Alienware Area-51 R2 Boot Loop issue.
  • abajor
    • 178
    I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
    It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
    To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
    Right now I'm trying to dig through the PDF schematics and Board layouts I've found to identify test points, but the PDF board views are mostly just component pad layouts, with minimal information other than part numbers.
    I've found a few .brd files here and other places but they don't open in flex board view.
    Does anybody here have any experience with this beast and have any idea what I should look for in the power up which would cause this boot looping behavior?
    For what its worth, the motherboard looks really clean other than some dust and lint, apparently the original GPU burnt out and needed to be replaced.
    Thanks for any suggestions/assistance.
  • Sephir0th
    • Oct 2020
    • 1283
    Is the battery good and does it the same when it boots from battery?
    Interestingly, the most important information came at the end. You are not considering that the problem originates there (GPU)? Any history known about when was the GPU replaced and whether the issue was present since then?
    FairRepair on YouTube
    • abajor
      • 178
      First: Same problem with or with out the battery connected.
      I think the boot loop issue may have started after GPU replacement. The guy that owned the Lap top says that it was a periodic annoyance but his system would boot after one or two loops. It just got worse and worse until it never booted into the OS.
      I got it to boot once with a test drive got through "configuring hardware" message then reset.
      • javierwilliam
        Boot loop issue with LCD TV
        by javierwilliam
        I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
        Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
        Thanks in advance!​
        08-29-2024, 04:06 AM
      • blaster_
        Samsung UE49MU6105K - boot loop, horizontal lines
        by blaster_
        Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
        Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
        06-22-2022, 05:19 PM
      • luis71
        PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
        by luis71
        Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
        I have backed up PQ,SPI,and Profile if anyone want
        Which usb_auto_update_??.txt can i use to dump firmware?
        I would be grateful if anyone could help me to find the firmware for USB recovery.
        11-05-2023, 06:31 AM
      • No Lan
        [Macbook pro A1708] [Boot loop] [Trackpad ?]
        by No Lan
        Hey everyone,
        Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
        Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
        Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
        05-24-2025, 03:09 PM
      • Simone Vergani
        Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
        by Simone Vergani
        I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
        To assist with troubleshooting, I'm attaching two power circuit schematics:
        • Power
        03-05-2025, 02:25 PM
