For those that swear by KZG... :(
  • Fast Alpha
    • Feb 2013
    • 245
    #61
    Re: For those that swear by KZG...
    Is this a good motherboard ?
    http://*************/a/img811/2263/p1000603e.jpg
    I'm slowly building a new rig.
    http://www.hse.gov.uk/pubns/indg305.pdf
    • mariushm
      • May 2011
      • 3799
      #62
      Yes, it's good.
      • mockingbird
        • Dec 2008
        • 5484
        #63
        It's so-so.
        • cheapie
          null
          • Jul 2010
          • 849
          Originally posted by Wester547
          ^ You are fortunate that those KZGs have not failed yet after all that time, though it's possible they have since they can easily fail without any indication in terms of sensory (and your computer may not POST if you reboot...).
          *snip*
          Not surprised they failed, the VRM circuit is one of the most stressful parts of the motherboard (if not the most).
          At least mine aren't in the VRM (it has Nichicon for the CPU and NB power and Rubycon for the SB power). The KZG seems to be powering the onboard NIC and such.
          • Fast Alpha
            • Feb 2013
            • 245
            #65
            Originally posted by mockingbird
            It's so-so.
            7 stand off holes in motherboard don't fit any ATX case, and you failed to spot it.
            • mariushm
              • May 2011
              • 3799
              #66
              The motherboard will fit in any decent case, and that antec (if you have the antec) is one. It's a standard ATX motherboard and the location of the holes are standard according to ATX, so you have a hole for a standoff for that 7th motherboard hole.
              The case has screw holes for several motherboard styles. You take the motherboard standoffs (the gold things) and you put them in the proper holes on the case, then you install the motherboard.
              Read the manual :
              See page 6, it says the case comes with 9 of those standoffs, 4 are preinstalled but removable
              The motherboard SHOULD NOT have any traces or contacts in the spots where you usually have a standoff for the ATX standard, if you have a standoff touching something on the board, that standoff is in the wrong place. But just don't put a standoff if there's no need for one.
              Anyway, we've been going in this thread for a page or so already, and it has nothing to do with the KZG series capacitors. I will suggest to the mods to split the off topic posts into another thread.
              • c_hegge
                • Sep 2009
                • 5219
                Most cases don't have a standoff for that 7th hole (closest to the front). It's not a problem, though. Just leave the screw out. The other 6 screws are fine.
                • BillV
                  • Sep 2013
                  Here's a shot of my Asus A7N8X board. I bought it new in the box about two years ago. It suddenly died about 3 months ago. Inspection revealed that seven of the eight 3300 ufd KZG capacitors were buldging. The other capacitors on the board are OST RLX except for two Rubycon MBZ's, all of which look OK. I recently bought a used A7N8X that has MBZ's instead of the KZG's. Otherwise it's the same. It seems to work OK. I can't find any date code on the board or its box that might indicate when Asus changed vendors.
                  • Behemot
                    • 4845
                    • CZ
                    #69
                    Just repalce with some verified caps and will be as new.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      And if you don't want to be doing it again, replace the OST too
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Looks like a 2004 and I had a feeling that it was likely a 2004 when I saw a sticker said that the board was manufactured in China.
                        2004 A7N8Xs are usually China and have KZGs.
                        2002s and 2003s are more likely to be manufactured in good ol' ROC.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                          by momaka
                          03-12-2025, 03:42 PM
                        • flibidy
                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                          by flibidy
                          I have here a Magnum IA.100 which belongs to my parents.
                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                          What Ive done........
                          01-01-2025, 01:26 PM
                          Copy DMI info easily with Hex editing software and Macro script
                          by SMDFlea
                          Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                          Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                          02-28-2023, 02:14 PM
                        • ZixuTech
                          Dell XPS 15 9570 - LA-G341P - Power cycling after liquid damage and blown ISL88738
                          by ZixuTech
                          I am dealing with this LA-G341P, which had heavy liquid damage around the Audio board, Battery charging circuit. I went and cleaned liquid areas and left the audio board disconnected.
                          It had blown PQ1900/02/3 as well as a trace on PU1900. I replaced all 4, and now it turns on and switches off. With a connected battery, it turns on and stays on for a while, even loading the system, then cuts off suddenly.
                          Charger only - without a battery, the PQ201/PD200 area gets hot. I can see the chipset and CPU also warm up for a second trying to pull up to 2A, then cust off....
                          10-22-2022, 10:33 PM
                        • b0n3v
                          [Help]Reading EC - T14 G1 AMD with RT809h
                          by b0n3v
                          Hello everyone!
                          I try to read the EC ITE/IT8300FN where the bios password is stored.
                          The laptop is Lenovo T14 G1 AMD Ryzen 4650U, the MB is NM-C801.
                          I can't read the chip with RT809H with ITE board and PFC cable. Might be I need to do something more to enable programing mode(SPI Enable?).
                          I saw the post in another forum for T14s AMD (different MB but same EC configuration and pinouts) and one user successfully read and write the the same chip with SVOD3.
                          Some details what i did:
                          Battery and CMOS battery is unplugged.
                          I click Read and then...
                          05-15-2023, 04:02 AM
