Lcs-8038tx
  • zynix
    • Sep 2010
    • 27
    • The Old Continent
    Lcs-8038tx
    Hello everyone!
    This is my first time to post on Badcaps Forums, so I apologize if I say something ridiculous.
    Anyway, as the title says, I have got a Longshine LCS-8038TX ver.M1 LAN card from a friend of mine. The problem is that it isn't identified on my PC as a network device, and the LEDs on it blink hopelessly.
    In the picture you will see (hopefully) that capacitor C1 is missing. Could it be the culprit?
    TIA,
    zynix
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Lcs-8038tx
    Most likely
    The picture of a LCS-8038TX in the attached PDF does seem to have a capacitor in that place
    Even though yours has a Macronix chipset, and not an Intel like the specification says, the capacitor is probably still necessary
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Lcs-8038tx
      Yes you have a missing cap.
      The design is to use either radial or SMD in every spot.
      The spot you are worried about has the legs from a missing radial still on the board.
      Mann-Made Global Warming.
      - Dr Seuss
      • zynix
        • Sep 2010
        • 27
        • The Old Continent
        Re: Lcs-8038tx
        So, I popping in a 10uF 25V cap (that are the specs of other caps on the board) should solve the problem?
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          Re: Lcs-8038tx
          you can pick up trashed computers in dumpsters with nics in them, I have a few dozen lying around. if your'e really willing to go this far for a crappy nic, then make sure you put it in with the right polarization.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Lcs-8038tx
            Can't tell you that for sure. I dunno what was there.
            - Often cards like that only have one size cap but that is absolutely not 'always' the case.
            Chances are that will work but no guarantees..
            As Uranium-235 said, replacement NICs are readily available and cheap [or even free].
            Fix or replace would depend on what your priorities are.
            If repairing this is a learning experience then go for it, if the system is important for whatever reason then replacing it might be better.
            - Dr Seuss
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              Re: Lcs-8038tx
              when I worked for goodwill CW, I ran by so many tttouusssaaanndds of nics I kept throwing them away in droves. go through any old computers you have lying around, chances you will find one
              but yeah if this is for experience reasons, then good luck, smd soldering is hard if you don't have the right equipment and you have a big lack of experience. having ether or is ok, but if you dont' have both, well, good luck
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: Lcs-8038tx
                They aren't SMD.
                Has both SMD and Through Hole Pads. .. 2 mounting options.
                - Dr Seuss
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Re: Lcs-8038tx
                  That cap is likely on the 12v rail so use a 16v. Try a 100 or 220uf.
                  A working TV? How boring!
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    Re: Lcs-8038tx
                    the ones under the smd pads just looks like smaller smd pads, but now a second look, they do look like through holes
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: Lcs-8038tx
                      You can probably figure out what voltage it's on with a DMM and the pin-out.
                      http://pinouts.ru/Slots/PCI_pinout.shtml
                      A 16v or 25v cap would be safe anyway because the highest voltage is +12v.
                      They probably upped it to 25v for a larger can and a higher ripple rating.
                      Messing with uF on a NIC might have bad results because there are timings and frequency dependent circuits involved.
                      If you are SURE it is -only- for power to the IC chips then getting the uF exactly right shouldn't matter that much.
                      - Dr Seuss
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Re: Lcs-8038tx
                        If the capacitor value was critical they wouldn't have used a cheap lytic as they have large tolerances even when they just left the factory door, let alone what happens with aging.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Re: Lcs-8038tx
                          Seeing as how the original is missing entirely how did you arrive at a conclusion about what it was?
                          - Dr Seuss
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Re: Lcs-8038tx
                            There is room for both thru-hole and SMD, the SMD pads are large, and it is polarized. The only types of capacitor that fit this description are lytic and tantalum. Thru-hole tantalums have larger pitch.
                            Therefore it must be a lytic.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Re: Lcs-8038tx
                              The value........
                              And the tolerance is +/-20%. That's loose but not THAT loose.
                              Asker stated the other caps are 10uF.
                              The missing one was -probably- the same...
                              100uF and 220uF aren't within 20% of that nor are they within 20% of each other.
                              - Dr Seuss
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Re: Lcs-8038tx
                                +/-20% in a timing circuit? You're funny today.
                                I did not read that the other cap was 10uF. That's my bad. But i bet it wouldn't be a problem if it were 100u.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: Lcs-8038tx
                                  It's done all the time out in the 'real world'. [Meaning not consumer stuff.]
                                  That's what trim pots are for.
                                  - Dr Seuss
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Re: Lcs-8038tx
                                    Sure but a trimpot is more expensive, not mentioning more failure prone, than a 1% tolerance cap (and there are even tighter tolerances available) so why not do it right in the first place? I don't see a trimpot on that NIC anyway.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: Lcs-8038tx
                                      When you get out of the tunnel you will see more.
                                      - Dr Seuss
                                      • zynix
                                        • Sep 2010
                                        • 27
                                        • The Old Continent
                                        Re: Lcs-8038tx
                                        Sorry peeps for not informing you about the...err... progress, but I've had some goddamn school obligations so I wasn't able to respond any sooner. Anyway, I found a shot of my NIC on some Chinese shopping site, and all caps on that picture were having the same specs, so I decided to solder a Licon (yes, I know they suck!) cap that was lying around. And guess what? The card worked just as miserably as it did before I soldered that cap there. Cap isn't dead, and it's soldered properly. OK, I'd say so because there's no shorts and I've taken care for the polarity stuff. Seems like something else died, but not caps, right?
                                        • ugamazing
                                          820-02020 PPBUS_AON missing
                                          by ugamazing
                                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                          02-05-2025, 04:21 PM
                                        • jpreza
                                          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                          by jpreza
                                          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                          Looking at the card, it appears to be missing the following:
                                          1x 1.0uH inductor - orange square
                                          2x...
                                          11-01-2024, 10:54 PM
                                        • gurj1979
                                          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                          by gurj1979
                                          Hey guys.
                                          Need help with this one.
                                          Fan not spinning due to missing PWN Fan signal.
                                          Also 5 seconds from powering up it freezes, unless in BIOS.
                                          But as soon as Windows starts to load, it will freeze.
                                          CPU is COLD / Room temp when it freezes.
                                          I've replaced the CPU, same problem.
                                          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                          Replaced fan - same problem.
                                          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                          08-19-2024, 05:22 PM
                                        • salopian
                                          Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                                          by salopian
                                          Hello. I would need some advice please.
                                          My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                                          He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                                          I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                                          I have already replaced the logic board with another...
                                          02-27-2021, 07:30 AM
                                        • ein_individuum
                                          Missing Capacitator Intel I9-12900KF CPU
                                          by ein_individuum
                                          I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                          I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                          Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                          08-06-2025, 01:36 AM
