technika tv, 32 inch,capacitor replacement question, useful advice needed
  • rustinjust
    • Jun 2022
    • 49
    • England
    I have a technika tv, 32 inch, around 10 years or so in age and last night when watching tv i heard a hissing sound and the next thing i saw smoke coming out the back of the tv, i instantly unplugged the tv. I took the back off tv to expose power board, then plugged in tv and saw smoke coming out of a capacitor, i will try and attach a photo below, see below for attachments of board and cap, and keep reading, maybe you can advise ?
    The cap says on it: 105kj450mff4. This doesn't mean a lot to me as i'm an amateur when it comes to electronics, though i've undertaken some repairs such as fixing a washing machine replacing the carbon brushes etc.
    Although its a cheap tv id like to have a go at fixing it by soldering on a replacement cap. Also near to the cap that blew is another of the same type and same numbers written on it. This seems ok.
    My question: which replacement cap do i need to purchase ? Can anyone advise which one i need to buy, or a link to one etc ? Much appreciated if you can advise on what the numbers on the cap mean too and which cap to buy, not too cheap, nor too expensive, but something that will work, be reliable for a few more years.
  • yokoono
    • Apr 2010
    • 502
    Re: technika tv, 32 inch,capacitor replacement question, useful advice needed
    105=10x00000pF=1.000nF=1uF/450V
    Conclusion: 1 microfarad at 450 volts. Non-polarized.
    • lotas
      • Jan 2016
      • 4711
      • Russia
      More Mff - Metallized Polyester Film Capacitor.
      • vinceroger69
        • Mar 2012
        • 6714
        ignore wrong thread sorry
        • rustinjust
          • Jun 2022
          • 49
          • England
          Thanks and can you advise what replacement cap i should purchase? Im here in the u.k so from a uk source online would be ideal. Link something if possible. Im new to this but im going to have a go at soldering on a replacement cap. One thats reasonable quality but not too expensive would be ideal
          Would any of these work ? https://www.digikey.co.uk/en/product...iABEgJkjfD_BwE
          or https://www.digikey.co.uk/en/product...2105JA/1635187
          • yokoono
            • Apr 2010
            • 502
            Depending on the position in which it is placed on the power supply, the capacitor is part of an EMI filter. Power supply works very well without it.
            • vinceroger69
              • Mar 2012
              • 6714
              Those capacitors are only 250v you should replace like for like 450v as this is a one off repair have a look on ebay as maybe cheaper shipping too.
              £2.95 on ebay delivered 1uf 450 v 15mm https://www.ebay.co.uk/itm/265197356....c100667.m2042
              • rustinjust
                • Jun 2022
                • 49
                • England
                • rustinjust
                  • Jun 2022
                  • 49
                  • England
                  Ive attached a photo, its near to the top right in the photo attached to this, there are 2 of them, the one nearest the top is blown, the one on the slopping angle, its like that because i put it back in for the reasons of the photo.
                  Do you mean the tv may work ok without the capacitor on? It's removed ( the cap) but ive not tried the tv yet.
                  Also, what is an emi filter ? Im a novice at this stuff and gathering information as i go
                  Last edited by rustinjust; 06-08-2022, 09:04 AM. Reason: make adjustment to description
                  • yokoono
                    • Apr 2010
                    • 502
                    The EMI filter is a filter that stops the oscillations from the power supply to reach the voltage network. Anti-oscillation filter. It can disturb medium-wave radios.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      you really need to measure the size of the old capacitor for lead spacing etc.
                      • R_J
                        • 9582
                        Too bad you never mention the model number, board number or even the caps location number. So I will guess that it is a 17PW15-9 and the location is C802 and if it IS this cap, you can try the tv with it removed.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          possibly a 17pw20
                          • R_J
                            • 9582
                            Yes, it seems to be the 17pw20, C802 is the location and it should operate without it installed for testing, but should be replaced.
                              • 31161
                              important question is is it across mains (X1 class) or between the primary and secondary (Y1 class)
                              • rustinjust
                                • Jun 2022
                                • 49
                                • England
                                If it isnt replaced could it cause problems with the tv operation ?
                                • rustinjust
                                  • Jun 2022
                                  • 49
                                  • England
                                  Its a 17pw20 v2 and im not sure where the board number is, im new to this so learning as i go, i have a name and number on the board, its a tehlikelli canli bolge and somewhere else on the board is written a number of: 260707 if thats the board number ?
                                  • lotas
                                    • Jan 2016
                                    • 4711
                                    • Russia
                                    17pw20
                                    • rustinjust
                                      • Jun 2022
                                      • 49
                                      • England
                                      Originally posted by lotas
                                      17pw20
                                      Im not sure how to read a wiring diagram/schematics as im starting out in electronics. Is there a resource on here to understand it or a book/video/online thing you can recommend ?
                                      Also where is the number of the board usually written or where on my board will it be ?
                                      • R_J
                                        • 9582
                                        The component location number is next to the component on the board (sometimes it is on the bottom as well) This number will be next to the component in the schematic.
                                        The board number can be located anywhere and can be more than one, this one is 17PW20 V2. The schematic for these boards can be hard to work with as the schematic covers many similar boards with some components installed in some and missing in others.
                                        • rustinjust
                                          Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                                          by rustinjust
                                          My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                                          The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                                          It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                                          I have to turn the tv off and then on again with...
                                          09-28-2023, 12:23 PM
                                        • Uy181
                                          Capacitor Replacement: Advice Needed
                                          by Uy181
                                          So I have a couple motherboards I am recapping that I do not have capacitor replacements already in my used inventory. I am wondering which capacitors that are currently in production for 2022 that I can use to replace the following capacitors:
                                          "SAM YOUNG" NXC series 6.3v 3300uf
                                          "Nichicon" HM series 6.3v 1000uf
                                          "Nichicon" HM series 6.3v 3300uf
                                          "United Chemi-Con" KZG series 6.3v 820uf
                                          "TK" ATWY series 6.3v 820uf
                                          Thanks!
                                          05-28-2022, 04:36 PM
                                        • Hondaman
                                          Windows 11 buying advice needed
                                          by Hondaman
                                          My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                                          She does not want to switch to Linux. And she does not want to use a laptop because...
                                          04-14-2025, 11:35 PM
                                        • RyanRiz
                                          Asus ROG STRIX G512LW-WS74 needed clearME bios after PCH replacement
                                          by RyanRiz
                                          Dear All,
                                          I need assistance creating clearMe bios. The laptop is shorted PCH, after PCH replacement laptop can ON but cannot boot. Power supply current reading is 2.5-3.0 Amp.
                                          Model : G512LW-WS74
                                          SN : LCNRKD009429512
                                          CN : ANE9
                                          Attach backup bios.
                                          Thanks for your help.
                                          Best Regards....
                                          01-14-2025, 05:55 PM
                                        • ant3202
                                          Help Needed to Find Replacement for the IC Chip - CY1341A
                                          by ant3202
                                          Hi All
                                          Had tried using google lens but not much info was provided.
                                          Appreciate if you can help identify this component.
                                          IC Seems to be SOT-23.
                                          Thank You...
                                          05-15-2025, 08:45 PM
