NCC KZGs really that bad?
  • TheLaw
    • Jan 2011
    • 477
    I'm seeing a lot of motherboards using KZG theses days. It seems that people are bagging on KZGs on this forum, and I was wondering if it's really that bad or not...
    Just curious to hear your opinions.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: NCC KZGs really that bad?
    Yes
    Mann-Made Global Warming.
    - Dr Seuss
    • TheLaw
      • Jan 2011
      • 477
      Originally posted by PCBONEZ
      Yes
      So OSTs or KZGs. =P
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        If =P means POS then yes.
        It's bad enough when caps go bad,,, but caps that go bad -and- 'look' perfectly fine suck 10x more.
        If you have a board that won't run and it's got bloated caps then you can be fairly confident a recap will fix it and you aren't wasting your time.
        OST, KZG, KZJ, and TAYEH will go bad in mass and the board will 'look' perfectly fine.
        That isn't to say they never bloat BTW. Sometimes they do.
        TAYEH kinda faded away. Only seen on older boards.
        - Dr Seuss
        • TheLaw
          • Jan 2011
          • 477
          Oooohh, those devils. I see what you mean. I was just curious. It would seem to me that if a manufacturer is willing to buy from a reputable brand like NCC, then why would they pick the crap cap versus the decent one, like a KMG. I suppose KZGs are cheaper than KMGs or Nichy HNs or something?
          Well thanks.
          • Colt45ws
            • Jan 2009
            • 174
            I have a 2.5 year old Biostar board that failed its KZGs. Only one of them popped but the others are toast as well, Im sure. Though, I think its kinda weak on caps to begin with. 3 1500uf on the VRM input and 4 3300uf on the VRM output for a 3.2 prescott. So its probably pretty rough on caps regardless.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Yeah that is kind'a light with 4x3300uF.
              There's enough uF there [8x or 9x 1500uF isn't too uncommon on 'prescott boards'] but I can't see 4x lytics having low enough total ESR.
              If you have some empty cap pads then you might wanna add some caps.
              [Make sure the pads are in parallel with those 4 caps.]
              The VRM-in should be okay if those three are better grades like MBZ up.
              - Dr Seuss
              • Colt45ws
                • Jan 2009
                • 174
                If you have some empty cap pads then you might wanna ad some caps.
                I was hoping to be able to add a cap or two, but no additional cap pads.
                Its getting MCZs in the input and MBZs on the out.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Well thanks.
                  Nichicon HM and HN were defective from 2001 thru 2004 due to a manufacturing error.
                  That one got in the news big time and I think some mobo mfrs are still 'gun shy' about using them.
                  KMG don't have that low of ESR.
                  KZG are comparable to MBZ, FJ, FL, WG, HM for ESR & Ripple.
                  KZJ are comparable to MCZ and HN.
                  What amazes me is that the motherboard manufacturers never figured out KZG had a problem.
                  They are out of production now [so I hear] but they were made for ~years~ and most mobo mfrs used them at one time or another.
                  I'm thinking the failure rate during the warranty period was low enough they didn't care.
                  [Same same with OST.]
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    If you can get MCZ for the 'out' I would do that.
                    There aren't enough cap pads to go to Polys.
                    - Dr Seuss
                    • Colt45ws
                      • Jan 2009
                      • 174
                      Hmm, okay, Ill try to get a hold of some. They are difficult to find. Only one place I have found has them and they are out of stock.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        KZG is batch dependent IMO... They're all lousy, but some batches preform better than others. Right now I'm typing from a Soltek motherboard with KZGs around the CPU... I'll recap it, but It's been running nearly 24x7 for months now with few problems.
                        I'm sure if I test them, they'll all read half capacitance. Still, a step up from OST.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          My first experience with the KZG issue was two systems with the same board that worked fine one day then simply wouldn't boot the next.
                          They died one day apart. [As if I didn't have enough to do.]
                          None of the caps were bloated but I heard here that KZG were going bad.
                          [It was new news at the time].
                          One had KZG/VRM-in and MBZ/Vcore.
                          The other had MBZ/VRM-in and KZG/Vcore.
                          I didn't want to wait for caps just to see in they were repairable at all so I pulled the MBZ off one and made the other one all MBZ.
                          - Fired right up and ran fine.
                          Ordered caps and fixed the other one later. It worked too.
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            With only 4 caps there you want as low of ESR caps as you can get.
                            These have lower ESR than the original KZG and are comparable specs wise to each other.
                            Rubycon MCZ
                            Nichicon HN
                            Samxon GC
                            Lower ESR still are..
                            Nichicon HZ
                            Samxon GA
                            My preference would be MCZ but that's just me.
                            HZ would probably be my second choice.
                            - Dr Seuss
                            • c_hegge
                              • Sep 2009
                              • 5219
                              ...It would seem to me that if a manufacturer is willing to buy from a reputable brand like NCC, then why would they pick the crap cap versus the decent one, like a KMG. I suppose KZGs are cheaper than KMGs or Nichy HNs or something?
                              KMG are not suitable for motherboard use, which is why manufacturers don't use them. Their ESR is too high. The reason manufacturers use them over rubycon for example is because they don't seem to realise that KZG is actually worse than some taiwanese beands. They think that KZG is as reliable as rubycon. All they need to do, though, is read these forums.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5038
                                • New Zealand
                                OST, KZG, KZJ, and TAYEH will go bad in mass and the board will 'look' perfectly fine..
                                Interesting - I've got an Albatron board, Intel 865 Chipset, won't POST and it's full of KZG (although flat-topped).... sound hopeful for repair?
                                -David VanHorn
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Yes it does if there is no obvious other damage.
                                  Inspect your chipset closely to make sure there is no sign of overheating.
                                  [Shiny spots mean it got hot there. Also might present as cracks or pits.]
                                  Take a look for the same thing on the MOSFETS.
                                  - If you don't see any problems there then go for it.
                                  The odds are pretty good.
                                  - Dr Seuss
                                  • TheLaw
                                    • Jan 2011
                                    • 477
                                    Really? My set top box has KMGs and I've seen LOTS of motherboards use them. Hmmph...
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5038
                                      • New Zealand
                                      The board looks in very good condition, MOSFETs look fine, both NB and SB look fine.
                                      The only thing visually 'wrong' is that some of the VRM capacitors have strange marks on the top, as if very tiny snails had been going around on top of them.
                                      I don't know what caused it but I think that will make sense to you as I suspect you will have seen some like that before.
                                      -David VanHorn
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        They can be OK as the small 100uF caps without vents on motherboards where the ESR isn't so critical, but they are general purpose caps, NOT low ESR.
                                        • kalemaroni
                                          Opinions on particular soldering iron tip maintenance product
                                          by kalemaroni
                                          Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
                                          04-12-2024, 03:52 AM
                                        • RetroComputingGrotto
                                          Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                                          by RetroComputingGrotto
                                          I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                                          As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                                          What is your advice/opinion on whether or not on old(er)...
                                          04-03-2024, 08:30 AM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • wildstoo
                                          Dell 9200 KZGs and other caps
                                          by wildstoo
                                          During the COVID-19 lockdown I've been entertaining myself by dragging out old stuff from storage and playing with it. My grandfather's old Dell Dimension 9200 has been cluttering the basement for a few years since he passed away, so I decided to drag it out and try to get it working.
                                          Although it was pretty clean inside, I soon discovered that it wasn't completely stable, and a quick look over the board confirmed some caps that are obviously bad.
                                          I know there are several threads that discuss this model but they're all from 7-9 years ago and the recommended...
                                          04-26-2020, 07:40 PM
                                        • Gregtheone
                                          Hot air station - 858D opinions?
                                          by Gregtheone
                                          Hello guys!
                                          I would like to ask your opinion on the hot air station Atten 858D or even 868D (there are many other producers of this very same product like W.E.R and so on).
                                          Rough specifics:
                                          Power consumption: 700W
                                          Airflow: 120L/m (max)
                                          Temperature range: 100-450 celsius
                                          I would want to remove and resolder the RAM BGA chips of a graphics card and I was wondering if it is plausible with a 858D (or 868D) or not? I have heard others say, that for a RAM sized BGA it is better to use a stronger hot air station, but I was wondering if...
                                          04-18-2022, 04:35 PM
