Sony KDL-55W755C - Dead
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    Hello again lifesavers.
    I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
    I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I have absolutely no idea what the "Muffin" is.
    Decided to just swap the mainboard instead of trying to find out the meaning of "Muffin". Even had an actual muffin during lookout for the board. Found one from 50" 755c, exactly the same board numbers.
    After installing it I was greeted by flashing green/Amber lights. "Firmware please" it said. Downloaded it from Sony website and flashed it - could see the status light change to dimming white, which - according to various places in the Net - means it is reading the firmware and installing it. After some time the TV resets and... Continues to flash green/Amber, this time with Android setup sound playing in the background. I can hear it reacts to the remote as well.
    It is not a backlight issue as the backlight works fine when mainboard is disconnected from the PSU, and there is no picture visible when flashing with torch.
    Green/Amber flash means panel Id error, which I guess maybe could be solved by choosing the correct panel Id in service mode - the problem is I have no picture and can't really do it blind.
    I've seen various threads about a corrupted Android update that caused this sets to fail this way. At this pont I am suspecting that the board I received from eBay has the 'bricked' soft on it, that doesn't 'want' to be overwritten.
    My questions to you are as follows:
    1. Is anyone able to explain what a "Muffin" is? Eeprom?
    2. If the board I received has a corrupted firmware on it, would it update over with fresh update from Sony website?
    3. Is there any reasonable way to make 1 properly working board out of the 2 I have? I suspect swapping the firmware is 'a bit' more complicated than transferring an iC containing it?
    What's my best shot now? Any help would be highly appreciated.
    Thanks for stopping by.
    • 12141
    • U.S.
    Re: Sony KDL-55W755C - Dead
    Probably the EEMC chip on mainboard is dead, they only last so long.
    • CapLeaker
      Leaking Member
      • 8134
      Backup the contents of both EMMC’s from both boards, then flash the content from the original board to the new board with flying wires. No soldering needed.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4316
        • Italy - Milan
        Android versions carrys the name of a typical sweet, evidently your tv has got muffin version. Since this is an always on tv, a not booting tv is often one with damaged android. I have followed a thread on an italian forum that was by headache, also there a not booting one followed by mb replacement and no video with audio, ended up in carrying the giant tv to Sony assistance, they told to the owner they worked only with closed tv and an usb memory with correct firmware, i guessed they have secret key combinations/menus that carrys to the correct updating process that recognize the actual panel and synchronizes with the new main board..
        Finally i suggest you to try insert the sowftware usb key in with tv in standby, then keep press on key on local keyboard for 4-5 secs and watch if update starts, if the process is not successful retry it but with at least 14-15secs..
        bye..
          • 12141
          • U.S.
          lol, if only someone could get that SECRET combination, but there is no such thing in the real world.
          • mrsith
            • Mar 2021
            • 146
            • Wielka Brytania
            There was no Android version called Muffin (there was Cupcake but that's an ancient 2009 1.5 version which was never present in this TVs) and the service manual says about REPLACING the Muffin, so doesn't sound like a soft reinstall.
              • 12141
              • U.S.
              ^^^LOLOLOL, I believe you 1000%.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4316
                • Italy - Milan
                it is a coded name or a special version of android
                  • 12141
                  • U.S.
                  they were toying with the idea of calling android 6 muffin, but it's no secret or special conspiracy that needs a magic combination, VERY AMUSING concept tho.
                  • mrsith
                    • Mar 2021
                    • 146
                    • Wielka Brytania
                    For anyone in the future who might be looking for this answer - Muffin doesn't mean Android. Sony calls that it's main SOC, trivialising it Muffin = CPU.
                    I did try the update hundreds of times with the same results. Ordered a programmer to dump and flash eMMC as suggested. It's about time lol.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4316
                      • Italy - Milan
                      You can't do Capleaker's suggestion because flow chart tells emmc erase and re install software, this doesn't mean copy a premade installation with a dump but a new installation maybe with a software installer by usb flash key, remember cpu has got in it some key codes.. them must be used for new installation.. this is what seems to me..
                      ps: is possible new software is copied at steps, like another tv i repaired, first bootloader copy by serial port, then usb installation..
                      • CapLeaker
                        Leaking Member
                        • 8134
                        Only the flow chart sez something, doesn’t mean automatically it has to be done that way. I’ve cut many flowcharts short and was surprised with the outcome that it actually did work copying the content from one board and load it to the identical other board. Even worked on an Android TV box. Given, it isn’t a guarantee to revive this like that, but worth a shot. Before I do the boot loader on a TTL and USB jazz, I prefer making a dump file and flashing that. However, you have to be very careful with that and know what you’re doing, because you can easily screw up a dump too, by not selecting proper chip parameters, etc.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          You weren't able to read the faulty eMMC and had to read off a working one IIRC Capleaker.
                            • 12141
                            • U.S.
                            Only the flow chart sez something, doesn't mean automatically it has to be done that way. I've cut many flowcharts short and was surprised with the outcome that it actually did work copying the content from one board and load it to the identical other board. Even worked on an Android TV box. Given, it isn't a guarantee to revive this like that, but worth a shot. Before I do the boot loader on a TTL and USB jazz, I prefer making a dump file and flashing that. However, you have to be very careful with that and know what you're doing, because you can easily screw up a dump too, by not selecting proper chip parameters, etc.
                            +1000, I have also seen this done before, and seen some done on youtube.
                            • CapLeaker
                              Leaking Member
                              • 8134
                              Yes, that is correct. It was the Dreamlink T1, first Android box with an EMMC I did. I even put larger EMMCs and different brands in there. I made a dump from a working one, then copied that to a different EMMC that I had in the junk pile and soldered that on to the non working one. MAC addressees etc were no problem and stayed the same as they were. I ended up fixing a few of these boxes and others too using the exact same method. Worked like a charm every time.
                              The problem with this is, you gotta know what you’re doing. So someone had the idea to read their router and didn’t select the chip proper (there were 2 versions on how the memory banks are laid out). Selected the wrong one, dumped the contents (no errors). Then he flashed the dump file back and now he got tons of errors during flashing back and of course the router doesn’t work no more, then wonders why.
                              • mrsith
                                • Mar 2021
                                • 146
                                • Wielka Brytania
                                That flow chart was about replacing the CPU - I think only then it is necessary to follow exactly these steps.
                                I did some BIOS programming before but don't have experience with eMMC. Did some digging and it seems -quite- straightforward, but is there anything specific I should know? Or maybe some step by step how-to guide?
                                Would soldering the original eMMC to the new board do the trick? Not a fan of bga-like ICs at but least I'd know what I'm doing lol.
                                • CapLeaker
                                  Leaking Member
                                  • 8134
                                  You can read my Dreamlink T1 thread. I did both, using flying wires to read and write from and to the EMMC, and I replaced the bad EMMC with a used and re flashed one. Its not as quite forward as it seems. Lots of pitfalls if its not done correctly.
                                  First tip is don't take a EMMC off, if you don't have to. Getting it off, isn't the problem. But getting it soldered back to the board, is the hard part. You need low temperature melting solder. Some use solder balls and a stencil, I didn't.
                                  Second tip is an oscilloscope to figure out where to get all your wires hooked up to the board to read / flash the EMMC without taking it off. This takes quite a bit of probing, measuring and verifying.
                                  Third tip is to get a digital microscope like Andonstar and put that on a large monitor, so you can see something.
                                  Take your time doing the work and double check everything. It looks easier than it is. I would only take the EMMC off or reflow it, if it doesn't communicate. Which is easy to figure out by measuring the data lines with the oscilloscope.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    I'd stick the suspected faulty one in a socket and a RT809H to see if it was faulty.
                                    If it is then I see two options, swap your original eMMC which will require some skill as the BGA is small and needs replacing, or buy a preprogrammed one with the balls already on, so the hard work is done.
                                    • CapLeaker
                                      Leaking Member
                                      • 8134
                                      you don't need to stick the emmc into the RT809H in order to see if it is faulty. Just look at the data lines, clock, voltage etc. A dead emmc will not transfer any data at all.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        Your previous post you say it takes time to find where to attach the wires. My way would be quicker and if it's faulty it has to come off anyway.
                                        There's more than one way to do things, it depends on the tools and skills on hand and time.
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                        • joby91
                                          SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                          by joby91
                                          I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                          I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                          I found one chat about firmware on ************** forum but i cannot read the comments.
                                          https://**************/forum/108-114100-1#880537
                                          09-04-2024, 01:34 PM
                                        • jason123
                                          Sony Firmware for XBR-70X850B
                                          by jason123
                                          Hello
                                          Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                                          I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                                          Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                                          Much appreciated.
                                          05-17-2022, 12:42 PM
                                        • Andreasbest
                                          Dell Latitude 7410 dead and amber light as long power button is pressed.
                                          by Andreasbest
                                          Hello.
                                          I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                                          Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                                          Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                                          Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                                          12-21-2024, 02:02 PM
                                        • AlexWhat
                                          SONY KDL-65w850c need latest firmware 6.827
                                          by AlexWhat
                                          In 2022 SONY did "Termination of TV Software Update" for this model.
                                          I did find older firmware but it can't be installed over newer one (rolled back)
                                          Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
                                          12-15-2024, 11:32 PM
