Real or fake?
  • csh
    • Mar 2015
    • 38
    • Croatia
    Real or fake?
    Friend brought some caps to test on my new chinese T3/T4 :-)
    Since he got it from ebay I'd like to hear your opinion.
    I never used caps from ebay out of fear they would be fakes, these look really good to me, but I'm no expert.
    NCC KY 47uF/25V 5x11mm - are they supposed to have these stamps on top of can?
    There isn't eny info about it in the datasheet.
    Measures 49uF with ESR 0.36 ohm.
    Rubycon YXG 4700/16V 16x31mm- There is "K" vent, font and sleeving looks good, bungs also.
    Measuring 4980uF and ESR 0.00
    Probably out of range for the meter?
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Re: Real or fake?
    Those are probably genuine. The Rubycons are almost 10 years old though.
    • SteveNielsen
      Retired Tech
      • 2327
      Re: Real or fake?
      The ESR reading on that tester is not the same as the manufacturer specs because it does the test at a much lower frequency. The docs address that.
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Re: Real or fake?
        2 things.
        1) On the Nippon Chemi-Cons, where the logo is, there is no text.
        2) Also, you have bulging bungs.
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
        • csh
          • Mar 2015
          • 38
          • Croatia
          Re: Real or fake?
          You mean that line "S0624" should be something like 2006, week 24?
          Probably not a good idea to use them even if they are genuine
          • Sparkey55
            • Jan 2010
            • 1523
            Re: Real or fake?
            Who is the Ebay seller if you do not mind saying?
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Re: Real or fake?
              Do you know which seller he got it from?
              There are *some* reputable sellers on eBay (like egekecu, and I think AudJade, among a few others). Just about anyone else in China / HK sells junk, though.
              That said, I agree with Jooo - your capacitors look genuine indeed.
              Well, I don't know about your KYs, but I have some KMGs, 10V 100 uF, in 5x11 size, and they have the same type of stamps on them above, so I think this is normal, if not even a better indicator of them being genuine. Copycats are rarely bothered with small details like that.
              That's because it's a tiny 47 uF cap. No way you can fit text there. Only the big can UCC caps have the text. The rest don't.
              That, I won't dispute.
              But I think that, again, because these are just small 5x11 mm caps. That said, my 10V 100 uF KMGs I mentioned above don't appear to have the bung sticking out like that. Perhaps the KY and KMG can differ a bit in looks, though.
              • SteveNielsen
                Retired Tech
                • 2327
                Re: Real or fake?
                I've used older low voltage caps than that without incident. Higher voltage rated caps may benefit from being reformed if they've been unused for a long time. One example source for reforming:
                http://www.vcomp.co.uk/tech_tips/reform_caps.htm
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  Re: Real or fake?
                  egekecu does sell fakes amid the "genuines":
                  http://www.ebay.com/itm/12-Pcs-Nichi...item439b7f07ef
                  Those capacitors look good, but it isn't difficult to take bona fide Chemi-con and Rubycon sleeves and resleeve different capacitors with them...
                  • csh
                    • Mar 2015
                    • 38
                    • Croatia
                    Re: Real or fake?
                    He brought the rubycons in a envelope that says "PC MotherBoard Capacitor Store" and also http://www.capselling.com, arrived a couple of days ago from ebay. Has a neat logo on it, well, that' a luxury package for ebay seller, i always get the goods in a plain bag. As for The NCC, i would have to check with him, i got it in a plain plastic bag, friend says they are some time older, he would have to check which seller he got them from. But it was also some store that deals primarily in electronics/caps etc.
                    I just searched for that PC MotherBoard store in Ebay, it says owner name is "egekecu" and he has 100% positive feedback
                    That site capselling resolves to some store, first time I see that chinese ebay seller has some independent store.
                    The rubycons are probably genuine, but where do these guys find 10y old caps?
                    Can someone confirm that datecode is ok?
                    Perhaps he can get some of his money refunded for a caps that old.
                    • Cartel
                      • Feb 2006
                      • 112
                      Re: Real or fake?
                      I have some ky series 47uf caps with the code stamped on top too.
                      OP's kinda look crushed on the sides
                      • michael dranfield
                        • Jan 2016
                        • 232
                        • England
                        Re: Real or fake?
                        This is how you can tell if a cap is fake .
                          • 31066
                          Re: Real or fake?
                          lol that's only the big ones.
                          and dont wear out that photo!
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            Re: Real or fake?
                            better quality here:
                            Instead of a blue smurf inside a mushroom, you can have a blue rubycon inside a tin can! Either way, you'll be conned!
                            "pokemon go... to hell!"
                            EOL it...
                            All style and no substance.
                            guilty,guilty,guilty,guilty!
                            guilty of being cheap-made!
                            • michael dranfield
                              • Jan 2016
                              • 232
                              • England
                              Re: Real or fake?
                              Quite correct , the small ones only last 3 days , I bought some once and fitted 2 to a DVD player , the guy brought it back 3 days later complaining of the same fault and the caps had gassed up, they were only on the 5 volt rail !
                              incidentally there were green ones labeled Nichicon
                              If you can put empty cooking oil drums in supporting pillars instead of concrete you can put a small cap in a big can !!!!!
                              • chowder
                                • Feb 2016
                                • 44
                                Re: Real or fake?
                                Aren't Sanyo caps branded Suncon nowadays? Unless these are old or lower capacitance are still Sanyo branded?
                                https://www.ebay.com/itm/10-Pcs-Sany...ETFFMzGGVIZKfw
                                From egekecu's account.
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  Re: Real or fake?
                                  he mainly sells old stock
