Will this recap work ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    So I brought a ibm eserver 225 off ebay it has a mixture of nichicon hm panny fj and ucc kzg, as I was looking aorund I saw that some of the caps were not soldered through the board but to the top copper pads on the surface, I was just wandering will this work or should I remove the board and resolder them ?
    The server works fine btw.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Will this recap work ?
    Someone may have done a repair job? If the date codes on the those capacitors that stand up are different from the others, then you have a good indication that someone did a repair job.
    --- begin sig file ---
    --- end sig file ---
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      If it isn't too much trouble you might want to pull it and inspect the bung to make sure it's a legitimate Panasonic capacitor. I know Hermei uses Panasonic's vent stamp. It'll function like that, the ESR will just be a little bit higher
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hello thank you for the replies it is a genuine panasonic fj the bung is fine I bent over the cap and its good, so will the repair be fine ?
        • Agent24
          I see dead caps
          • Oct 2007
          • 4926
          • New Zealand
          It's not done properly, but it's not too bad either. I'd say it's fine though.
          -David VanHorn
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok thank you all
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              I've never seen panasonic fj in that color before
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                It all looks genuine I can take pictures if you want ?
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  +1
                  Originally posted by pentium4
                  i've never seen panasonic fj in that color before
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    +2
                    Follow the white rabbit.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Agreed. Either it's not an FJ, or someone has recapped it with fake caps. Real FJs are black with gold markings
                      • lti
                        • May 2011
                        • 2547
                        Panasonic M series (general purpose 85°C) uses that color scheme.
                        Also, having the caps raised off the board and soldered like that makes me think the board was damaged while removing the old caps and that was the only way they could get it to connect to the correct trace.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          They appear to be genuine and I tested them with lcr meter at work and they seem perfectly in specification.
                          I re-soldered them all works fine.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Ah. It's an M series, not FJ. These are not suitable for use on a motherboard.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Ohh are they dam just put the board back in I will used nichicon hz thank you all.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4926
                                • New Zealand
                                That doesn't mean much. Even the worst-of-the-worst capacitors like Sacon FZ would measure OK when they came from the factory. Besides, an LCR meter won't generally test ESR which is more of a concern, especially on motherboards.
                                The real test is how long they last, and this won't be very long for low grade capacitors, fakes, or general purpose ones (even if they are high quality) when used in circuits where Low ESR is really needed.
                                -David VanHorn
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  I know but I have seen fake caps that claim to be a certain value and aren't, any way I will replacing them with nichicon hz as these aren't the correct esr.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Got around to recapping this board, used sanyo wx works fine had to keep one of the capacitors floating as there is a capacitor lead blocking the hole and I cant get it out with out ruining the trace so I had to keep that one floating but it works fine.
                                    Pictures showing the new capacitors.
                                    • Jonny Accelerant
                                      Banned
                                      • Aug 2014
                                      • 205
                                      So I brought a ibm eserver 225 off ebay it has a mixture of nichicon hm panny fj and ucc kzg, as I was looking aorund I saw that some of the caps were not soldered through the board but to the top copper pads on the surface ...
                                      I just read the whole thread. Seems like someone went to a lot of trouble to do a half-assed job? Did the one blocked lead whole cause the whole situation? I got the wrong caps part, and I don't really understand how a broken lead in the pc board is a permanent situation (desoldering iron?), but I still don't understand why they are setting those caps high off the motherboard like that as it seems to me that it would have been easier to solder them all the correct way on the back-side of the board, so at this point after reading the thread I'm "wtf?" and would appreciate a forensic analysis of how this motherboard came to this condition.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        Jonny, i've seen it before and even recommended on this forum. The person who originally recapped the board possibly didn't have a decent enough iron to remove the old caps. They are either cut or pulled of the board leaving the legs to solder to.
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • resistor83
                                          lenovo 330s-15ikb, led num lock key always on and numbers don't work
                                          by resistor83
                                          hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                                          I tried updating the bios but the problem remains
                                          https://s...
                                          05-29-2025, 08:06 AM
                                          DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
                                          by sam_sam_sam
                                          I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
                                          If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
                                          One —>the LEDs might be bad
                                          Two —> the buck converter or regular might be bad
                                          Three —> the controller might not...
                                          08-08-2023, 05:12 PM
                                        • Rhaverz
                                          My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
                                          by Rhaverz
                                          Good afternoon friends
                                          I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
                                          I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
                                          I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
                                          03-30-2023, 03:56 PM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
