it had 22028 hours and 19 bad sectors. Not too bad for an old Deskstar .
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              That's not why.
                              The reason is there is no point in building an IDE drive faster than 7200 RPM.
                              The higher RPMs is what necessitates the higher build quality.
                              His point was that -IF- they used the same mechanicals the interface would be irrelevant to failure rate.
                              - Dr Seuss
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Originally posted by PCBONEZ
                                That's not why.
                                Maybe you can help out here PCBONEZ. I don't understand how faster spin speeds of a hard drive correlates with reliability!
                                In fact, personally I've observed quite an interesting thing regarding those ancient ~20GB IDE 4200RPM 2.5" drives made by Fujitsu, Hitachi, IBM, etc: they last much longer than modern hard drives. They technically aren't more reliable (because their lifetimes and failure method) vary widely but they do last longer...(compared to modern 5400/7200RPM 2.5" SATA/IDE laptop drivers).
                                Can you explain that?
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Faster is more stressful on the mechanicals so for faster:
                                  - They use higher quality parts/materials. [Better alloys and platings.]
                                  - The tolerances are tighter for the head to hit the 'right spot' on the disc at a higher RPM so:
                                  - - - The machining has to be more accurate.
                                  - - - Faster wear from more rotations/time lessens time to out of spec tolerances.
                                  - - - The firmware also has to be more accurate.
                                  - - - As to cost, there is a lower yield on parts coming out of the 'machine shop' and electroplating phases of production due to the tighter tolerances.
                                  So higher RPM drives are built to higher quality standards.
                                  [And that's what makes them more expensive.]
                                  A secondary thing for older and smaller drives it that they use[d] the Longitudinal Recording Method which is less prone to wear related failures than the newer PRM [Perpendicular Recording Method].
                                  - With Longitudinal Recording the 'spots' on the disc are -physically- larger.
                                  - With PRM the 'spots' are smaller -and- the 'free' space between the 'spots' is also smaller.
                                  With PRM the head placement has to be more accurate and that inherently means wear issues are more likely cause problems.
                                  With PRM the charge [on the spot] is also somewhat weaker due to less space to put the charge in -and- as they are also closer together -and- as there is more adjacent area spot-to-spot: they are more susceptible to corruption due to charges 'discharging' or 'neutralizing' each other through the free space.
                                  [This is basically the same magnetic media problem tape media is known for. The charges eventually dissipate with time.]
                                  Not a huge problem short term but if you are in the habit of using drives as deep storage back-up for files that don't get rewritten for ages [overwriting refreshes the charges] then a PRM drive isn't the best choice.
                                  You also might note that very high RPM drives tend to be smaller capacity.
                                  That's not a marketing thing...
                                  It's because it's easier to keep a smaller 'spinning mass' within dynamic tolerances.
                                  The discs tend to be physically smaller for less spinning weight for the sake of stability while spinning.
                                  - Dr Seuss
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    Yeah pretty much, it's my neighbors computer. The hard drive is dead. Not completely dead, it is recognized by the computer and everything but there are too many sector errors on it for any program to fix. It found 100 errors 55% through the scan and can't go any further. It's had a good life though
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      Okay so I just had to share this with everyone. I'm checking all the hours on my IDE hard drives, the old Pentium 3 comp my neighbors gave me had an old WD hard drive. Made in June, 2000 it has 63,713 hours on it! That's crazy. And they stopped using it in 2008 so it was on almost every minute from 2000-2008
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4913
                                        • New Zealand
                                        Personally I don't use Seatools or any manufacturer-specific tool unless it's for a specific reason.
                                        The reason is that Seatools doesn't give a damn about SMART, unless it's 'officially' tripped.
                                        By that I mean that if your hard drive has 500 reallocated sectors, yet 700 must get reallocated for SMART to tell you the drive is faulty, Seatools will tell you there is nothing wrong - yet with that many reallocated sectors there most certainly is!
                                        For this (and other reasons) I use HDAT2 for testing\scanning HDDs. It gives a readout of the full SMART data (Seatools doesn't) and uses common sense to determine if something is bad, rather than just blindly believing the drive.
                                        For a quick SMART readout under Windows, I like Speedfan. Bonus is it can read all your temperatures too, so I have it running anyway.
                                        -David VanHorn
                                        • eccerr0r
                                          failing hard drives after sitting for years...
                                          by eccerr0r
                                          With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                          Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                          Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                          03-02-2023, 10:33 AM
                                        • abajor
                                          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                          by abajor
                                          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                          04-23-2024, 11:43 PM
                                        • karto95
                                          Repairing a Seagate hard drive with damaged logic board
                                          by karto95
                                          I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                                          I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                                          If anyone has any suggestions or experience with this...
                                          03-21-2023, 04:05 AM
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • ChaosLegionnaire
                                          what to do with faulty hard drives?
                                          by ChaosLegionnaire
                                          i have several dead/bricked (not detected, doesnt show up or making constant clicks of death) and faulty bad sector hard drives. im moving house soon and need to get rid of some dead weight.
                                          i thought of selling them for parts or not working but they are quite heavy and shipping each drive internationally via local post is US$23 each. im using some of the drives as gym strength training dumbells by putting 4 of them in a box to make a 3kg dumbell. but since im moving i cant carry the deadweight with me. any ideas what to do with them that is cost-effective for ppl like me...
                                          11-25-2021, 02:42 AM
