Physical Electrolytic Cap Size Question
  • jdczerwin
    • Jan 2021
    • 3
    My question has to do with through-hole Electrolytic Capacitor physical size and finding the correct specification in ordering a replacement.
    Example: I'm working on an old video arcade monitor. The parts list calls for two (2) 6800pF, 50V Electrolytic Capacitors (ECap). Based on that specification, you can go to Mouser, DigiKey, etc and get a through-hole ECap at that spec…and get a far smaller one (physical size-wise) than what was on the board.
    From my limited knowledge, I understand that size does matter in this application because of the stress that the circuit puts on the ECap in charging and discharging, so I'm assuming that its something to do with the operational frequency of the ECap.
    My question:
    Is there something on the old cap I can look at to get the right replacement part? Going just by the parts list, it doesn't state size or frequency.
    Is it better to measure the ECap that's on the board first, and match-up the physical size and capacitor specs with the suppliers? Wondering how other experience repair shops solve this…especially when building a spare parts inventory.
    Any help or direction would be most appreciated.
    • 31289
    Re: Physical Electrolytic Cap Size Question
    6800pF is not an electrolytic
    • jdczerwin
      • Jan 2021
      • 3
      Unfortunately, the parts list states pF, but the actual size is uF. See attached photos.
        • 31289
        those are good caps,
        the base is called 10mm snap-in btw
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
          by momaka
          03-12-2025, 03:42 PM
        • sikocan
          Lenovo X1 Carbon 9th Gen Black Screen
          by sikocan
          I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
          SN: PF3G1REP
          MODEL: 20KW-00J1AU
          PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
          Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
          06-24-2025, 09:01 PM
        • dragometin
          Hitachi 40HYC42
          by dragometin
          TV Model: Hitachi 40HYC42
          Power Supply: 17IPS71
          MainBoard: 17MB95M
          Panel: VES400UNDS-2D-NO3
          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
          Is there any variants on 17IPS71 power supply's?
          UART output pins 10 and 12 on scart connector:
          Code:
          12:24:04.595
          08-08-2024, 05:53 AM
