I have a faulty MS-6340 mainboard in a five/six-year-old noname PC bought from Staples (UK) in around 2000. The PC started showing weird symptoms only a couple of years after I bought it, but at the time I had other stuff to deal with so I just stuck it in a cupboard and used another PC. Now I've dug the Staples/6340 out again, cleaned dust off the m/b (bristle brush/Hoover) and got it going. But the erratic working is soon evident (BSODs, fatal exception errors, freeze-ups, sudden reboots). I got it working for long enough to wipe the hard disk and reinstall 98SE from scratch. I also used System File Checker/Scandisk/Scanreg, so I reckon the software is okay. This is a basic machine. No NIC. No cards other than the graphics card. I've disabled the onboard sound chip. Often I switch the PC on, the green power LED comes on, the CPU and power supply fans come on, but there is no POST, zilch. Then I power down the machine, pull the power cord, tweak* one or two of the large caps, and ten-to-one this lets the machine reboot again - till the next time the failure occurs.
I suspect the capacitors are faulty. See my pics at http://www.visualbasic.fsnet.co.uk/Capacitors-1.jpg and .../Capacitors-2.jpg. The tall ones marked (A) in the first jpg don't look too healthy, do they? (The ones at (B) look okay.) The big question: Can I replace these myself? I have soldered circuits before and can use a solder pump! But I am not an electronics wiz (motor fitter by trade originally). Is this a difficult job? Since I could probably buy a replacement m/b for £50, it may not be worth the hassle. I have read elsewhere that m/b's have several layers, so maybe soldering in new caps is not something that beginners can do. Any comments are welcome!
* gently rock cap 1 - 2 mm from side to side
