High CPU Usage When Using USB 2.0 Storage.
  • Musafir_86
    • Feb 2006
    • 6
    Dear Friends,
    -My onboard USB port (USB 1.1) consume a lot of CPU Usage (up to 100%) when any high speed (USB 2.0) Mass Storage Device (such as thumbdrive/external harddisk/digital camera) connected to the port(s). Also, I had installed another add-in PCI USB 2.0 card (2 ports) using VIA VT6212L chip, but still have the problem.
    -I've tested using WinME and also WinXP SP2, but the problem still persist.
    -FYI, some years before, I had accidentally short-circuit two USB cable, both connected to the onboard ports (the motherboard using VIA Apollo Pro chipset (VT82C686 & 686A)). One of them had the plastic half-melted (it's like a handphone charger - the purpose is solely supplying power to a USB device).
    -I've seen that some of the capacitors have been bulged but not leaked (yet). Then, I had refer to (1) http://www.pcstats.com/articleview.cfm?articleID=195 (2) http://www.siliconchip.com.au/cms/A_30328/article.html (3) http://en.wikipedia.org/wiki/Capacitor_plague for more info. Could it be the cause? If so, can it be repaired (replacing the capacitors) by myself?
    -Or could it be an incorrect settings in the BIOS? If so, can anyone give me some tips?
    -As for the symptoms, this is the only that I've detected so far. My system run smoothly for hours under 100% CPU load; only a little sluggishness under (very) high harddisk activities.
    -My system specs :-
    Motherboard : Soltek SL-65DVB (BIOS Rev J8.2)
    OS : Windows XP
    CPU : Pentium 3 1000EB
    Memory : Apacer 256MB PC133 CL2
    -Thank you.
    Best regards,
    -Musafir86.
  • Musafir_86
    • Feb 2006
    • 6
    Re: High CPU Usage When Using USB 2.0 Storage.
    Here's how my voltages status during various conditions (refer to attached pics) :
    (1) First pic ("01.jpg") - under normal CPU load, just some downloads running (FreshDownload & BitComet).
    (2) Second pic ("02.jpg") - during files transfer from PC harddisk to external USB 2.0 portable harddisk. I just managed to get about 2.0MB/s (around 1.9-2.1MB/s) on a USB 2.0 connection.
    (3) Third pic ("03.jpg") - an alphanumeric keygen running while FreshDownload is building (and moving) output (completed) 215MB file from TEMP directory in drive C: to destination dir in drive D: (same disk). This is quite a high disk activity, I think.
    (4) Fourth pic ("04.jpg") - the condition after the previous action (1 minute later).
    -Note that the rating for my Pentium 3 1000EB is 1.76V. I noticed that while Core, +3.3V, & +12V tend to rise when the CPU load is high, the +5V seems to decrease on the same condition.
    -Also, under high CPU load for a long time (e.g. playing FIFA 2005 for 2+ hours), the system never hangs.
    • Musafir_86
      • Feb 2006
      • 6
      -Also, just ignore the second temperature reading (which says 144C); this obviously some error in the SpeedFan app.
      -Musafir_86.
      • MD Willington
        • Sep 2004
        • 702
        Actually the error you describe can also indicate the hardware channel for that sensor is not implemented, and speedfan is reading a non-existant sensor... Same thing happens on some of my mainboards.
        No surprises on the Soltek board needing a recap, Soltek was handing out capacitors for FREE while they were still a motherboard manufacturer, they have since left the manufacturing business.
        Ya'll think us folk from the country's real funny-like, dontcha?
        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          for your usb2 card you need xp sp2
          high cpu is a windows problem usually, i am suprised it happens accross all os you have tried
          i would not expect there to be a bios setting to help
          can we see a pic of the bulging caps. if they are bulging then it is a waste of time to troubleshoot problems because badcaps can cause many wierd problems. the board needs to be recapped and yes you can do it yourself, please read the faq and then come back with questions, we are pleased to help you do the job. after recapping then it is good time to look at issues which remain.
          • Musafir_86
            • Feb 2006
            • 6
            -Hmm, I'd like to take the pics, but for now I don't have access to any (good) digicam yet. FYI, there about 6-7 caps around the CPU socket that are bulged, & there is (something like) rust on the upper part of the caps.
            -The attached picture I got from the Soltek China website; note the bulged caps are mostly around the CPU socket & one near the DIMM slot/IDE connector (circled red). Again, this is NOT my actual board.
            Thanks.
            -Musafir_86.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              its gotta be taken out of service and recapped soon
              • Musafir_86
                • Feb 2006
                • 6
                -Hmm, I'd like to give it a try too (when there's enough time). Then, I'll report the result back.
                Musafir_86.
                • RJARRRPCGP
                  • Jul 2004
                  • 6301
                  Then by now, processor taxing tasks will fail. Thus crashes are right around the corner when gaming and thus if you continue to use it before replacing the caps, don't be surprised if you get a BSOD!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    or a board which is dead as a dodo
                    Soltek annouce 17/Feb/06
                    Soltek SL-945P-L Motherboard ????
                    (Pentium 4/Pentium D, Socket 775, Intel 945P, ATX, DDR2, 1066MHz FSB)
                    Description: The SL-945P-L with Intel 945P chipset is an high-powered solution for LGA 775 Intel Pentium 4 CPU. It supports Intel dual-core CPU and provides 1066 MHz FSB, PCI Express architecture, Serial ATA interface, high performance integrated graphics engine, dual-channel DDR memory, 8-channel HD Audio CODEC and LAN. It also supports Intel EM64T and EIST technology, which provides you a 64-bit environment and an energy saving solution.
                    • larrymoencurly
                      • Oct 2004
                      • 960
                      On an ECS K7S5A Pro or P4S5A2 mobo, I shorted a USB ports' +5V to ground through a rear bracket adapter, which got hot enough to slightly melt its vinyl. However it didn't seem to suffer damage and still works fine.
                      I have an NEC-based USB 2.0 card that was zapped when a device was plugged or unplugged, and not by high voltage from static. Ironically the only thing damaged was the LM3526 chip that was supposed to protect against such damage, possibly because the capacitor across the +5V and ground of the USB port was undersized or of low quality (Maxtor brand NEC USB 2.0 card uses 220uF, this one 100uF). The chip maker recommends a tantalum cap of at least 120uF.
                      Every time I back up to a USB 2.0 drive, my system becomes sluggish, and it seems that this is a common problem with USB. Is there such a thing as a USB adapter that does DMA transfers?
                      • Musafir_86
                        • Feb 2006
                        • 6
                        Hello Everybody!
                        -Sorry for this very late reply. Actually, I've (near) completely forgot about this thread.
                        -Hmm, I had replaced the bad capacitors about 3/4 month ago. The one who did the replacement is an expert (from my view) electronic technician that I know in my hometown. The replaced caps are a bit bigger than originals - there're 6 caps totals.
                        -The good news is : the problem gone! But, CPU usage is still a bit high than a P4 system (between 15%-45%) - maybe because old CPU & mobo, I guess. Another good news : this is actually my uncle PC, he rarely used those USB ports for large data transfers.
                        -Anyway, thanks for all advices & comments.
                        Best regards,
                        -Musafir_86.
                        • WNG
                          • Sep 2006
                          • 354
                          I've discovered that VIA chipped USB 2.0 pci cards don't work well in older motherboards with VIA chipsets providing USB 1.1 ports.
                          IMAGINE THAT!! VIA couldn't even get their own products to play nice.
                          Once a device is attached to the the USB 2.0 port(s) the memory transfer bandwidth takes a dive! Usually down 75% of maximum transfer rate.
                          The entire system slows down.
                          I've only been able to restore performance by rebooting the system after removing the USB drive device. This has occurred in Win2k and WinXP.
                          Place the VIA chipped card in a system with Intel chipset, and all is fine.
                          Place a NEC chipped card in the VIA systems, and it's also fine!
                          Go figure.
                          “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
                          We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
                          • Rainbow
                            • Aug 2005
                            • 1371
                            VIA add-on USB cards suck.
                              Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                              by sam_sam_sam
                              I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                              I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                              I tested the battery cells there are installed right now and they are testing good with no issues that I...
                              02-04-2025, 08:08 PM
                            • DynaxSC
                              Extreme High Current & Low Voltage Short Killer ??
                              by DynaxSC
                              Hi Folks
                              I'm looking for a extreme high current short killer solution for a reasonable cost.
                              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                              After taking off the socket, the shorts dissappear again.
                              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                              10-15-2024, 10:13 AM
                            • harp
                              high voltage high resistance marking resistor
                              by harp
                              Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                              08-26-2024, 01:42 PM
                            • karatzdi
                              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                              by karatzdi
                              I know some might say... just buy another one. Sell it as parts..!
                              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                              Spent some time downloading the Service...
                              06-11-2024, 08:38 AM
                            • ictc
                              Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                              by ictc
                              I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                              Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                              The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                              02-25-2025, 12:15 PM
