NCC KZGs really that bad?
  • TheLaw
    • Jan 2011
    • 477
    Re: NCC KZGs really that bad?
    Originally posted by c_hegge
    They can be OK as the small 100uF caps without vents on motherboards where the ESR isn't so critical, but they are general purpose caps, NOT low ESR.
    Oh alright...I'm still confused about ESR.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      ESR = Equivalent Series Resistance
      It's basically the 'resistance' to Ripple passing through the cap.
      The units are Ohms.
      Since a filter cap's job is to get rid of Ripple by providing a path to ground, the smaller the ESR is, the less 'resistance' there is to the Ripple going through it to ground.
      Caps like KMG are used in circuits where the Ripple has already been removed or is small or for signal coupling.
      The 'Ripple' we talk about as a cap's rating is basically how much Ripple Current it [the cap] can pass without overheating internally.
      Ripple Current [the rating] is to a cap as a watts rating is to a resistor.
      Keep in mind Ripple is AC noise.
      The DC obviously doesn't go through the cap.
      Since it is AC 'resistance' isn't the correct word so they call it 'Equivalent', as in equivalent ohms to having a resistor in series with an 'ideal' cap. [Which would have zero ESR.]
      Mann-Made Global Warming.
      - Dr Seuss
      • mockingbird
        • Dec 2008
        • 5484
        Why is there ripple after the AC has been converted to DC? I thought the components which converted it cut of the high and low waves, so shouldn't there be a steady stable line of DC?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          The ripple is from the switchers switching in SMPS.
          The PSU is a SMPS.
          The VRM is a SMPS.
          There are single chip SMPS all over a motherboard.
          - But they often call them voltage regulators or converters.
          On a basic level a single MOSFET regulator is still a SMPS.
          When the switchers switch they create little voltage spikes. [Ripple.]
          That's also why the Ripple frequency is near 100 kHz instead of 50 or 60 Hz.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            And for the new guy...
            "Switchers" = Switching Transistors.
            On a mobo they are usually MOSFETs.
            - Dr Seuss
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #26
              If you mean in the primary, there's actually a HUGE amount of ripple there. It's the ability of a regulated switchmode supply to compensate for low frequency ripple that allows for rather small primary capacitors. It's simple - diodes take the AC which goes +/- and turn it into DC which only goes from ground to one polarity (positive, or negative). But now this voltage has the shape of a half sine, there are still peaks and throughs (zeros actually). So you need the capacitor to turn that into "usable" DC, something resembling more a steady line.
              If you had a capacitor with infinite capacitance and zero ESR, there would be no ripple. But it would also need an infinite amount of time OR an infinite amount of current to charge it in the first place.
              A working TV? How boring!
              • mockingbird
                • Dec 2008
                • 5484
                #27
                Yea this I understood, the peaks and lows are cut off, but now you're left with fragmented straight lines which must be "buffered" somehow to make one steady streaming line.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  No, at that point it goes to the switching section that turns it into higher frequency AC.
                  That's because the higher frequency allows reasonable sized in/out isolation xfmrs.
                  Then it gets rectified again.
                  Then come the filter caps.
                  - Dr Seuss
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #29
                    Nope, the peaks aren't cut off. The capacitor charges at the peak voltage of the waveform and attempts to hold the voltage at that level. That's precisely why ripple gets produced.
                    • TheLaw
                      • Jan 2011
                      • 477
                      #30
                      I a linear supply, would you need low ESR caps? (Since there's no switching transistors.)
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        #31
                        No. But you will need more capacitance (higher uF values).
                        • TheLaw
                          • Jan 2011
                          • 477
                          #32
                          Ahh...so ESR really doesn't matter at all? Like NONE?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            #33
                            It does matter to a certain extent. But it doesn't need to be "low esr" for linear supplies.
                            • TheLaw
                              • Jan 2011
                              • 477
                              #34
                              Sorry to be all theoretical and such...but say I did use low ESR, would it be more stable?
                              Thanks.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                No, the caps are not where ripple is produced.
                                Without caps you would have more ripple, not less.
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Thanks.
                                  In what?
                                  - Dr Seuss
                                  • TheLaw
                                    • Jan 2011
                                    • 477
                                    #37
                                    Originally posted by PCBONEZ
                                    In what?
                                    I've been trying to figure out how to build a super stable linear power supply. I don't really have the materials/knowledge to go about making a custom PCB for a switching supply of my own, which is highly dependent on layout.
                                    Does low ESR (on a linear PSU) lead to more stable voltage/better ripple suppression? Any tips?
                                    Would polymers make a difference?
                                    Just massive capacitances?
                                    Thanks.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      I would maybe add KZE's as bad, too, at least the 3300uF ones. I recently had two boards with bad KZG, toghether with the 1500uF KZE's which looked good. However I did not measure them and it looks like I should have to becuase right now I look at old nForce 2 board with bulging KZE's 3300 uF/6,3 V.
                                      Once again, there are 1500uF/16V ones too, optically good, I will desolder them and measure just for case.
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        #39
                                        No, KZE is a proven reliable series. Most likely it was a cascade failure.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #40
                                          No way. After recap it works just fine, no broken MOSFTET's.
                                          • kalemaroni
                                            Opinions on particular soldering iron tip maintenance product
                                            by kalemaroni
                                            Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
                                            04-12-2024, 03:52 AM
                                          • RetroComputingGrotto
                                            Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                                            by RetroComputingGrotto
                                            I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                                            As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                                            What is your advice/opinion on whether or not on old(er)...
                                            04-03-2024, 08:30 AM
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • wildstoo
                                            Dell 9200 KZGs and other caps
                                            by wildstoo
                                            During the COVID-19 lockdown I've been entertaining myself by dragging out old stuff from storage and playing with it. My grandfather's old Dell Dimension 9200 has been cluttering the basement for a few years since he passed away, so I decided to drag it out and try to get it working.
                                            Although it was pretty clean inside, I soon discovered that it wasn't completely stable, and a quick look over the board confirmed some caps that are obviously bad.
                                            I know there are several threads that discuss this model but they're all from 7-9 years ago and the recommended...
                                            04-26-2020, 07:40 PM
                                          • Gregtheone
                                            Hot air station - 858D opinions?
                                            by Gregtheone
                                            Hello guys!
                                            I would like to ask your opinion on the hot air station Atten 858D or even 868D (there are many other producers of this very same product like W.E.R and so on).
                                            Rough specifics:
                                            Power consumption: 700W
                                            Airflow: 120L/m (max)
                                            Temperature range: 100-450 celsius
                                            I would want to remove and resolder the RAM BGA chips of a graphics card and I was wondering if it is plausible with a 858D (or 868D) or not? I have heard others say, that for a RAM sized BGA it is better to use a stronger hot air station, but I was wondering if...
                                            04-18-2022, 04:35 PM
