For those that swear by KZG... :(
  • yanz
    • Nov 2004
    • 910
    #41
    Re: For those that swear by KZG...
    KZJ suffer a bad fate too
    well, we still have some deer-lookalike psu with each rail using 2x 1800uF/16v KZJ and none of those PSU have failed yet. psu are some p4s and athlon xp in our net cafe. i glad i conducted that experiment in that 2006. it's been 3 years..
    • yanz
      • Nov 2004
      • 910
      #42
      only one is pic showing.. and i would like to know what capacitance and voltage are those black KZJ? usually chemicon use three line date code style, and those KZJ are just different, they use 2 lines...
      • yanz
        • Nov 2004
        • 910
        #43
        oh wait, maybe it just the angles..
        • c_hegge
          • Sep 2009
          • 5219
          These are some leaking Chemi-con KZG from a HP Motherboard. I replaced them with panasonic and the mosfets gave off smoke. I then discovered two pins on the CPU socket were touching!
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Yup, thats lga775 for ya. Great idea intel.
            • nasdat
              • Jul 2009
              #46
              Gateway Profile 5 => 17" & 19" nVidia 5200 video board ~ has [4] KZG 6.3v 1500uF ~ ambient cooled card => [1] only slightly bulged on bottom & proved to
              be the culprit ~ undocumented troubleshooting of these machines // removing the
              video board enables intel northbridge video [*note* the 15" versions all came stock
              without the nVidia card & the Profile 5.5 have a completely different system board
              and also a completely different ATI video board in the same case]
              • larrymoencurly
                • Oct 2004
                • 960
                Did Chemicon ever fix the problem with KZG and KGJ caps?
                I just replaced several KZGs, even though none bulged or had ESRs above 0.01 ohm.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  That should have been KZG & KZJ.
                  No one official has even admitted there is a problem.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • laser
                    • Jan 2009
                    • 29
                    #49
                    personally I had several problems with KZG series
                    in my case I see bulged 820mf, 2200mf and 3300mf /all 6.3v
                    (specially the 3300 mf is the worst)
                    I recommend avoid and destroy chemicon KZG series like the plague
                    /thread
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      #50
                      i need to post my video of several thousand new kzg being poured into the dumpster.
                      i got them in a surplus buy and found they cant even take power supply duty.popped in 6 months.even crapxon last longer than that.
                      • LLLlllou
                        • May 2011
                        • 201
                        Please do!
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          I hate KZG. Intel still uses them on some of their new boards like their DH61BE on the VRM...and almost every Dell computer that was made from 2005-2008 that comes in usually has bad KZG
                          Yes please do
                          • c_hegge
                            • Sep 2009
                            • 5219
                            You let me down big time. You should have poured them onto a fire
                            • cheapie
                              null
                              • Jul 2010
                              • 849
                              Hmm... I have a motherboard full of KZG, and it's been running almost 24/7 since 2007 with no issues. As for the power supply, the original Liteon power supply died (low 5vsb), then the Hipro replacement died (same problem, visually confirmed bad caps on this one), then the Dynex replacement for that died too (erratic operation). Now, I'm running an ancient Astec out of a broken Gateway from 1999. It's full of Nichicon (LQ for the primaries, PX(?) for almost everything else). It should last a while. These caps are so old that the primaries say "CE" (French for "Electrolytic Condenser", covered in another thread) and refer to the voltage rating as "WV" (working voltage)...
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                #55
                                ^ You are fortunate that those KZGs have not failed yet after all that time, though it's possible they have since they can easily fail without any indication in terms of sensory (and your computer may not POST if you reboot...). KZGs will inevitably fail because there is something fundamentally wrong with their electrolyte (a chemical process takes place that cannot be deterred in the long run), somewhat unlike mediocre (at best) Taiwanese capacitors where it's more the impurities of the aluminimum/foil that leech into the electrolyte and cause failure (which can be at least prolonged if stress and heat is kept away from such capacitors). However, unlike cheap Chinese and Taiwanese capacitors, KZG still have good aluminum and foil and besides their electrolyte are high quality and Japanese so if you keep them away from heat and stress they could last a while too (wouldn't be surprised if they didn't, though...)... I'd recommend replacing them all either way.
                                Not surprised they failed, the VRM circuit is one of the most stressful parts of the motherboard (if not the most).
                                • Jooo
                                  • Oct 2011
                                  • 222
                                  • Finland
                                  #56
                                  Just saw this review, seems like Asus still likes Total Krap and KZG
                                  http://forums.tweaktown.com/asus/510...od-review.html
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    #57
                                    Another ASUS RMA on just a year old board today... Yesterday I got a P5RD1-VM full of bloated KZGs... Lasted 7 years though I think.
                                    Avoid motherboards with APAQ polymers like the plague. Also, I don't trust the quality of HEXFETs Gigabyte uses...
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3579
                                      • USA, Unsure of Planet
                                      #58
                                      "HexFET" was a trademarked name of International Rectifier, until they sold that part of their line to Siliconix (Ironically!) about 5 years ago. Siliconix is part of Vishay. Are you seeing problems with Vishay-Siliconix parts of the older HexFET type? The reason IR sold the line is because it was basically at the limit of what the technology could do - especially in R(DS On). AFAIK, modern high-performance parts don't use any form of the hexagonal cell design technology.
                                      PeteS in CA
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        I cross-referenced Chemi-Con KZG to new KZN series (if you can get them!), but even though ripple current for KZN is slightly better, the ESR is not as good as KZG.
                                        • mockingbird
                                          • Dec 2008
                                          • 5484
                                          #60
                                          Interesting...
                                          Just guessing that they're the weakest link on Gigabyte boards, that's all... I have no other basis for my assumption since I can't imagine what else would cause Gigabyte "Ultra Durable" boards to conk out... On Asus boards I'm pretty sure that it's those Apaq Polymers degrading over a short amount of time.
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                            Copy DMI info easily with Hex editing software and Macro script
                                            by SMDFlea
                                            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                            02-28-2023, 02:14 PM
                                          • ZixuTech
                                            Dell XPS 15 9570 - LA-G341P - Power cycling after liquid damage and blown ISL88738
                                            by ZixuTech
                                            I am dealing with this LA-G341P, which had heavy liquid damage around the Audio board, Battery charging circuit. I went and cleaned liquid areas and left the audio board disconnected.
                                            It had blown PQ1900/02/3 as well as a trace on PU1900. I replaced all 4, and now it turns on and switches off. With a connected battery, it turns on and stays on for a while, even loading the system, then cuts off suddenly.
                                            Charger only - without a battery, the PQ201/PD200 area gets hot. I can see the chipset and CPU also warm up for a second trying to pull up to 2A, then cust off....
                                            10-22-2022, 10:33 PM
                                          • b0n3v
                                            [Help]Reading EC - T14 G1 AMD with RT809h
                                            by b0n3v
                                            Hello everyone!
                                            I try to read the EC ITE/IT8300FN where the bios password is stored.
                                            The laptop is Lenovo T14 G1 AMD Ryzen 4650U, the MB is NM-C801.
                                            I can't read the chip with RT809H with ITE board and PFC cable. Might be I need to do something more to enable programing mode(SPI Enable?).
                                            I saw the post in another forum for T14s AMD (different MB but same EC configuration and pinouts) and one user successfully read and write the the same chip with SVOD3.
                                            Some details what i did:
                                            Battery and CMOS battery is unplugged.
                                            I click Read and then...
                                            05-15-2023, 04:02 AM
