Samsung UN55MU8000 - Backlight But No Picture Problem
  • lotas
    • Jan 2016
    • 4760
    • Russia
    #81
    Re: Samsung UN55MU8000 - Backlight But No Picture Problem
    You don't need to supply any power, you just need to put a jumper between FB_TRDY_1 and FB_TRDY_3.
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      #82
      Okay I am back with voltage readings after jumping FB_TRDY_1 and FB_TRDY_3.
      AVDD_17V = 0V
      HAVDD_8.5V = 0V
      VGH = ~0V (actually it was 0.065v
      STVP1 = 0V
      Panel_3.3V = 3.3V
      There were a few other test points I hadn't noticed or paid attention to before so I took their measurements anyway.
      SFC1 = 1.85V
      VCCA_1.9V = 1.9V
      If I recall correctly there is no change from before jumpered the FB_TRDY_1 and FB_TRDY_3.
      Does this mean that the T-Con portion of the mainboard is non-operational?
      Is that a firmware issue? I remember checking all the PMICs and they seemed okay.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4477
        • Italy - Milan
        #83
        How can you check a pmic? maybe pmic has internal registers and those are cleared... need mainboard replacement, but on the market there is a gadged of a tiny board reproducing all standard trimmable tensions of a lcd display.. this only for testing purposes... china market..
          09-07-2024, 05:50 AM
        • madyoyo
          Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
          by madyoyo
          Hi
          I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
          Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
          12-01-2023, 09:28 AM
        • NWArkGuy
          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
          by NWArkGuy
          Well, I will be the first to admit that I screwed up...
          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
          I have 2 that I have found and have in my possession. ...
          10-12-2023, 10:13 PM
        • KYBOSH
          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
          by KYBOSH
          I picked this one up today.
          Previous owner says no signs of life.
          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
          The TV model is QN65LS03BAFXZA - version: CB06
          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
          Will keep you all...
          04-05-2025, 08:32 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
