Samxon recap
  • quattro
    • Jan 2006
    • 26
    Samxon recap
    Just want to thank 'Big Pope' for the caps he sent me. I have successfully recapped a motherboard and PSU, and although I haven't tested the MB yet, the PSU runs.
    I just have some questions:
    I replaced a handful of caps on a rebranded Deer PSU, as although it didn't show any major problems before hand, the caps were bulging. I had hoped this replacement would have fixed an issue I did notice, namely, a multimeter test showed only ~ -10.5v on the -12v rail. Even at this level, it had still powered a system fine for a long time.
    The MB I did recap was an old socket A Soltek, and ill give it a go as soon as I get some ram for it. But there was also another newer socket A MB, and I had planned on fixing that too but somehow I ended up one cap short from those Big pope sent. Either I lost it, or not enough were sent, I'm not sure as I didn't count them before is started (but I can't complain, free is free), regardless, it leaves me one cap short of a functioning MB which is very annoying.
    Some of the caps I put in the PSU are the same as I need for the MB, given its weak voltage, would you recommend I ditch the PSU? Or can someone help me out with a donation?...
    Thanks in advance
    Tim
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: Samxon recap
    What PSU? Any photo here? Do you have reverse the voltage (position and negative)?
    Or make a wrong voltage caps(12v rail used with 6.3v or 10v)?
    Thanks.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
    • quattro
      • Jan 2006
      • 26
      Re: Samxon recap
      Its a 'Hyena LC-A350ATX' if that means anything.
      To clarify, this problem existed long before i replaced the caps, i had hoped it was due to the bad ones, but obviously not.
      • Big Pope
        Approved Vendor
        • Dec 2005
        • 426
        Re: Samxon recap
        Oh, i see.
        I think bad circuit is happened in this PSU.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Re: Samxon recap
          I would dump the PSU if its the least bit questionable. A flaky PSU is your worst enemy when battling a finicky PC.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • quattro
            • Jan 2006
            • 26
            Re: Samxon recap
            Ok, so get rid of the PSU.
            The thing is i dont really want to spend too much getting this system going, so that rules out a branded PSU. Would an unbranded cheap psu do the job? At least for a while?
            • Shroomie
              • Apr 2006
              • 356
              Re: Samxon recap
              I'd pick up a 300 watt Fortron or the like for it. The new ones don't last forever, but even if it does fail, the rest of the computer will be OK. You can get one for around $30 US shipped, I don't know how things are down there.
              You know there's something wrong when you open up a PSU and are glad to find Teapos.
              Why I don't buy cheap cases!
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Re: Samxon recap
                pull the new caps and shitcan the hyena.junk.
                • quattro
                  • Jan 2006
                  • 26
                  Re: Samxon recap
                  Thanks for the replies,
                  Yeah, i think thats what ill do. But im still stuck with what to replace it with. No signs of 'Fortron' here, available PSU brands in the price range im looking at are:
                  Hyena (again?), iCute, Excel, Colorsit...
                  Theyre probably all the same thing...
                  Would it really be that bad getting one of those? Do they suck out of the box? There is a 350W Hyena, the same model number as the broken one, with a 2 year warranty...
                  • tiresias
                    • Feb 2006
                    • 489
                    Re: Samxon recap
                    I'm afraid so. Are you not able to find any of the (older, even) Enermax-branded models? They can be quite reliable (in my experience) and generally not too expensive...
                    • quattro
                      • Jan 2006
                      • 26
                      Re: Samxon recap
                      New Enermax's are too much, but i did find this:
                      http://www.trademe.co.nz/Computers/C...n-67863153.htm
                      What do you think? Can 2nd hand old PSUs, even branded, be trusted?
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        Re: Samxon recap
                        i would take it, enermax are good for several years (e.g. at least 3 to 4 years, if not longer). The only od thing on them, is the very bad fual fan desing, wich is not more than an air short, e.g. it blows the warm air back in to the case.
                        • tiresias
                          • Feb 2006
                          • 489
                          Re: Samxon recap
                          That does depend on which model we're dealing with though - the "coolergiant" series for example has a standard "push-pull" setup with 80mm fans .
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            Re: Samxon recap
                            grab that enermax and do a premptive recap.they are ok.
                            pull those new samxon from the hyena and put em in the enermax.
                              ASUS P5GC-MX motherboard recap
                              by momaka
                              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                              So here is what the motherboard looked like with its original caps:
                              CPU VRM area up close…...
                              01-27-2021, 11:59 PM
                              no-name Radeon 9600 XT recap and cooler
                              by momaka
                              I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                              This one was actually suggested to me by ChaosLegionnaire....
                              11-06-2020, 07:54 PM
                            • chth96
                              Can I replace KME cap with Samxon GF cap?
                              by chth96
                              Hello.
                              I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                              Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                              I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                              04-17-2024, 07:11 AM
                            • varunviolin007
                              Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                              by varunviolin007
                              Hi guys,
                              I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                              I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                              Looking for someone experienced with older PC boards who uses...
                              07-29-2025, 11:53 PM
                            • Foetuss
                              Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                              by Foetuss
                              Hi all
                              Hope this is in the correct place.
                              I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                              Could use some double checking to see if I'm not doing something stupid .
                              Pictures of the boards are attached.
                              What I will be replacing with what : (planned)
                              Soltek Golden ::
                              4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                              6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                              01-18-2025, 11:44 AM
