SONY KDL-65w850c need latest firmware 6.827
  • AlexWhat
    • Mar 2024
    • 11
    In 2022 SONY did "Termination of TV Software Update" for this model.
    I did find older firmware but it can't be installed over newer one (rolled back)
    Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
  • nomoresonys
    • 12306
    • U.S.
    Maybe try these guys, tell them you changed a board and need the firmware that they dropped from their site: https://ca.esupport.sony.com/support...language=en_US
    • zomi
      • Nov 2011
      • 511
      https://community.sony.de/t5/android...57/m-p/3955838
      • Diah
        • Feb 2013
        • 6465
        android system.. always have copy saved on partition , if you have bootloop always hard reset will write the firmware back
        • AlexWhat
          • Mar 2024
          • 11
          I did find this " https://www.reddit.com/r/Troubleshoo...screen_anyone/ "
          • AlexWhat
            • Mar 2024
            • 11
            I did contact Sony support and they did supply me with the latest software and all instructions but since the tv had latest software I was not able to upgrade.
            • Diah
              • Feb 2013
              • 6465
              at my post 4 i said what it should need,
              good Sony give you last firmware.. .. copy it after extract on root USB stick no more than 4Gb formatted in FAT 32 MBR mode ..while TV plugged out from the wall insert thr stich at the side Black USB Port.. hold joystic pushed and pull it down keep this action and plug the tv IN wall release yours Push only after the front LED change from white to green. after it change color count 3..2..1 and releasr you push... leafe it even you have blank screen... you ,may try it several time to work.. thought this is your cheapest way to bring the TV to work again.
              i posted here before many ears and it did work with worst condition not as yours... search after.
              • AlexWhat
                • Mar 2024
                • 11
                That what it states in (Android software Help.pdf) "If TV was updated to last software release, you cannot update again" and at the end "If does not recover, TV will need a new main board."
                After reflash it does not switch to a new flash, it just behaves as before.
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                • joby91
                  SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                  by joby91
                  I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                  I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                  I found one chat about firmware on ************** forum but i cannot read the comments.
                  https://**************/forum/108-114100-1#880537
                  09-04-2024, 01:34 PM
                • jason123
                  Sony Firmware for XBR-70X850B
                  by jason123
                  Hello
                  Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                  I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                  Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                  Much appreciated.
                  05-17-2022, 12:42 PM
                • cheeky2
                  Help with Sony firmware KDL-40W5500 v1.752EA
                  by cheeky2
                  Unfortunately Sony Have taken all there old TV firmwares down from there website last year. So it isn't available to download. Does someone have the firmware available please? It is used for a whole range of the KDL range of TV's including the following models :
                  KDL-22E5300, KDL-22E5310, KDL-32E5500, KDL-32E5510, KDL-32E5520, KDL-32V5500, KDL-32V5610, KDL-32W5500, KDL-32W5710, KDL-32W5720, KDL-32W5730, KDL-32W5740, KDL-37V5500, KDL-37V5610, KDL-37W5500, KDL-37W5710, KDL-37W5720, KDL-37W5730, KDL-37W5740, KDL-40E5500, KDL-40E5510, KDL-40E5520, KDL-40V5500, KDL-40V5610, KDL-40W5500, KDL-40W5710,...
                  01-28-2023, 06:13 PM
                • thesteve
                  Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                  by thesteve
                  So I bought another main board from eBay and the same thing happened.
                  I got the firmware file from the Sony website. My model was listed and everything matched.
                  sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                  Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                  with file: 00000301_07e8046a.bin inside.
                  Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                  The file reads perfectly. Lots of "disk activity"...
                  07-17-2021, 04:59 PM
