My Dimension has always been on a UPC battery backup. For the past couple of months the fan on the power supply has been making noises and then going away so I would clean it out with air and then it would be fine. We went away on a trip and came back and power was lost to the entire house but the computer was still running but it was froze at the login screen.
I rebooted it and the USB ports would work during post but would not work inside of Windows 7 and it would power itself off after about 2 minutes. I removed all of the PCI cards and it would stay running a bit longer then power itself off.
I ordered a new power supply and the USB ports now work inside of the OS but it still powers itself off. So I started looking at the board and found 1 capicator that was leaking and the other next to it was buldging at the top. Before I go and order 2 new caps does anyone think I can just replace these 2 caps and it will solve the problem or could it be other caps or something else and not be worth my time and be better off just buying a new system as this computer is getting older. I have attached pictures to reference. Thank You
? Strange...
