Boot loop issue with LCD TV
  • javierwilliam
    • Aug 2024
    I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
    Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
    Thanks in advance!​
    geometry dash breeze
  • nomoresonys
    • 12157
    • U.S.
    Brand and full model number?
    • abajor
      Alienware Area-51 R2 Boot Loop issue.
      by abajor
      I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
      It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
      To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
      Right now I'm trying to dig through the PDF schematics and Board...
      03-08-2024, 10:08 PM
    • blaster_
      Samsung UE49MU6105K - boot loop, horizontal lines
      by blaster_
      Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
      Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
      06-22-2022, 05:19 PM
    • luis71
      PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
      by luis71
      Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
      I have backed up PQ,SPI,and Profile if anyone want
      Which usb_auto_update_??.txt can i use to dump firmware?
      I would be grateful if anyone could help me to find the firmware for USB recovery.
      11-05-2023, 06:31 AM
    • No Lan
      [Macbook pro A1708] [Boot loop] [Trackpad ?]
      by No Lan
      Hey everyone,
      Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
      Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
      Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
      05-24-2025, 03:09 PM
    • Stefano Crivellari
      Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
      by Stefano Crivellari
      Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
      01-14-2025, 03:49 PM
