cap size help
  • v b chil-n
    • Dec 2005
    • 32
    cap size help
    I'm new here and have a asrock k7s41gx which has several bad caps, they are 6.3v 1000uf taicon's..
    my question is, how do I know what size (measurement) they are? several of them are in tight spaces and a larger diameter will not fit..
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: cap size help
    All my boards 6.3v 1000uf are 8mm by 12-15mm. Get a kids cheap school ruler. Most have cm/mm on one side.
    • v b chil-n
      • Dec 2005
      • 32
      Re: cap size help
      where did you buy your replacements?
      • davmax
        • Dec 2005
        • 899
        Re: cap size help
        Please complete some of your profile, click on User CP. This can then enable us to tell what country you live in.
        Places to buy: mouser.com and digikey.com. Both sell Nichicon. You will find 1000uF 8mm diameter caps there.
        I am still looking for 3300uF 6.3V at 10mm diameter. Most are 12.5mm diameter (reputable brands that is).
        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        160Gb WD eSATAII Server grade for backup.
        Samsung 18x DVD writer
        Pioneer 16x DVD writer + 6x Dual layer
        33 way card reader
        Windows XP Pro SP3
        Thermaltake Matrix case with 430W Silent Power
        17" Benq FP737s LCD monitor
        HP Officejet Pro K5300 with refillable tanks
        • Big Pope
          Approved Vendor
          • Dec 2005
          • 426
          Re: cap size help
          I have played more than 20 pieces 8RDA+, Rubycon ZL is not a good choice for this motherboard. I suggest used with MBZ or same grade at least.
          My SAMXON Capacitors Database HERE!!
          X-CON is a new brand for SAMXON's Polymer Capacitors.
          • davmax
            • Dec 2005
            • 899
            Re: cap size help
            Big Pope. That is a very interesting input. I guess a bit late for me. But ZL was the only readily available and the characteristics are way better than the original Teapo caps. Teapo have only just released a new product range SZ that competes very well with ZL and ZLG.
            My mother boards are going very well with ZL so will live with that.
            Thanks for your input
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: cap size help
              Big Pope is right but availability is difficult. HK,China from pcbulb, US from badcaps.net and nowhere else at reasonable price.
              • Big Pope
                Approved Vendor
                • Dec 2005
                • 426
                Re: cap size help
                Do know why "pcbulb" no stock for Rubycon MBZ and MCZ now?? Haha, it is because my SAMXON GD and GC can provide same grade in Hong Kong market, but more cheaper than "pcbulb" Rubycon.
                Now, I am waiting for the member's test report for my SAMXON capacitors here.
                • Big Pope
                  Approved Vendor
                  • Dec 2005
                  • 426
                  Re: cap size help
                  Do you want to try my SAMXON GD and GC with this motherboard? I know you must surprise the power of GD and GC.
                  I will send you free of charge. Please contact me if you want?
                  • Mustang
                    • Dec 2003
                    • 203
                    Re: cap size help
                    Big Pope, what's your experience with the Abit NF7-S motherboard? Every cap on it is Rubycon. It overclocks very well but would your caps push it further? Curious
                    • Big Pope
                      Approved Vendor
                      • Dec 2005
                      • 426
                      Re: cap size help
                      Yes, i have experience with NF7-S Ver2.0. All are Rubycon MBZ, i know. By this reason, it is no much space to push further. Actaully, i have experience over 100 pcs motherboards in th past.(Socket 7 to P4 and A64)
                      Do you know DFI LanParty NFII Ultra? NF7-S compare with LanParty NFII Ultra, both are good motherboard, but DFI can overclock FSB 250MHz above with same CPU. I feel DFI LanParty NFII Ultra is better than NF7-S.
                      • Mustang
                        • Dec 2003
                        • 203
                        Re: cap size help
                        Yes, that DFI still is the best NF2 mobo for overclockers. The Abit was considerably less expensive at the time and to my surprise has very good caps across the board. I'm not sure what the DFI has for caps and how well they stand the test of time but I guess the overclockers already have A64's and beating those up now
                        • Big Pope
                          Approved Vendor
                          • Dec 2005
                          • 426
                          Re: cap size help
                          Yes, DFI LanParty SLI-DR Expert and Asus A8R-MVP is my target motherboards for A64's system. Now, Opteron 146 is hot choose for DIY user. Retail market price is HK$1480 in Hong Kong. What price of Opteron 146 in your side?
                          • Mustang
                            • Dec 2003
                            • 203
                            Re: cap size help
                            2.0gig socket 939 about $200.00US at monarchcomputer.com
                            • Newbie2
                              • Sep 2005
                              • 885
                              Re: cap size help
                              An AMD Opteron 148 (OEM) will cost $377.99 at TigerDirect.ca
                              I'm in Canada
                              My gaming PC:
                              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                              ASUS M4A77TD AMD 770 AM3 Motherboard
                              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                              ASUS Xonar DG 5.1 Channel PCI sound card
                              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                              Antec Three Hundred Mid-Tower Case
                              Microsoft Windows 10 Pro 64-bit
                              Microsoft Windows 7 Ultimate SP1 64-bit
                              • m1ch43lzm
                                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                by m1ch43lzm
                                Hi everyone
                                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                There's also an extra OTP Secu.R...
                                09-06-2025, 05:47 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • dragometin
                                Hitachi 40HYC42
                                by dragometin
                                TV Model: Hitachi 40HYC42
                                Power Supply: 17IPS71
                                MainBoard: 17MB95M
                                Panel: VES400UNDS-2D-NO3
                                When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                Is there any variants on 17IPS71 power supply's?
                                UART output pins 10 and 12 on scart connector:
                                Code:
                                12:24:04.595
                                08-08-2024, 05:53 AM
                              • disti
                                Flash HP 450 G5 using Arduino - wrong file size
                                by disti
                                I'm trying to flash an HP Probook 450 G5 (2XY63EA) BIOS using Arduino.
                                It's the first time I try this procedure so maybe I'm missing something stupid.
                                I've been able to unsolder bios chip (Winbond W25Q128JV) and wire it up to Arduino.
                                I also dumped it succesfully (dump.bin).
                                Now I'm having a hard time trying to reflash it, because the bios file I downloaded from HP has the wrong size.
                                I downloaded bios from HP (https://ftp.hp.com/pub/softpaq/sp103...0/sp103710.exe).
                                When launched, the executable extracts a file (Q...
                                06-23-2020, 10:09 AM
                              • jdczerwin
                                Physical Electrolytic Cap Size Question
                                by jdczerwin
                                My question has to do with through-hole Electrolytic Capacitor physical size and finding the correct specification in ordering a replacement.
                                Example: I'm working on an old video arcade monitor. The parts list calls for two (2) 6800pF, 50V Electrolytic Capacitors (ECap). Based on that specification, you can go to Mouser, DigiKey, etc and get a through-hole ECap at that spec…and get a far smaller one (physical size-wise) than what was on the board.
                                From my limited knowledge, I understand that size does matter in this application because of the stress that the circuit...
                                01-15-2021, 09:08 AM
