Milwaukee M12-18FC fast battery charger - blown TOP268EG?
  • spleenharvester
    • Mar 2010
    • 914
    I bought 5 of these chargers as parts/not working from the same seller. Upon receipt all were dead and had blown or missing 3A fuses. Upon connecting to mains I find there is +330VDC across the filter cap and nothing past that point.
    TOP268EG is visibly scorched on all 5 units, with the scorch mark being between drain and source pins. Is this a common fault or have these chargers all been killed simultaneously by a power surge?
    Any ideas what else might be damaged? I am in the process of tracing a schematic for these parts
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8321
    Very common fault for these type of TOPxxx or LNKxxx switching devices to blow. Same on other battery chargers, washing machines, etc. Look like a T220 with 6 pins. Go to YouTube and search for "buy it fix it Milwaukee" He made a few videos on how to repair it. I have repaired a lot of devices with these type of switcher. Gotta be THE worst switcher ever designed on earth. Take some straight shot, high resolution pictures from top and bottom and upload them here using the attachment function. Most of the time it is the switcher and the fuse are blown, but depending on how the circuit is designed more can be blown too.
    • spleenharvester
      • Mar 2010
      • 914
      Ah yes just found a video with exactly the same fault. Unlike theirs fortunately it seems like none of my 5 have damage to the surrounding components, nothing short/open, diodes test OK. Internal fuses are all OK, it was just the plug fuse blown. Four out of the five units had one or more pads lifted when removing TOP268EG... fortunately it looks like an easy enough jumper repair.
      I'm working on a schematic for both M12-18FC and M12-18C at the moment anyway, will upload them at a later date
        • 31183
        when you see a TOPswitch device, replace the startup capacitor allways.
        i have fixed dozens of settop boxes with topswitches, if the cap dries out they go into a startup loop like a rythmic pulsing - then they go bang!
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8321
          Whatever you do around that TOPxxx or LNKxxx that area too and bottom needs to be squeaky, hospital grade clean. Otherwise it may blow shortly after again. Happened to me before.
          Looks like some oxidized solder problems? A not enough heat and or B didn't use flux and added 60/40 leaded solder first before desoldering.
          Yes, these TOPxxx switches can fail like that and just take the fuse with them, nothing else.
          • lotas
            • Jan 2016
            • 4744
            • Russia
            It happens that they take away the feedback optocoupler...
            • spleenharvester
              • Mar 2010
              • 914
              Replaced the TOP on the first unit today, worked straight away. My plan is to put jumper wire on every pad as I don't trust even the intact ones not to crack in the future.
              Looks messy as hell though. I used 22AWG solid core wire. Will this hold or does it need more cleaning up? Also attached the relevant section of the work in progress schematic
              I am going to reapply conformal coating once it is done too
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8321
                Just make sure this is hospital grade clean on top and bottom between the pins. Otherwise you may be changing it soon again. No speck of dirt, lint or whatever. Good job! These TOPxxx, LNKxxx, TNYxxx are very well known to raise havoc. Most of the time if I find such a switcher and the unit is dead, all it needs is the switcher to be replaced.
                • spleenharvester
                  • Mar 2010
                  • 914
                  Cheers CapLeaker!
                  Did the second one today, here it is after a fresh coating of Ambersil. This one was more of a nuisance as all the pads were shot. Still looks quite messy but probably as best as my shaky hands can do. It initially didn't work because the 10K resistor was open, I'm not sure if it was blown with the initial fault or if I overheated it but it works fine after replacement.
                  3 more to go
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8321
                    Keep em coming! I wanna the the other 3 repaired.
                    • spleenharvester
                      • Mar 2010
                      • 914
                      I've gotten 3.5/5 repaired now. First 3 worked just fine. Fourth one, I knocked a resistor off and accidentally replaced it with a 10ohm instead of a 10kohm and it never worked again, I think I am just going to scrap that one. The fourth one though, M12 slot works fine but M18 flashes green/red on any battery that is perfectly fine on another charger. Anyone run into this before?
                      • spleenharvester
                        • Mar 2010
                        • 914
                        So I determined the RS6334 op amp was dead. Replaced it, the M18 battery began charging... then a few seconds later the whole board went completely dead. No VCC. I think the TOP IC has blown again. I can't be arsed with it anymore so it's going in the bin. 😁
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8321
                          Number 4 charger where you knocked off that 10k resistor R6? That’s the current adjustment pin of the Topswitch.
                          • reessi
                            20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
                            by reessi
                            My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
                            The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
                            The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
                            I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
                            08-22-2024, 08:12 AM
                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                            So I have put them on the battery testing machine to drain each battery cell down to...
                            09-04-2022, 04:45 PM
                          • Petr0x
                            Bosch 12V and 18V chargers modification
                            by Petr0x
                            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                            05-24-2024, 01:00 PM
                            NVDC charger configuration...
                            11-05-2024, 03:28 PM
                          • flat-earther
                            how to prevent a connected charger from draining battery when not charging?
                            by flat-earther
                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                            So the battery is backfeeding the charger and being drained.
                            How can I prevent...
                            08-07-2025, 01:04 PM
