un58tu7000 reboot loop
    • 12206
    • U.S.
    Re: un58tu7000 reboot loop
    ok, thats what the testing is for, if you had done that simple test before as suggested, you wouldn't have had to guess, so the test seems to indicate a panel issue, these tests are pretty simple and basic but they need to be done to get a picture of what is wrong, and YES sometimes those symptoms are mainboard issue and sometimes they are panel issue, the last samsung I fixed with these same symptoms was fixed with a new mainboard.
    • lotas
      • Jan 2016
      • 4633
      • Russia
      Originally posted by tmlfan
      I received the new main board today, swapped boards and it is still doing same thing, I figured out that also if you leave everything plugged in but remove this cable from the main to the panel also that the panel stays on
      Why are you buying these boards, you have a problem in the panel.
      • tmlfan
        • Jun 2011
        • 109
        I missed the post saying to try main board to panel, just seen main to power suggestion, my fault....so panel issue is a definate unfixable issue I assume
          • 12206
          • U.S.
          post #10, tape cut-off method may work.
          • lotas
            • Jan 2016
            • 4633
            • Russia
            Disconnect this cable and check again with your original motherboard.
              • 12206
              • U.S.
              #26
              in some cases it can be a faulty component/s on the panel driver boards, another pretty simple test is test the little mlcc capacitors for shorts or very low ohms.
              • tmlfan
                • Jun 2011
                • 109
                #27
                It does same thing with original board in it, I will give the tape method a go here in a bit
                • tmlfan
                  • Jun 2011
                  • 109
                  #28
                  So I have been messing with the tape method but the best I can do is get the tv to stay on, has a black screen and I can hear the cursor sound when I hit the arrows on the remote
                  • cheebster
                    • May 2008
                    • 374
                    #29
                    tmlfan, this specific set ive been messing with it for ages.
                    you have a bad panel, and taping does not work on it because you are blocking signals on both sides because of the way it's been designed.
                    So, you need to be able to block signals, but in a different way. You can start by isolating on which side the issue comes from by blocking VGH from going on right, then left side of the tv's pcb to see if it works
                    Is vgh present on the tv's pcb with the bonded tabs at the test points ?
                    • sputnikoff
                      • Feb 2016
                      • 203
                      • canada
                      #30
                      I got one in tonight same issue with right cable lifted off from display screen stays on .The panel is definitely bad ,actually had two this weekend the other got away with a vertical line in it.
                      • Nicktronic
                        • Mar 2023
                        • 247
                        I have the same issue with the same TV. Managed to isolate two contacts on the ribbon cable that joins the left and right driver boards (see pictures), and get a crappy picture. Wondering if someone knows what signal is on these pins and if there is an area to focus on to improve the picture (lines are acceptable, but the picture right now if really bad).
                        • KANSRVERO
                          • Jun 2020
                          • 6
                          • ecuador
                          #32
                          Hi, sorry for bothering you. I saw the thread about the Samsung 58TU7000 TV and I'm having a similar problem.
                          The TV was freezing and wouldn't start up. I put a piece of tape on the flex cable and it only worked partially. Two days later, the screen went dark on the side where I put the tape. I tried resetting it, but it wouldn't turn back on. I used the tape and did everything else I could to try to restart the TV, but I haven't had any results.
                          If you have a schematic diagram where I can track possible problems, I'd appreciate it.​
                          • lotas
                            • Jan 2016
                            • 4633
                            • Russia
                            #33
                            But the screen may darken on one side due to the backlight, this is a common problem in these series...
                            • kevin_allein
                              Samsung GU58TU7199 reboot loop
                              by kevin_allein
                              Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                              The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                              03-24-2024, 12:19 PM
                            • natiz
                              Samsung QE50Q60AA - Reboot loop
                              by natiz
                              I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                              Disconnecting the LVDS cable stops the restart loop but no image.
                              I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                              Tested the caps on the left buffer board, no beeps.
                              What else can be checked?...
                              08-30-2024, 09:26 AM
                            • javierwilliam
                              Boot loop issue with LCD TV
                              by javierwilliam
                              I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
                              Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
                              Thanks in advance!​
                              08-29-2024, 04:06 AM
                            • abajor
                              Alienware Area-51 R2 Boot Loop issue.
                              by abajor
                              I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
                              It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
                              To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
                              Right now I'm trying to dig through the PDF schematics and Board...
                              03-08-2024, 10:08 PM
                            • nocnoc
                              Acer Swift 5 (SF514-52T) reboot loop mistery
                              by nocnoc
                              I'm quite new to this and trying to learn by help a friend with his SF514-52T that stopped booting after battery was replaced. I suspected the battery was bad but the problem persisted when putting back the original one (which is was still working although with reduced capacity).
                              When pressing the power-on button the symptoms are:
                              - Keyboard backlight and blue power LED turn on for about 5-7 seconds, and then flash off-on in ~3 seconds cycles (reboot loop).
                              - Display does not seem to turn on, although it sometimes seems to flash in between reboots....
                              04-21-2024, 06:42 AM
