Gigabyte Motherboard
  • TheDragon
    • Feb 2011
    • 69
    • UK - 230 v
    I have an issue with a motherboard and after reading the post here "This is Why You NEVER Ignore Bad Capacitors!" I may need to do a possible repair.
    I have a Gigabyte GA-965P-DS3 rev.3.3 running a Core 2 Duo E8600 with a Corsair 800 watt 80 plus PSU.
    And though it's fairly old by standards the system works fine for my purposes.
    Last few months the system has been starting with a odd half muted beep then the main POST bios beeps. And once or twice the system has made several attempts in booting. And also one stick of corsair memory has stopped working and needed taking out. The stick does not run alone so cannot run any tests on it. It will not run in my friends similar system so I presume it has fried or something.
    Now considering all this and with the supposed long lasting solid caps this board uses. How can I determine if the caps are at fault and if so, how do do I determine which one(s)? And are these caps available to the general public?
    Thank you in advance.
    master hoarder
    • May 2008
    • 12176
    Re: Gigabyte Motherboard
    If the board has all polymers, then bad capacitors are unlikely to be the problem. Posting a picture of your board here is still strongly encouraged, though (use forum's "Manage Attachements" feature, do not link to off-site hosts).
    I suggest you strip the system down to minimum hardware first - i.e. only CPU, RAM, and graphics card (if there in no on-board video only). Disconnect everything else. Even unnecesary cables such as front USB, firewire, etc. Then try some known good RAM (i.e. something that posts in another computer and runs error-free with Memtest).
    Also, open the power supply and check the caps in there as well. Again, pictures of the power supply are also welcome.
    • TheDragon
      • Feb 2011
      • 69
      • UK - 230 v
      Thanks Momaka. This will take a little longer. So will get the photos done asap.
      The Corsair power supply was only installed after the first few beeping issues, as a friend stated that the original PSU that came with the PC case was cheap and probably running under current and/or voltage. So, because it is still under warranty I would rather not break the seal.
        master hoarder
        • May 2008
        • 12176
        Yeah, if the Corsair PSU is less than 2 years old, it's probably okay. Plus, since the symptoms didn't chance with the new PSU, then most likely that is not the problem.
        • mockingbird
          • Dec 2008
          • 5488
          I'm pretty sure it's not the capacitors. Gigabyte used polymer Japanese caps back at that time (And not Apaq like they use today).
          I've had fauly Corsair memory before, I wouldn't count it out. Which model Corsair PSU do you have? Which videocard do you have?
          • TheDragon
            • Feb 2011
            • 69
            • UK - 230 v
            I'll be working on getting some photos for better identifications of motherboard components.
            The other information: Corsair RM750 PSU (i thought it was 800, apologies)
            The Video card is a MSI 7900GS. As I said an old system, but adequate for the needs.
            The RAM is Corsair XMS2 6400 matched pair, one now not working.
            Now you mention the corsair memory issue. These pair were added as an upgrade months after initially building of the system. I wonder if these are the cause of the odd beeps?
              master hoarder
              • May 2008
              • 12176
              Can't know for sure until you try something else that is known to be tested and good.
              I was going through some DDR memory stashes yesterday, and I found a non-working Corsair 1 GB memory stick as well. For all I know, it probably was working fine when given to me a while back.
              Sometimes, you can get a finicky RAM like that running if you lower the frequency. But you can't do that unless you have some good RAM so that you can make your motherboard POST and go in the BIOS to change those settings. So either way, you need some known tested good RAM.
              • mockingbird
                • Dec 2008
                • 5488
                Not the greatest PSU. Taicon and LTec capacitors. But because your load is nowhere near 750w, I don't think it's the problem.
                Bingo! I would test with another videocard. nVidia cards of this generation have known issues.
                The exact same thing happened to me with a matched DDR2 XMS2 pair. OTOH, I have another pair I bought for dirt cheap running fine in a different computer.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Yup. Either the Graphics card or RAM would be my guess. I've had nothing but trouble with Corsair RAM over the last few years. It got to a point where not one module we got would run stable at its stock settings. We would either increase the voltage or replace it with RAM from another brand (usually Kingston). Otherwise, it would cause random BSoDs.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    7-series have a tendency to be FZ'ed!
                    (I know that at least with eVGA, I haven't spotted any "FZ" cap with an 8-series and later.) (With a possible exception of 8400 and 8600, maybe 8500)
                    I'm afraid that with a 7-series, even high end versions got FZ caps!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                      master hoarder
                      • May 2008
                      • 12176
                      I don't know much about e-VGA and the 8 series, but I can tell you that XFX and a few others definitely still used FZ even on the 8 series. I think the 9 series is where most everyone learned to stay away from them.
                      Negative.
                      The 7800, 7900, and 7950 all had nothing but polymers (or high quality Japanese capacitors at the very least). It is with the mid-tier cards such as the 7600 that you could find FZ. e-VGA was certainly one of them to use FZ. I'm not sure about XFX, but I think they might have, too, along with PNY. Probably only Saphire and a few others didn't. And, of course, the low-end tier (7300 and 7200) was again manufacturer-dependent, but crappy caps weren't uncommon on those either.
                      That aside, the 7900 and 7950 did suffered from die-separation (and thus artifacts or "no video" symptom) more than any of the other 7 series. So yeah, the random beeps could be from the 7900 in the OP's PC.
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        I have a few BFG 7800 agp cards with no FZ just Japanese polymers.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          [snip]
                          That depends on the manufacturer of the card and has nothing to do with the GPU used. I don't think MSI was ever stupid enough to put Sacon FZ on any of their video cards - not even low end 7-series. At least I've never seen any MSI cards with FZ caps.
                          I have seen a Galaxy 7950GT which had them, though (and it only lasted 3 months)
                          • TheDragon
                            • Feb 2011
                            • 69
                            • UK - 230 v
                            Sorry guys for the late reply. Looks like my PC packed up altogether. Won't boot up at all. Tested power supply and it's fine. I'm putting it down to bad RAM modules, but need time to investigate.
                            For the moment I will leave this problem the side and just use my laptop.
                            You all mentioned the graphics card. Well, that had all solid capacitors, assume it would not be the issue?
                            Thanks for the info. A possible future repair, for educational purposes.
