Was given a "broken" Dell XPS 410 (9200) and want to re-cap and get running again!
    Like the title states I was given a "broken" Dell XPS 410 (9200) because it just randomly would stop working. I figured I was just going to use it for parts since it was still completely intact and pretty well loaded for a "freebie". Brought it home and decided to clean it up instead because it was PACKED full of dust and pet hair. Spent a few hours cleaning, put it back together and BOOM.. it booted right up! Thing seems to run great now that it can breathe but while cleaning I found 1 bad cap. It's a "KZG" 3300uF 6.3v cap right next to a power supply cable if I am not mistaken. I have been doing a bit of research and it seems this is a pretty standard problem with this motherboard. I am no soldering expert, but I am ok at it and it seems like re-capping would be a LOT easier then the last few Nintendo Wii modchips I have installed! . I figured I would just go ahead and replace all of the KZG and KZJ caps that are likely to fail and hopefully this sucker will last a while for me. I have been looking for a place to buy all my replacement parts in one shot and it seems like badcaps is going to be it for me but I just wanted to make sure I am getting what I need to make the repair as I am a bit of a noob when it comes to this. I am not sure on the exact count at this moment but I will do a final when I get a chance so I can make sure I have enough to replace everything (unless someone might have already done this and cares to enlighten me a bit :P).
    From what I can tell I will be ok with Nichicon caps.. both in the HZ series. Can anybody confirm my choice? It looks like the 3300uF caps are 10x25mm and the 2200uF caps are 10x20. I don't think that clearance is going to be an issue, but I do see that they also come in a 10x16mm so I am not 100%.
    Specs are as follows..
    Dell XPS 410 (9200)
    Intel Core 2 Duo (E6600)
    4gig Ram
    500gb HDD
    NVIDIA GeForce 6800 GS
    Like I said the computer runs great right now, but I don't want to risk doing further damage so I want to go ahead and replace the bad/soon to be bad caps. It seems like it is going to be an awesome computer for what I need.. Especially since it was a freebie!
    Any help would be appreciated! Thanks again!
    Re: Was given a "broken" Dell XPS 410 (9200) and want to re-cap and get running again
    HZ will be fine. you're either replacing MCZ or KZG, seen these boards roast both. I've recapped many, they have all recovered...never had a dud.
    2200uF
    https://www.badcaps.net/store/produc...roducts_id=137
    3300uF
    https://www.badcaps.net/store/produc...roducts_id=142
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      Dell XPS 410 (9200)
      4gig Ram
      500gb HDD
      not bad for a freebie, definitely sounds worth recapping. just be careful and don't rush the job. through-hole parts are usually nice and easy to fix. oh and if you think wii chips are difficult, you should see some of the PS2 chips that i install :P
        I have done 2 PS2's in my time.. Definitely not something I would want to do daily! LOL
          2200uF
          3300uF
          I didn't see any MCZ's on the board.. Maybe I should take another look. All I saw were the KZG's (the 3300's) and the 2200's say KZJ on them. Are there others I should be looking for?
            They used one or the other, you got KZG's.
            Team : 49813
            Join in!!
            Team Stats
              KZGs appear to be common on Dells. Looks like Foxconn often uses them.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
