Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
  • ictc
    • May 2015
    • 46
    • Italy
    I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
    Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
    The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset signal always stay high in this case? Pressing the buttons has no effect, and the display remains completely off.
    Any insights would be greatly appreciated!
  • truclacicr
    • Apr 2019
    • 353
    • australia
    RESET_ should start at 0V immediately after power-on, and then rise to 3.3V. It should then remain at 3.3V until the next power cycle. You could always short RESET_ to ground to restart the player, if you suspect that it is not resetting properly.
    • lotas
      • Jan 2016
      • 4854
      • Russia
      Connect to the UART (TX, Rx, GND) and through the terminal see what it displays, the problem may also be in the NAND memory, a firmware failure...
      Also check the signal lines on USB, HDMI and LAN for resistance relative to GND.
      • Diah
        • Feb 2013
        • 6560
        its much error at micro switch at CD unit... try to do drive CD in manual with yours finger to rool it up down and the laser head to have up with little click... then inser it in wall see if it reject the CD out
        • ictc
          • May 2015
          • 46
          • Italy
          Thank you all for your input, though I still have some doubts. No evidence of shorts was found on the ETH and HDMI ports. However, I did notice signs of corrosion on R190 (a large 0-ohm resistor connected to HDMI_VCC) and a small mark on the PCB that made me think a spark might have occurred. You know when, after a spark, the PCB shows a halo with various color gradients, likely due to the evaporation of some metallic oxide? In this case, the phenomenon is almost imperceptible to an untrained or inattentive eye, and I might have overthought it or exaggerated its significance. There's no actual damage to the copper, just a very slight discoloration on the solder mask, which can probably be removed with IPA. The resistor measures fine, though.
          As for the display being completely off, could this really be caused by a microswitch on the DVD unit? I believe that under any operating condition, the display should remain on, both when opening and closing the tray. Since it remains off, I tend to think the issue lies elsewhere—possibly firmware-related, as the display is also managed by the microcontroller.
          In any case, I suggested a more in-depth analysis to the customer, but the repair cost would be comparable to that of a new unit. Understandably, they declined the offer. So, I appreciate everyone's help, but I have no option other than to reassemble the product and return it to the customer.
          Regardless of whether the issue is firmware-related or a NAND failure, the repair would still be excessive and not cost-effective. That said, does anyone know if there's a way to attempt a blind firmware reflash in this condition? An update is available, but I'm unsure whether it's feasible given the device's current state of total inoperability
          • ictc
            • May 2015
            • 46
            • Italy
            update, the client doesn't want it back so I can give a try eventually.
            • nomoresonys
              • 12328
              • U.S.
              First thing I suspect in old units is bad caps, they can make them show no life in many cases. Might not be the problem but I always test them first.
              • ictc
                • May 2015
                • 46
                • Italy
                do you mean the electrolytic capacitors on the mainboard? I allready checked the SMPS and they are fine so far... the unit still perfectly clean inside perheaps not used very often.
                • nomoresonys
                  • 12328
                  • U.S.
                  Sure, might be worth checking. The led display unit may be bad but if that was the only problem, I think the player would still work thru the tv display and the buttons and such would still work. Can you post some good pictures of these internals.
                  • nomoresonys
                    • 12328
                    • U.S.
                    You did hook it up to a tv yes?
                    • ictc
                      • May 2015
                      • 46
                      • Italy
                      Of course, no signs of life. Also tested the only 2 caps on the motherboard and they tested fine too.
                      • nomoresonys
                        • 12328
                        • U.S.
                        Did you try post #4, manually release the tray, things go smoother if you relay that you tried a given suggestion. Before you say I already did that, it IS not clear if you did or not, you just give an opinion.
                        • ictc
                          • May 2015
                          • 46
                          • Italy
                          Yes, I'm sorry for not expressing myself clearly enough. I manually released the tray using the access point under the casing, specifically designed for manual ejection. I had to do that at the beginning in order to remove the front panel. I did it once again just to be sure but it didn't have any effect. Thanks again!
                          • ictc
                            • May 2015
                            • 46
                            • Italy
                            By the way I also was unable to find the UART as suggested in another reply ...
                            • lotas
                              • Jan 2016
                              • 4854
                              • Russia
                              Look for contact points RX, TX.
                              • nervous_capybara
                                Repairing the Hitachi DA-6000 CD player
                                by nervous_capybara
                                Hello everyone !
                                I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                                Feel free to share your experience if you ran into other issues.
                                DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                                CD tray would not come out of the player
                                I could hear a motor spinning inside the player but the CD tray would not come out.
                                Turned out that the issue was the CD tray belt that aged poorly and began to...
                                11-05-2025, 03:11 AM
                                MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                                This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                09-06-2024, 05:30 PM
                                DELL Latitude 3380 Notebook 3000 Specification for Upgrade or Repair
                                This specification for the DELL Latitude 3380 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3380 boardview and 3380 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3380...
                                09-06-2024, 02:34 PM
                                09-06-2024, 12:30 PM
                                09-06-2024, 07:42 AM
