Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
  • abajor
    • 178
    I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
    I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
    The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
    Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present the values differently, and sometimes I suspect they low ball certain values?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    I' e got a few boxes full of HDD's 3.5” and the 5 1/4”. I did find a much higher percentage of real slow or failing 3.5” HDD's than the 5 1/4 with anything short as a day of total runtime. The lower the days it ran, usually the.higher risk of failing faster. I think that is because the laptop or external HDD got dropped.
    On the other hand, I've got some old desktop HDD's spinning 24/7 with over 11 years of on time and have little or no errors in smart data. I had HDDs that would last exactly the warranty period plus one week, I hardly had ever luck with warranty on a HDD.
    • lti
      • May 2011
      • 2558
      Seagate drives normally have huge raw values for read and seek error rates while being perfectly healthy (aside from a few failure-prone models).
      I never noticed a difference between CrystalDiskInfo and other SMART monitoring tools.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        thing is crystal disk info (windows) lists the smart values as raw hex values by default instead of decimal like other smart utilities. so u have to either use the calculator in programmer mode to convert the hex values to decimal or just find the menu option in crystal disk info to list the values in decimal instead of hex.
        the linux disks utility is also called gnome disk utility. i find that it doesnt display some types of smart info correctly for some ssds and helium filled hard drives like the lba read and write, number of ssd sudden poweroffs and the helium indicator for helium filled hard drives. so i use gsmartcontrol instead. gsmartcontrol displays that info correctly. so there's other smart utilities to try out in linux if one doesnt work or displays bogus values.
        • abajor
          • 178
          I will have to check out gsmartcontrol.
          I definitely prefer checking drives in linux, since it doesn't have the bad habit of trying to handshake and index a bad drive like windows.
          • eccerr0r
            laptop vs desktop rust spinner longevity
            by eccerr0r
            Has there been a study on how durable laptop 2.5" vs desktop 3.5" hard drives? Also consider 2.5" SAS drives which were meant for server use...
            The thing that I wonder about is whether or not mechanical abuse can be controlled out. Because laptop disks are subject to more mechanical abuse due to shaking, heat, etc. they tend to die earlier... but if this is controlled out, do they last as long or longer than 3.5" disks? How about 2.5" SAS disks?
            08-05-2022, 09:39 PM
          • eccerr0r
            It's 2025: do you know where your 5¼" floppy drives are?
            by eccerr0r
            Oh wow.
            As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
            Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
            Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
            Weird. Seems the PC drive is having trouble clamping...
            07-07-2025, 12:49 AM
          • claws77
            FX553VE-DM318T(FX553v) not POSTING
            by claws77
            Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
            Gpu - nvidia geforce 1050ti
            Ssd orion o700
            Hdd hgst721010A9e630
            See images
            What's not working right?
            The system does not even POST, display is black,
            LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
            When did the problem happen?
            My laptop had dual boot setup, ubuntu and windows 10.
            It already had a moklist error, that would occur when i tried to boot ubuntu.
            05-17-2025, 04:09 PM
          • eccerr0r
            failing hard drives after sitting for years...
            by eccerr0r
            With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
            Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
            Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
            03-02-2023, 10:33 AM
            HP Z200 Small Form Factor Workstation i5-650 Specification for Upgrade or Repair
            This specification for the HP Z200 Small Form Factor Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z200 Small Form Factor Workstation boardview and Z200 Small Form Factor Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-12-2024, 03:30 PM
