Help Needed to Find Replacement for the IC Chip - CY1341A
This topic has been answered.
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Hi All
    Had tried using google lens but not much info was provided.
    Appreciate if you can help identify this component.
    IC Seems to be SOT-23.
    Thank You
  • Answer selected by ant3202 at 07-09-2025, 04:10 AM.
    ant3202
    • Jun 2006
    • 275
    • Singapore
    Thank you stj and truclacicr, TL431 works
      • 31289
      it *may* be a copy of a TL431
      what does it do?
      • truclacicr
        • Apr 2019
        • 355
        • australia
        https://u.dianyuan.com/bbs/u/82/3003691256524958.pdf (CYT431A)
        https://img.alicdn.com/imgextra/i2/3...3659875068.jpg (photo)
        • ant3202
          • Jun 2006
          • 275
          • Singapore
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • danielgerman681
            ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
            by danielgerman681
            Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
            08-27-2025, 01:17 PM
          • ebugs
            Asus laptop EC/SIO chip replacement
            by ebugs
            Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
            I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
            I found the EC chip...
            09-14-2024, 02:09 AM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
