O Milwaukee, you wound me.
  • WeaselXP
    • Oct 2015
    • 107
    They said you were reliable and tough. They said you were the best. I kept you around, never knowing the real you. Today, I found you out. Beneath that tough exterior was something common and cheap. I was forced to make some drastic changes...
  • Behemot
    • 4845
    • CZ
    Re: O Milwaukee, you wound me.
    Whats the problem? You buy expensive drill, not expensive charger.
    Besides, even if you do heavy daily work, which you most likely don't, you use it how long, 4 hours a day? Thats gonna last a decade with any caps.
    • WeaselXP
      • Oct 2015
      • 107
      I buy capacitors from you and then you treat me like a cheap hussy. I see how it is. I left the Samxons in place.
      • Behemot
        • 4845
        • CZ
        No, I wonder what do you expect from that. These chargers "do" survive a decade, actually, they usually survive much longer than the drill (or longer than it is economically sensible to buy new battery packs for the drills). There is not too much stress put on them (couple amperes of current), they are used very occassionally, so every single manufacturer makes them as cheap as possible…does it surprise you? Makita, Milwaukee, Hitachi, Narex and many others, every single one of them is the same.
        If they do go bad, they usually cost reasonable money…and are unviersal these days (for most packs of that single manufacturer), compared to those Li-Ion packs. Expensive as hell, they drop like flies and with NO chance for renovation. Good ol' Ni-Cd packs you can renovate always. Not anymore in EU! Introducing new Ni-Cd cells is completelly forbidden since october so we run out of stock and than we are fucked. Panasonic stops making them and we can only smuggle chinese crap afterwards (but there is no sense in that).
        • WeaselXP
          • Oct 2015
          • 107
          I expect that I now have a charger with better ripple current handling, superior filtering and better shelf life at very little cost over the common off the shelf units. Maybe. Either that or I just enjoy recapping.
          • Behemot
            • 4845
            • CZ
            I guess Cause batteries don't mind some ripple, if it's not too much…
              • 31058
              i'm with Behemot on the caps.
              what i dont like is all the yellow glue that will go brown, and the captive single-insulated mains cable.
              • Behemot
                • 4845
                • CZ
                Again…in this case, it will see so little operation time the glue will take decade to go brown. If it was working 10 hours a day than yes, it would be concern…
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  That sounds just like ni-cad! (my experiences)
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    the glue is the real concern.
                    have rebuilt a few of the li-ion packs,a ton of the nicad but dont recall any charger failures.
                    • dmill89
                      • Dec 2011
                      • 2534
                      That is usually a result of cheap "dumb" chargers that overcharge them and severely shorten their life (especially common with the Harbor-Freight/Wal-Mart specials and their equivalents sold else ware) rather than the packs themselves (even cheap Chinese Ni-Cads usually have decent life if charged properly). I have 20 year old Ni-Cad packs for drills that are still good (obviously used with a "smart" charger).
                      • Behemot
                        • 4845
                        • CZ
                        Where does one get such a smart charger? Are they universal? I got one cheap drill, former colleague had the cells replaced by cheap low-capacity chinese. I forgot it for half a day on charger couple times, now they are getting discharged quite fast.
                        On the other hand *some* overcharge is neccessary to balance the cells…
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          That was with a manual charger that I plug in for the times stated, usually 12 hours or 24 hours max! And still get the sudden drop off!
                          Nickel-metal-hydride was doing better! With R/C vehicles, I seemed to get better results with a replacement 9.6 V pack that was Ni-MH.
                          Seems that Ni-cad sux at real high loads...
                          Arc A770 16 GB
                          • Behemot
                            • 4845
                            • CZ
                            Ni-MH has higher energy density. But it is even more susceptible to under and overcharging.
                            • dmill89
                              • Dec 2011
                              • 2534
                              They are generally specific to the brand and pack type.
                              Those are the kinds of chargers that usually cause issues, I have a cheap "beater" harbor-freight drill with a charger like that, I took it apart once and it is literally noting more than a transformer and 4 diodes functioning as a bridge-rectifier, with no circuitry whatsoever to regulate the rate of charging or prevent overcharging, such chargers often cause overcharging and/or cell overheating (by comparison, my DeWalt with a smart charger not only prevents overcharge, but also monitors temp and pauses if the cells get too hot).
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                Why oh why did you dig up a necro'd thread?
                                Follow the white rabbit.
                                • Stefan Payne
                                  • 1267
                                  hu?
                                  After reading the thread title I was expecting something awful. But what I see on those pics looks like a fairly decent powersupply with fairly decent caps as well - and the 'hot one' reasonably sized as well (10mm at least, maybe even 12mm diametre)...
                                  But CapXon? c'mon...
                                  There is a bunch of things out there that is much much much much worse than that. The KF is somewhere in the middle of the cap range, not great but not total garbage either...
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Mr. RJARRRPCGP does that with many other threads. It's just his thing, I guess.
                                    • BigDon
                                      Milwaukee 2890-20 Jobsite radio schematics
                                      by BigDon
                                      Hello guys and gals! I have just received a Milwaukee 2890-20 Jobsite radio for repair. The device powers up and the display works correctly, the buttons function, and the speakers do produce some sound although it is a rhythmic thumping sound instead of the expected usual static. I have been searching high and low for a schematic for the board so I can get this unit back up and running as it should. Anyone have a diagram laying around they wouldn't mind sharing? I would appreciate it. Awaiting the necessary tools to enter the case...some of the screws are recessed almost 4 inches deep in a hole!...
                                      09-13-2024, 08:25 AM
                                      Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                      by sam_sam_sam
                                      I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                      So I have put them on the battery testing machine to drain each battery cell down to...
                                      09-04-2022, 04:45 PM
                                    • labello
                                      milwaukee battery dead
                                      by labello
                                      Hi guys I have this battery for impact wrench milwaukee I checked all of the battery cells and two of them was very low voltage, then I changed but it still gone no led about battery level status ... But i
                                      I misured output pin and i have 19v, then I cleaned and I found this chip broken, can I found it on aliexpress just similar mark (R5F100BCA) or it must be the original one? Thank you so much for the answer...
                                      10-12-2023, 12:54 PM
                                    • spleenharvester
                                      Milwaukee M12-18FC fast battery charger - blown TOP268EG?
                                      by spleenharvester
                                      I bought 5 of these chargers as parts/not working from the same seller. Upon receipt all were dead and had blown or missing 3A fuses. Upon connecting to mains I find there is +330VDC across the filter cap and nothing past that point.
                                      TOP268EG is visibly scorched on all 5 units, with the scorch mark being between drain and source pins. Is this a common fault or have these chargers all been killed simultaneously by a power surge?
                                      Any ideas what else might be damaged? I am in the process of tracing a schematic for these parts
                                      05-07-2025, 09:35 AM
                                    • lordgeny
                                      Nokia 800 tough Ta-1189 no signal
                                      by lordgeny
                                      i have no signal in 3g/4g and gps .
                                      FM and wifi work .....
                                      04-06-2023, 03:42 AM
